I’ve modify the objectDetector_Yolo/deepstream_app_config_yoloV3_tiny.txt as follow:
[source0]
enable=1
type=1
camera-width=1920
camera-height=1080
camera-fps-n=30
camera-fps-d=1
num-sources=1
gpu-id=0
cudadec-memtype=0
when I run the sample, I got an error below:
ERROR from src_elem: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin /GstBin:src_sub_bin0/
GstV4l2Src:src_elem:
streaming stopped, reason not-negotiated (-4)
** INFO: <bus_callback:175>: Pipeline running
Quitting
App run failed
Do I miss something??
Yes. Before Installing Deepstream SDK, I have installed the pre-requisite packages
What kind of camera do you use?
Could you share the log generated from the following command:
$ sudo apt-get install v4l-utils
$ v4l2-ctl -l
@AastaLLL :
Greatful for your replying
Here is the log generated from the command:
brightness 0x00980900 (int) : min=-64 max=64 step=1 default=0 value=-1
contrast 0x00980901 (int) : min=0 max=100 step=1 default=38 value=39
saturation 0x00980902 (int) : min=0 max=100 step=1 default=60 value=60
hue 0x00980903 (int) : min=-180 max=180 step=1 default=0 value=0
white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
gamma 0x00980910 (int) : min=100 max=500 step=1 default=440 value=439
gain 0x00980913 (int) : min=0 max=128 step=1 default=40 value=40
power_line_frequency 0x00980918 (menu) : min=0 max=2 default=1 value=1
white_balance_temperature 0x0098091a (int) : min=2800 max=6500 step=10 default=4600 value=4600 flags=inactive
sharpness 0x0098091b (int) : min=0 max=100 step=1 default=80 value=80
backlight_compensation 0x0098091c (int) : min=0 max=2 step=1 default=0 value=0
exposure_auto 0x009a0901 (menu) : min=0 max=3 default=3 value=3
exposure_absolute 0x009a0902 (int) : min=50 max=10000 step=1 default=166 value=166 flags=inactive
exposure_auto_priority 0x009a0903 (bool) : default=0 value=1
focus_absolute 0x009a090a (int) : min=0 max=1023 step=1 default=68 value=68 flags=inactive
focus_auto 0x009a090c (bool) : default=1 value=1
Thanks~~
Thanks~~
Hello sir:
I changed another webcam, the reference app run successfully
Thanks again for you replying~
I have installed al prerequisite package for DeepstreamSDK but by running this command :
v4l2-ctl -l
This message is what showed to me:
Failed to open /dev/video0: No such file or directory
v4l2-ctl -l
Ensure you have inserted the webcam correctly.
If still shows this message, that means the system couldn’t recognize the device, please confirm your
device is supported by Ubuntu OS
v4l2-ctl -l
I have an USB Camera device. I’m sure that it’s plugged in correctly. Also I have installed device driver and I could see USB camera input via MVViewer . But v4l2 could not detect device.
