Software Version
[*] DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
[*] 2.1.0
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
The updateCurrentHealthSignal method of the CGF Node class involves the dwHealthSignal data type, which is defined as follows:
@brief Basic health signal that describes the health status of a particular software element
@note each health signal is defined to be 1024 bytes
typedef struct dwHealthSignal
/// timestamp at which the health status was last updated, filled by module
dwTime_t timestamp;
/// module id, automatically filled
uint16_t sourceID;
/// the number of errors in @a errorIds
size_t count;
/// module defined error
uint32_t errorIDs[DW_MAX_ERROR_SIGNAL_ERRORS_COUNT];/// bytes used in the optional byte array
size_t dataSize;
/// optional byte array for additional information
uint8_t data[DW_MAX_HEALTH_BYTEARRAY_SIZE];
} dwHealthSignal;
I have a question regarding the sourceID field: How is the module ID generated and by whom?
