We have to connect 2~3 eth port to AGX Orin Developer Kit.
So, we are using ‘usb to eth’ cable.
There is a issue when we use multipe ‘usb to eth’ port.
usb c (x1) => no issue
usb c (x2) => only 1 port has established and another doesn’t recognized.
usb c (x1) + usa a (x1) => no issue
I wonder no.2 case, what is the problem??
DaneLLL
September 5, 2022, 3:41am
#3
sumin.lee:
For this case, which type-C port do you use on Orin developer kit? And you connect to a USB hub and then to two USB to Ethernet dongles? Would like to get more information to understand the error case.
Please, check the dmesg and image
1. USB A (x1) and USB C (x1)
[J33] USB Type A to Eth => Connected
[J41] USB Type C to Eth => Connected
dmesg_ca.txt (78.4 KB)
2. USB C (x2)
[J40] USB Type C to Eth => Not Connected
dmesg_cc.txt (77.1 KB)
DaneLLL
September 5, 2022, 9:13am
#5
system
Closed
September 28, 2022, 4:47am
#7
