I tried connect the USB-C SDcard reader to USB-C above the power barrel connector,and the log shows below:
[ 227.442235] usb 1-2: new high-speed USB device number 6 using tegra-xusb
[ 227.599889] usb 1-2: New USB device found, idVendor=05e3, idProduct=0749, bcdDevice=15.32
[ 227.599899] usb 1-2: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 227.599903] usb 1-2: Product: USB3.0 Card Reader
[ 227.599907] usb 1-2: Manufacturer: Generic
[ 227.599910] usb 1-2: SerialNumber: 000000001532
[ 227.601501] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 227.602569] scsi host0: usb-storage 1-2:1.0
[ 228.615692] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 1532 PQ: 0 ANSI: 6
[ 228.892267] sd 0:0:0:0: [sda] 62333952 512-byte logical blocks: (31.9 GB/29.7 GiB)
[ 228.893165] sd 0:0:0:0: [sda] Write Protect is off
[ 228.893309] sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
[ 228.893915] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 228.925260] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sda10 sda11 sda12 sda13 sda14
[ 228.928416] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 229.665749] EXT4-fs (sda1): 9 orphan inodes deleted
[ 229.665757] EXT4-fs (sda1): recovery complete
[ 229.698064] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
then i remove the SDcard reader ,and try connect to front USB-C ,the log shows below:
[ 581.657661] usb 1-1: new high-speed USB device number 7 using tegra-xusb
[ 581.811266] usb 1-1: New USB device found, idVendor=05e3, idProduct=0749, bcdDevice=15.32
[ 581.811277] usb 1-1: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 581.811282] usb 1-1: Product: USB3.0 Card Reader
[ 581.811292] usb 1-1: Manufacturer: Generic
[ 581.811295] usb 1-1: SerialNumber: 000000001532
[ 581.812498] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 581.812885] scsi host0: usb-storage 1-1:1.0
[ 582.831599] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 1532 PQ: 0 ANSI: 6
[ 583.112839] sd 0:0:0:0: [sda] 62333952 512-byte logical blocks: (31.9 GB/29.7 GiB)
[ 583.113668] sd 0:0:0:0: [sda] Write Protect is off
[ 583.113814] sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
[ 583.114415] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 583.159348] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sda10 sda11 sda12 sda13 sda14
[ 583.163453] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 583.770148] EXT4-fs (sda1): recovery complete
[ 583.771275] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
It weird because it never connect successfully when using dc barrel before, so I try to connect my USB-C device which couldn’t connect before, then It work,devices are connected with some error but it work normally , I still don’t know what happen to these…
[ 1235.467333] usb 1-1: new low-speed USB device number 26 using tegra-xusb
[ 1235.599406] usb 1-1: device descriptor read/64, error -71
[ 1235.839370] usb 1-1: device descriptor read/64, error -71
[ 1236.075302] usb 1-1: new low-speed USB device number 27 using tegra-xusb
[ 1236.203348] usb 1-1: device descriptor read/64, error -71
[ 1236.439322] usb 1-1: device descriptor read/64, error -71
[ 1236.547410] usb usb1-port1: attempt power cycle
[ 1236.967280] usb 1-1: new full-speed USB device number 28 using tegra-xusb
[ 1236.995691] usb 1-1: New USB device found, idVendor=1546, idProduct=01a9, bcdDevice= 1.00
[ 1236.995695] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1236.995696] usb 1-1: Product: u-blox GNSS receiver
[ 1236.995697] usb 1-1: Manufacturer: u-blox AG - www.u-blox.com
[ 1236.996984] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 1242.922924] usb 1-2: new low-speed USB device number 29 using tegra-xusb
[ 1243.054988] usb 1-2: device descriptor read/64, error -71
[ 1243.294939] usb 1-2: device descriptor read/64, error -71
[ 1243.530891] usb 1-2: new low-speed USB device number 30 using tegra-xusb
[ 1243.662946] usb 1-2: device descriptor read/64, error -71
[ 1243.898885] usb 1-2: device descriptor read/64, error -71
[ 1244.007045] usb usb1-port2: attempt power cycle
[ 1244.434831] usb 1-2: new full-speed USB device number 31 using tegra-xusb
[ 1244.463258] usb 1-2: New USB device found, idVendor=1546, idProduct=01a9, bcdDevice= 1.00
[ 1244.463268] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1244.463270] usb 1-2: Product: u-blox GNSS receiver
[ 1244.463272] usb 1-2: Manufacturer: u-blox AG - www.u-blox.com
[ 1244.464929] cdc_acm 1-2:1.0: ttyACM1: USB ACM device
