How to achieve the samepower? TX2 8G and TX2 4G
For the same software application, there is difference between TX2 8G and TX2 4G power. How to solve it?
You might need to give more detail here.
TX2 4GB is actually a TX2i module but not a TX2 module. Also, I don’t think it is precise to say “same software application” because there must have other background application that would affect the result too.
How large is the power difference?
TX2 8G power higher than TX2 4G 4W,service voltage 12V。
In software, how to reduce the power consumption without changing the GPU/CPU frequency
What is the power difference if you run nothing? Also, is this on devkit?
What kind of application are you running?
