I have an engine shape in usd file. Its an existing model without any parameters. I want to add material to the model thru connector sample. I have added the image of model in attachment(s). Guide me on how to do it thru code.
I modified HelloWorld.cpp to assign a material from the MDL library and even set a shader input parameter.
See this video that walks through the process: https://youtu.be/TubrQuh1N4Y
Also, here’s the USDA file I used in the video and the modified HelloWorld source:
matExNothing.usda (2.6 KB)
helloWorld.cpp (10.9 KB)
Thank you so much LouRohan. The tutorial and example file provided is really useful. But I have another doubt LouRohan. In the example provided it shows only with one object and added with one material. What if there is around 40 - 50 objects. And I have to assign different material from the MDL Library for each objects. I will have two separate arrays with object id and material name . How to add them in a ‘for’ loop to do the process? Cuz in the example I find out it shows only for first usdGeoMesh. I will attach the usd file with multiple objects that i have here.
Trial_2_Ori.usda (2.0 MB)
