Hi I have an existing usd robot that is working fine in omniisaacgymnvs and of the correct porportions
I have the stl files for the 3d printed version
how can I add these to the usd file for the robot to visualise it better in omniverse?
i wanted to be able to colour the different meshes and have several meshes of different colours for each rigid body
Hi there, please check out the CAD importer tool available in omniverse: CAD Converter â Omniverse Extensions latest documentation to import the STL into USD. Once imported, you can add it to your existing assetâs USD stage and drag the individual meshes under the corresponding rigid bodies as their visual bodies.
Thanks @kellyg I had tried doing it previously from the import menu and failed but it did work from the content browser. The meshes were off-centre due to a fault in my stl exporter but I was able to fix this with meshlab.
May seem a really basic question but how can I set the colors of the meshes with the least memory allocationâŠ? I couldnât understand how to create a simple custom materialâŠ
depending on the complexity of the material, the quickest way to get material into your scene and onto your meshes could be using some of the materials shipped with OV. you can access it via Window > Browsers > Materials:
you can see the variety you can choose from within âmetalâ section alone
to apply any to your mesh, simply drag and drop onto prims where youâd like that specific material. some of these come with predetermined params for additional tweaking.
alternatively, you can create a material from scratch, which may allow you to control the material/shader complexity, which could have direct impact on the viewport perf. you can review the material overview video from the doc:
https://docs.omniverse.nvidia.com/materials-and-rendering/latest/materials.html#overview
thanks @simplychenable this is exactly what I needed re. material from scratchâŠ
@Simplychenable and @kellyg I was able to use the cad importer using .obj files. Although isaacsim accepts objâs directly dropped onto the stage this throws errors in omniisaacgymenvs which would only accept the converted usdâs. I was able to take the simple generated materials from the converter and drop them into a robot âLooksâ folder so I didnât have to build my own. The mesh scaling was out by a factor of 10 and had to mess a bit with the orientation. A bit of careful placing of the origin in relation to the joint orientation in my cad program before obj import meant I could use the meshes with some rotations, scaling, but no transforms necessary. Here is the final result which Iâm really pleased with
now all I have to do is design the arms and body and programmatically put in some arm swing
