I have used the asset_usd_converter.py to convert the stl file to the USD file. However the performance of the USD object is very different from the one in the NUCLEUS. The objects can be affected by the gravity but it seems that it does not have a collision with other obstacle. When they collide with the object, it just penetrates them. How can I handle this problem by using the python code?
Thank you for your reply. I have loaded the objects into the physics scene with reasonable dynamics but encountered another problem. The USD file is without a texture. In fact, my object files have a texture for this. Could you help me with this? Thank you.
i will try my best as i am simply another OV user. so to confirm, the textures are missing; is your mesh showing up red? where was the model sourced (which DCC was it made in)?
Thank you very much. In fact, the mesh is white and without any color.The ycb model is downloaded from the YCB dataset. I use asset_usb_converter.py to convert it into a USD file. But the USD file is without any texture.
