Is it possible to improve image quality to produce HDR images with UHD/FHD resolution in deepstream pipeline.
Thank you,
• Hardware Platform (Jetson / GPU) Jetson • DeepStream Version 6.2 • JetPack Version (valid for Jetson only) 5.1.1 • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Please share vendor and ID of the camera you are using. Not sure if you use the camera from our partners. We have partners listed in Jetson Ecosystem | NVIDIA Developer
Per our understanding, imx219 does not support HDR. You may need to switch to use other camera.
For enhancement in image quality, it has to do IQ tuning and adjust ISP parameters. The later plugins cannot do further enhancement. Please consult our camera partner for help. They have existing camera modules, and you can try and select the one for your use-case.
