i used custom board,Jetson AGX orin 32G,jetpack 5.1,L4T 35.2.1,
My hardware has added a network card,aqc113
,i want to with uphy1 trans into pcie ,Enable this 10G network card.
what shoud i do,to enable this 10G network card? thanks.
Please read document first.
If this is PCIe card, then NV would only support to the point that pcie could detect the card. Whether it would work or not depend on the vendor driver.
I see that the default is pcie mode, do I need to modify the device tree? thanks
if it is default mode, then no need to modify device tree.
