You are trying to control the robot through Jupiter notebook via Isaac SDK, correct?
If this is the case please ask your question in the IsaacSDK forum, since the control part happens there.
yes,thank you for asking. the issue is remain.
Can’t find documentation on how to add custom joint in USD and RobotEngine, so the python program cannot found the related joint when i try adding new robot arm into omniverse isaac sim.
@yoeyat when you make REB_JointControl you need to use the Relationship Editor under Windows->Isaac->Relationship Editor. Click on the REB_JointControl and then set the articulationPrim reference to /tm700. This will tell the REB_JointControl component which articulation you are trying to control.
