你好,按照上面步骤将APP分区更换位置后,使用SDK Manager烧录时报错:
17:05:26 INFO: Flash Jetson Linux - flash: [ 1.2308 ] tegraparser_v2 --pt flash.xml.tmp
17:05:26 ERROR: Flash Jetson Linux - flash: [ 1.2326 ] ERROR: Partition 'APP', 'kernel' have the same GPT ID: 1
17:05:26 ERROR: Flash Jetson Linux - flash: *** ERROR: flashing failed.
17:05:26 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
17:05:26 ERROR: Flash Jetson Linux - flash: command terminated with error
17:05:26 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed
未更换APP分区位置之前,开机dmesg信息为:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Aug 1 12:32:50 PDT 2023
[ 0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x4788c4518 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x458630000 MEMATTR=0x459e4e018 ESRT=0x4585f8118 RNG=0x47c58de98 MEMRESERVE=0x459e50f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x00000004585f8118 to 0x00000004585f8150.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000047fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000a0973fff]
[ 0.000000] node 0: [mem 0x00000000a0974000-0x00000000a0975fff]
[ 0.000000] node 0: [mem 0x00000000a0977000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c79fffff]
[ 0.000000] node 0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[ 0.000000] node 0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000004573c3fff]
[ 0.000000] node 0: [mem 0x00000004573c4000-0x000000045783ffff]
[ 0.000000] node 0: [mem 0x0000000457840000-0x0000000457c8ffff]
[ 0.000000] node 0: [mem 0x0000000457c90000-0x000000045852ffff]
[ 0.000000] node 0: [mem 0x0000000458530000-0x000000045854ffff]
[ 0.000000] node 0: [mem 0x0000000458550000-0x00000004585effff]
[ 0.000000] node 0: [mem 0x00000004585f0000-0x000000045861ffff]
[ 0.000000] node 0: [mem 0x0000000458620000-0x000000045863ffff]
[ 0.000000] node 0: [mem 0x0000000458640000-0x00000004586cffff]
[ 0.000000] node 0: [mem 0x00000004586d0000-0x00000004586fffff]
[ 0.000000] node 0: [mem 0x0000000458700000-0x0000000459cfffff]
[ 0.000000] node 0: [mem 0x0000000459d00000-0x0000000459d9ffff]
[ 0.000000] node 0: [mem 0x0000000459da0000-0x0000000459e5ffff]
[ 0.000000] node 0: [mem 0x0000000459e60000-0x0000000459e7ffff]
[ 0.000000] node 0: [mem 0x0000000459e80000-0x0000000459f0ffff]
[ 0.000000] node 0: [mem 0x0000000459f10000-0x0000000459f2ffff]
[ 0.000000] node 0: [mem 0x0000000459f30000-0x0000000459f8ffff]
[ 0.000000] node 0: [mem 0x0000000459f90000-0x000000045a0cffff]
[ 0.000000] node 0: [mem 0x000000045a0d0000-0x000000045a11ffff]
[ 0.000000] node 0: [mem 0x000000045a120000-0x000000045a1bffff]
[ 0.000000] node 0: [mem 0x000000045a1c0000-0x000000045a23ffff]
[ 0.000000] node 0: [mem 0x000000045a240000-0x000000045a2effff]
[ 0.000000] node 0: [mem 0x000000045a2f0000-0x000000045a33ffff]
[ 0.000000] node 0: [mem 0x000000045a340000-0x000000045a56ffff]
[ 0.000000] node 0: [mem 0x000000045a570000-0x000000045a5fffff]
[ 0.000000] node 0: [mem 0x000000045a600000-0x000000045a64ffff]
[ 0.000000] node 0: [mem 0x000000045a650000-0x000000045a67ffff]
[ 0.000000] node 0: [mem 0x000000045a680000-0x000000045a71ffff]
[ 0.000000] node 0: [mem 0x000000045a720000-0x000000045a76ffff]
[ 0.000000] node 0: [mem 0x000000045a770000-0x000000045a80ffff]
[ 0.000000] node 0: [mem 0x000000045a810000-0x000000045aceffff]
[ 0.000000] node 0: [mem 0x000000045acf0000-0x000000045aecffff]
[ 0.000000] node 0: [mem 0x000000045aed0000-0x000000047c53ffff]
[ 0.000000] node 0: [mem 0x000000047c540000-0x000000047c58ffff]
[ 0.000000] node 0: [mem 0x000000047c590000-0x000000047fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000047fffffff]
[ 0.000000] On node 0 totalpages: 3965615
[ 0.000000] DMA zone: 4619 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 295599 pages, LIFO batch:63
[ 0.000000] Normal zone: 57344 pages used for memmap
[ 0.000000] Normal zone: 3670016 pages, LIFO batch:63
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] pcpu-alloc: s90328 r8192 d32552 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 3903652
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=efifb:off nospectre_bhb nv-auto-config
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[ 0.000000] Memory: 15175708K/15862460K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 621216K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000708] Console: colour dummy device 80x25
[ 0.002180] printk: console [tty0] enabled
[ 0.002245] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.002292] pid_max: default: 32768 minimum: 301
[ 0.002602] LSM: Security Framework initializing
[ 0.002718] Yama: becoming mindful.
[ 0.002771] SELinux: Initializing.
[ 0.003038] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.003085] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.006328] rcu: Hierarchical SRCU implementation.
[ 0.006572] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.007278] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-0001-p3509-0000.dts
[ 0.007350] DTB Build time: Aug 1 2023 12:44:20
[ 0.010045] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.010297] Remapping and enabling EFI services.
[ 0.012735] smp: Bringing up secondary CPUs ...
[ 0.042398] Detected PIPT I-cache on CPU1
[ 0.042499] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.072034] Detected PIPT I-cache on CPU2
[ 0.072135] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.101597] Detected PIPT I-cache on CPU3
[ 0.101693] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.131280] Detected PIPT I-cache on CPU4
[ 0.131380] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.160928] Detected PIPT I-cache on CPU5
[ 0.161093] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.161518] smp: Brought up 1 node, 6 CPUs
[ 0.161704] SMP: Total of 6 processors activated.
[ 0.161746] CPU features: detected: Privileged Access Never
[ 0.161767] CPU features: detected: LSE atomic instructions
[ 0.161780] CPU features: detected: User Access Override
[ 0.161792] CPU features: detected: 32-bit EL0 Support
[ 0.161804] CPU features: detected: RAS Extension Support
[ 0.161815] CPU features: detected: CRC32 instructions
[ 0.161827] CPU features: detected: 32-bit EL1 Support
[ 0.201062] spectre-bhb mitigation disabled by command line option
[ 0.235483] CPU: All CPU(s) started at EL2
[ 0.244724] devtmpfs: initialized
[ 0.298652] Registered cp15_barrier emulation handler
[ 0.298759] Registered setend emulation handler
[ 0.298778] KASLR enabled
[ 0.299042] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.299065] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.300573] pinctrl core: initialized pinctrl subsystem
[ 0.301403] SMBIOS 3.0.0 present.
[ 0.301437] DMI: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 0.302325] NET: Registered protocol family 16
[ 0.304611] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.305605] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.307413] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.307486] audit: initializing netlink subsys (disabled)
[ 0.307774] audit: type=2000 audit(0.304:1): state=initialized audit_enabled=0 res=1
[ 0.308276] thermal_sys: Registered thermal governor 'step_wise'
[ 0.308285] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.308300] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.310694] cpuidle: using governor menu
[ 0.311047] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.311493] ASID allocator initialised with 32768 entries
[ 0.311777] Serial: AMBA PL011 UART driver
[ 0.316328] Tegra reboot handler registered.
[ 0.393669] mc: mapped MMIO address: 0xffff800010880000 -> 0x2c10000
[ 0.393708] mc: mapped MMIO address: 0xffff8000108a0000 -> 0x2c20000
[ 0.393734] mc: mapped MMIO address: 0xffff8000108c0000 -> 0x2c30000
[ 0.393759] mc: mapped MMIO address: 0xffff8000108e0000 -> 0x2c40000
[ 0.393783] mc: mapped MMIO address: 0xffff800010900000 -> 0x2c50000
[ 0.393806] mc: mapped MMIO address: 0xffff800010920000 -> 0x2b80000
[ 0.393830] mc: mapped MMIO address: 0xffff800010940000 -> 0x2b90000
[ 0.393853] mc: mapped MMIO address: 0xffff800010960000 -> 0x2ba0000
[ 0.393876] mc: mapped MMIO address: 0xffff800010980000 -> 0x2bb0000
[ 0.393900] mc: mapped MMIO address: 0xffff8000109a0000 -> 0x1700000
[ 0.393922] mc: mapped MMIO address: 0xffff8000109c0000 -> 0x1710000
[ 0.393958] mc: mapped MMIO address: 0xffff8000109e0000 -> 0x1720000
[ 0.393989] mc: mapped MMIO address: 0xffff800010a00000 -> 0x1730000
[ 0.394013] mc: mapped MMIO address: 0xffff800010a20000 -> 0x1740000
[ 0.394035] mc: mapped MMIO address: 0xffff800010a40000 -> 0x1750000
[ 0.394059] mc: mapped MMIO address: 0xffff800010a60000 -> 0x1760000
[ 0.394092] mc: mapped MMIO address: 0xffff800010a80000 -> 0x1770000
[ 0.394174] mc-err: mcerr ops are set to t19x
[ 0.406757] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.406780] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.406791] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.406802] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.413376] ACPI: Interpreter disabled.
[ 0.414502] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.415947] iommu: Default domain type: Translated
[ 0.416015] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.416453] SCSI subsystem initialized
[ 0.416624] usbcore: registered new interface driver usbfs
[ 0.416666] usbcore: registered new interface driver hub
[ 0.416698] usbcore: registered new device driver usb
[ 0.417095] mc: Linux media interface: v0.10
[ 0.417124] videodev: Linux video capture interface: v2.00
[ 0.417500] pps_core: LinuxPPS API ver. 1 registered
[ 0.417511] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.417530] PTP clock support registered
[ 0.417742] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.418194] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.418263] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.418840] Registered efivars operations
[ 0.424466] FPGA manager framework
[ 0.424582] Advanced Linux Sound Architecture Driver Initialized.
[ 0.425228] Bluetooth: Core ver 2.22
[ 0.425286] NET: Registered protocol family 31
[ 0.425298] Bluetooth: HCI device and connection manager initialized
[ 0.425312] Bluetooth: HCI socket layer initialized
[ 0.425333] Bluetooth: L2CAP socket layer initialized
[ 0.425380] Bluetooth: SCO socket layer initialized
[ 0.427087] camchar: rtcpu character device driver loaded
[ 0.427946] clocksource: Switched to clocksource arch_sys_counter
[ 0.762240] VFS: Disk quotas dquot_6.6.0
[ 0.762324] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.763107] pnp: PnP ACPI: disabled
[ 0.773805] la/ptsa driver initialized.
[ 0.773976] NET: Registered protocol family 2
[ 0.774267] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.784033] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.784145] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.784692] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.785124] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.785268] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.785426] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.785748] NET: Registered protocol family 1
[ 0.786540] RPC: Registered named UNIX socket transport module.
[ 0.786556] RPC: Registered udp transport module.
[ 0.786565] RPC: Registered tcp transport module.
[ 0.786574] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.786610] PCI: CLS 0 bytes, default 64
[ 0.786873] Trying to unpack rootfs image as initramfs...
[ 1.001813] Freeing initrd memory: 9552K
[ 1.007070] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.007502] kvm [1]: IPA Size Limit: 40 bits
[ 1.007869] kvm [1]: vgic interrupt IRQ9
[ 1.008344] kvm [1]: VHE mode initialized successfully
[ 1.009909] Initialise system trusted keyrings
[ 1.010199] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.015345] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.016274] NFS: Registering the id_resolver key type
[ 1.016309] Key type id_resolver registered
[ 1.016319] Key type id_legacy registered
[ 1.016408] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.016425] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.016473] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.025015] NET: Registered protocol family 38
[ 1.025035] Key type asymmetric registered
[ 1.025046] Asymmetric key parser 'x509' registered
[ 1.025086] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 1.025297] io scheduler mq-deadline registered
[ 1.025311] io scheduler kyber registered
[ 1.032350] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.032409] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.032462] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.032529] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.032581] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.036706] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.037183] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.037754] EINJ: ACPI disabled.
[ 1.040078] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.040098] tegra-pmc: ### PMC reset source: MAINSWRST
[ 1.040108] tegra-pmc: ### PMC reset level: L1
[ 1.040117] tegra-pmc: ### PMC reset status reg: 0x2d
[ 1.040152] tegra-pmc: PMC Prod config success
[ 1.044403] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.541828] printk: console [ttyTCU0] enabled
[ 2.547322] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.552486] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.556803] arm-smmu 10000000.iommu: stage 1 translation
[ 2.562174] arm-smmu 10000000.iommu: stage 2 translation
[ 2.567626] arm-smmu 10000000.iommu: nested translation
[ 2.573417] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.580577] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.590790] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.593473] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.599830] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.607215] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.612868] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.617846] arm-smmu 12000000.iommu: stage 1 translation
[ 2.623372] arm-smmu 12000000.iommu: stage 2 translation
[ 2.628784] arm-smmu 12000000.iommu: nested translation
[ 2.634211] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.641147] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.651775] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.654286] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.661069] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.668185] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.677905] tegra_profiler: version: 1.151, samples/io: 51/30
[ 2.681244] tegra_profiler: auth: init
[ 2.685519] THERMAL EST: found 3 subdevs
[ 2.689177] THERMAL EST num_resources: 0
[ 2.693007] [THERMAL EST subdev 0]
[ 2.696075] [THERMAL EST subdev 1]
[ 2.699732] [THERMAL EST subdev 2]
[ 2.702732] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.709420] THERMAL EST: thz register success.
[ 2.713707] THERMAL EST: end of probe, return err: 0
[ 2.718664] nvsciipc: loaded module
[ 2.725349] tun: Universal TUN/TAP device driver, 1.6
[ 2.727966] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.734762] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.740065] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.745253] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.751357] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.756363] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.762720] PPP generic driver version 2.4.2
[ 2.767041] PPP BSD Compression module registered
[ 2.771331] PPP Deflate Compression module registered
[ 2.776855] PPP MPPE Compression module registered
[ 2.781631] usbcore: registered new interface driver r8152
[ 2.787353] usbcore: registered new interface driver asix
[ 2.792692] usbcore: registered new interface driver ax88179_178a
[ 2.798840] usbcore: registered new interface driver cdc_ether
[ 2.804800] usbcore: registered new interface driver net1080
[ 2.810370] usbcore: registered new interface driver cdc_subset
[ 2.816141] usbcore: registered new interface driver zaurus
[ 2.821837] usbcore: registered new interface driver cdc_ncm
[ 2.827773] usbcore: registered new interface driver aqc111
[ 2.833132] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.839243] ohci-pci: OHCI PCI platform driver
[ 2.843788] ohci-platform: OHCI generic platform driver
[ 2.849375] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.855637] usbcore: registered new interface driver uas
[ 2.860097] usbcore: registered new interface driver usb-storage
[ 2.866166] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 2.871858] mousedev: PS/2 mouse device common for all mice
[ 2.876981] usbcore: registered new interface driver xpad
[ 2.884918] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.887741] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[ 2.895836] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.902258] i2c /dev entries driver
[ 2.905610] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 2.911439] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 2.916467] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 2.921879] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 2.927443] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 2.932713] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 2.938403] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 2.950373] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.951077] device-mapper: uevent: version 1.0.3
[ 2.955149] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.965467] cpuidle: Initializing cpuidle driver
[ 2.969422] sdhci: Secure Digital Host Controller Interface driver
[ 2.974076] sdhci: Copyright(c) Pierre Ossman
[ 2.978796] Synopsys Designware Multimedia Card Interface Driver
[ 2.984960] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.990724] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 2.991274] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 3.004071] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 3.022848] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 3.032318] vdd-1v0: supplied by regulator-dummy
[ 3.037784] vdd-1v8-hs: supplied by regulator-dummy
[ 3.042569] vdd-1v8-ls: supplied by regulator-dummy
[ 3.047287] vdd-1v8-ao: supplied by regulator-dummy
[ 3.051133] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.055738] vdd-rtc: supplied by regulator-dummy
[ 3.057636] spmic-ldo1: supplied by regulator-dummy
[ 3.059006] vdd-ao-3v3: supplied by regulator-dummy
[ 3.065381] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.071803] spmic-ldo4: supplied by regulator-dummy
[ 3.073238] vdd-usb-3v3: supplied by regulator-dummy
[ 3.079572] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.085885] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.091976] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.093925] gpio-510 (gpio_default): hogged as output/high
[ 3.095711] gpio-511 (gpio_default): hogged as output/high
[ 3.098479] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.237313] max77686-rtc max77620-rtc: registered as rtc0
[ 3.238562] max77620-power max20024-power: Event recorder REG_NVERC : 0x44
[ 3.238851] max77620 4-003c: max77620 probe successful
[ 3.949791] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.950701] hid: raw HID events driver (C) Jiri Kosina
[ 3.951375] usbcore: registered new interface driver usbhid
[ 3.951518] usbhid: USB HID core driver
[ 3.953166] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[ 3.954248] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.039855] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.040422] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.041406] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.042013] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.043446] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.044383] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.044946] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.046780] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (48)
[ 4.047132] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.048799] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=058eec606b43624552a5258fda5b4f3967bdfde1
[ 4.056175] tegra_aon c1a0000.aon: Adding to iommu group 5
[ 4.062828] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.067246] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.074295] denver_knobs_init:MTS_VERSION:55637613
[ 4.085621] t19x_cache tegra-cache: probed
[ 4.087670] optee: probing for conduit method.
[ 4.088870] optee: revision 3.21 (d8269f24)
[ 4.209137] optee: dynamic shared memory is enabled
[ 4.210608] optee: initialized driver
[ 4.214876] nvpmodel: initialized successfully
[ 4.215412] tegra_hv: get_hvd: not initialized yet
[ 4.215568] user_ivc_mempool: hypervisor not present
[ 4.216932] usbcore: registered new interface driver snd-usb-audio
[ 4.218282] u32 classifier
[ 4.218384] input device check on
[ 4.218503] Actions configured
[ 4.218796] Initializing XFRM netlink socket
[ 4.219667] NET: Registered protocol family 10
[ 4.223159] Segment Routing with IPv6
[ 4.223460] NET: Registered protocol family 17
[ 4.223713] NET: Registered protocol family 15
[ 4.224165] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.225032] Bluetooth: RFCOMM socket layer initialized
[ 4.225285] Bluetooth: RFCOMM ver 1.11
[ 4.225456] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.225692] Bluetooth: HIDP socket layer initialized
[ 4.226666] 9pnet: Installing 9P2000 support
[ 4.226899] Key type dns_resolver registered
[ 4.228592] registered taskstats version 1
[ 4.228783] Loading compiled-in X.509 certificates
[ 4.264236] Loaded X.509 cert 'Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9'
[ 4.265923] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 4.271442] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 4.271827] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 4.272288] tegra194-pcie 14160000.pcie: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 4.273048] tegra194-pcie 14160000.pcie: MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[ 4.388011] tegra194-pcie 14160000.pcie: Link up
[ 4.392074] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 4.392313] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 4.392471] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 4.392682] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 4.392933] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 4.393284] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 4.393725] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.405397] pci 0004:01:00.0: [10ec:8168] type 00 class 0x020000
[ 4.405892] pci 0004:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 4.406140] pci 0004:01:00.0: reg 0x10: [io size 0x0100]
[ 4.406592] pci 0004:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 4.407049] pci 0004:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 4.408711] pci 0004:01:00.0: supports D1 D2
[ 4.409049] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 4.419512] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 4.420034] pci 0004:00:00.0: BAR 15: assigned [mem 0x1400000000-0x14000fffff 64bit pref]
[ 4.420400] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 4.420640] pci 0004:01:00.0: BAR 4: assigned [mem 0x1400000000-0x1400003fff 64bit pref]
[ 4.427257] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x1740000fff 64bit]
[ 4.435256] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 4.441132] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 4.446398] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 4.452595] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 4.459791] pci 0004:00:00.0: bridge window [mem 0x1400000000-0x14000fffff 64bit pref]
[ 4.468009] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 4.476349] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 4.486832] pcieport 0004:00:00.0: Adding to iommu group 6
[ 4.491584] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[ 4.497724] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[ 4.504286] tegra194-pcie 141a0000.pcie: Adding to iommu group 7
[ 4.513617] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 4.514801] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 4.523093] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 4.531504] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 5.648482] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 5.649302] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 5.649603] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 5.649755] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 5.650066] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 5.650263] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 5.650614] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 5.651070] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.667757] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 5.668254] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.670129] pcieport 0005:00:00.0: Adding to iommu group 7
[ 5.671350] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[ 5.673099] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[ 5.674521] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 5.675307] pci 0005:00:00.0: Removing from iommu group 7
[ 5.675561] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 5.705547] host1x 13e10000.host1x: Adding to iommu group 8
[ 5.726710] host1x 13e10000.host1x: initialized
[ 5.728098] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 9
[ 5.728921] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 5.729939] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 10
[ 5.730536] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 5.731415] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 11
[ 5.732076] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 5.733019] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 12
[ 5.733584] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 5.741833] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 13
[ 5.748582] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.758495] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 14
[ 5.765502] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 5.775515] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 15
[ 5.782296] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 5.792295] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 16
[ 5.799478] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 5.809271] falcon 15340000.vic: Adding to iommu group 17
[ 5.822912] falcon 15340000.vic: initialized
[ 5.823703] falcon 15380000.nvjpg: Adding to iommu group 17
[ 5.829504] falcon 15380000.nvjpg: initialized
[ 5.830118] falcon 154c0000.nvenc: Adding to iommu group 17
[ 5.842214] falcon 154c0000.nvenc: initialized
[ 5.842795] falcon 15a80000.nvenc1: Adding to iommu group 17
[ 5.852452] falcon 15a80000.nvenc1: initialized
[ 5.853076] nvdec 15480000.nvdec: Adding to iommu group 17
[ 5.864883] nvdec 15480000.nvdec: initialized
[ 5.865496] nvdec 15140000.nvdec1: Adding to iommu group 17
[ 5.874488] nvdec 15140000.nvdec1: initialized
[ 5.875048] tsec 15500000.tsec: Adding to iommu group 18
[ 5.880085] tsec 15500000.tsec: initialized
[ 5.880531] tsec 15100000.tsecb: Adding to iommu group 19
[ 5.889671] tsec 15100000.tsecb: initialized
[ 5.895243] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 5.923328] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 5.936871] gpio-374 (wifi-enable): hogged as output/high
[ 5.937279] gpio-431 (camera-control-output-low): hogged as output/low
[ 5.937563] gpio-432 (camera-control-output-low): hogged as output/low
[ 5.939236] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 5.941065] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 5.941601] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 5.943206] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 5.945833] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 5.952090] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 5.957572] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 5.965812] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 5.973089] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 20
[ 5.984184] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 5.989685] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 5.995588] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 6.004404] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 6.013994] tegra194-vi5 15c10000.vi: Adding to iommu group 21
[ 6.020763] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.028378] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 6.034703] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.044583] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 6.051071] pva 16000000.pva0: Adding to iommu group 22
[ 6.077085] pva 16000000.pva0: initialized
[ 6.083546] pva 16800000.pva1: Adding to iommu group 23
[ 6.095569] pva 16800000.pva1: initialized
[ 6.099836] nvdla 15880000.nvdla0: Adding to iommu group 24
[ 6.112490] nvdla 15880000.nvdla0: initialized
[ 6.113878] nvdla 158c0000.nvdla1: Adding to iommu group 25
[ 6.122074] nvdla 158c0000.nvdla1: initialized
[ 6.125205] tegradc 15200000.display: Adding to iommu group 26
[ 6.127064] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=62
[ 6.127338] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 6.127899] tegradccommon 15200000.display-hub: host1x channel mapped
[ 6.128420] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 6.128833] tegradccommon 15200000.display-hub: dma mapping done
[ 6.129089] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 6.134337] tegradc 15200000.display: disp0 connected to head0->sor1
[ 6.134681] tegradc 15210000.display: Adding to iommu group 26
[ 6.135250] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 6.135259] tegra_cec 3960000.tegra_cec: probed
[ 6.136011] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[ 6.136265] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 6.141413] generic_infoframe_type: 0x87
[ 6.142873] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 6.143286] kfuse 3830000.kfuse: initialized
[ 6.143688] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.143694] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.144259] serial-tegra 3100000.serial: Adding to iommu group 2
[ 6.152385] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[ 6.157066] tegradc 15200000.display: DT parsed successfully
[ 6.163542] serial-tegra 3110000.serial: Adding to iommu group 2
[ 6.168551] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 6.183589] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[ 6.193526] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 6.197598] serial-tegra 3140000.serial: Adding to iommu group 2
[ 6.202835] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 6.202848] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 6.223074] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[ 6.231733] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 6.285215] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 6.292027] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[ 6.292989] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 6.300756] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.300851] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.315805] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[ 6.318283] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 6.325375] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[ 6.332169] tegra-xusb 3610000.xhci: irq 187, io mem 0x03610000
[ 6.343693] tegradc 15210000.display: disp0 connected to head1->sor
[ 6.349210] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.354627] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 6.360450] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.360477] usb usb1: Product: xHCI Host Controller
[ 6.368915] tegradc 15210000.display: DT parsed successfully
[ 6.376015] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 6.383304] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 6.388172] usb usb1: SerialNumber: 3610000.xhci
[ 6.389494] hub 1-0:1.0: USB hub found
[ 6.416533] hub 1-0:1.0: 4 ports detected
[ 6.421042] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.426092] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.433437] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.441027] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.449409] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.456514] usb usb2: Product: xHCI Host Controller
[ 6.461120] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 6.467246] usb usb2: SerialNumber: 3610000.xhci
[ 6.473728] hub 2-0:1.0: USB hub found
[ 6.476282] hub 2-0:1.0: 4 ports detected
[ 6.517492] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 6.523716] i2c i2c-2: Added multiplexed i2c bus 9
[ 6.525308] i2c i2c-2: Added multiplexed i2c bus 10
[ 6.525488] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 6.539685] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1906000 KHz, changing to: 1907200 KHz
[ 6.540770] tegra194-cpufreq ccplex: probed with BWMGR, cl:4
[ 6.541918] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 6.542323] irq: IRQ261: trimming hierarchy from :pmc@c360000
[ 6.542852] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[ 6.544115] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 6.550760] tegra194-vi5 15c10000.vi: initialized
[ 6.552128] tegradc 15200000.display: disp0 connected to head0->sor1
[ 6.553286] mmc0: CQHCI version 5.10
[ 6.553516] nvethernet 2490000.ethernet: Adding to iommu group 27
[ 6.553815] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 6.553821] nvethernet 2490000.ethernet: failed to read MDIO address
[ 6.553828] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 6.553832] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 6.553836] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 6.553848] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 6.553868] nvethernet 2490000.ethernet: Failed to read DMA Rx ring size, using default [1024]
[ 6.553890] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 6.553894] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 6.556605] generic_infoframe_type: 0x87
[ 6.556692] tegradc 15200000.display: DT parsed successfully
[ 6.589279] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 6.594415] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 6.661521] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 6.668855] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 6.677248] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 6.683932] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 6.685996] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[ 6.694637] mmc0: Command Queue Engine enabled
[ 6.698760] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[ 6.698949] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 6.702963] mmc0: periodic cache flush enabled
[ 6.702976] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 6.710754] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 6.721105] mmcblk0: mmc0:0001 DG4064 59.2 GiB
[ 6.724921] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 6.727340] tegradc 15200000.display: probed
[ 6.731471] mmcblk0rpmb: mmc0:0001 DG4064 partition 3 4.00 MiB, chardev (509:0)
[ 6.775599] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[ 6.790024] Console: switching to colour frame buffer device 240x67
[ 6.790306] tegradc 15200000.display: fb registered
[ 6.790513] irq: IRQ262: trimming hierarchy from :pmc@c360000
[ 6.791709] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 6.794985] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 6.796000] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 6.807187] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 6.813865] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 6.821867] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:76:23:8c
[ 6.828540] -->macsec_probe()
[ 6.828546] <--macsec_probe()
[ 6.828553] nvethernet 2490000.ethernet: Macsec not supported/Not enabled in DT
[ 6.836598] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 6.845152] irq: IRQ264: trimming hierarchy from :pmc@c360000
[ 6.848948] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.01
[ 6.849347] irq: IRQ265: trimming hierarchy from :interrupt-controller@3881000
[ 6.857607] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.864329] tegradc 15200000.display: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 6.865110] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 6.865510] tegradc 15200000.display: hdmi: get RGB quant from REG programmed by BL.
[ 6.865518] tegradc 15200000.display: hdmi: get YCC quant from REG programmed by BL.
[ 6.866150] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 6.866154] Extcon AUX1(HDMI) enable
[ 6.866285] tegradc 15210000.display: disp1 connected to head1->sor
[ 6.866302] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 6.866352] tegradc 15210000.display: DT parsed successfully
[ 6.866387] tegradc 15210000.display: Display dc.(____ptrval____) registered with id=1
[ 6.866522] tegradc 15210000.display: vblank syncpt # 13 for dc 1
[ 6.866527] tegradc 15210000.display: vpulse3 syncpt # 14 for dc 1
[ 6.872546] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 6.873172] tegradc 15210000.display: probed
[ 6.882107] tegra-se-nvhost 15810000.se: Adding to iommu group 28
[ 6.887848] usb 1-2: Manufacturer: Generic
[ 6.889434] hub 1-2:1.0: USB hub found
[ 6.897127] tegra-se-nvhost 15810000.se: initialized
[ 6.903768] hub 1-2:1.0: 4 ports detected
[ 6.912129] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 6.969286] usb 2-3: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[ 6.999954] tegradc 15210000.display: fb registered
[ 7.000157] tegra-se-nvhost 15820000.se: Adding to iommu group 29
[ 7.008694] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 2
[ 7.011750] tegra-se-nvhost 15820000.se: initialized
[ 7.019384] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 1
[ 7.024379] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.031118] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 0
[ 7.036226] tegra-se-nvhost 15830000.se: Adding to iommu group 30
[ 7.042799] usb 2-3: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.01
[ 7.044255] tegradc 15210000.display: dp: aux write got error (0x10000100)
[ 7.044262] tegradc 15210000.display: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[ 7.048887] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 7.049543] tegra-se-nvhost 15830000.se: initialized
[ 7.050622] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 7.051124] tegra-se-nvhost 15840000.se: Adding to iommu group 31
[ 7.051743] tegra-se-nvhost 15840000.se: initialized
[ 7.053240] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 7.054557] tegra_actmon d230000.actmon: in actmon_register()...
[ 7.054723] tegra_actmon d230000.actmon: bwmgr_disable = 0
[ 7.055209] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 7.055478] hvc_sysfs: hypervisor is not present
[ 7.056816] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.056821] usb 2-3: Product: 4-Port USB 3.1 Hub
[ 7.056851] usb 2-3: Manufacturer: Generic
[ 7.080696] ALSA device list:
[ 7.085617] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 2
[ 7.089396] hub 2-3:1.0: USB hub found
[ 7.089564] No soundcards found.
[ 7.090475] hub 2-3:1.0: 4 ports detected
[ 7.097235] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 1
[ 7.167920] tegra_cec 3960000.tegra_cec: physical address: 20:00.
[ 7.169720] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 0
[ 7.188591] tegradc 15200000.display: blank - powerdown
[ 7.189998] tegradc 15210000.display: dp: aux write got error (0x10000100)
[ 7.190005] tegradc 15210000.display: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 7.190673] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 2
[ 7.192152] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 1
[ 7.193629] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 0
[ 7.195106] tegradc 15210000.display: dp: aux write got error (0x10000100)
[ 7.195110] tegradc 15210000.display: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 7.195779] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 2
[ 7.197270] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 1
[ 7.198755] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 0
[ 7.200236] tegradc 15210000.display: dp: aux write got error (0x10000100)
[ 7.200241] tegradc 15210000.display: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 7.200910] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 2
[ 7.202389] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 1
[ 7.203867] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 0
[ 7.205370] tegradc 15210000.display: dp: aux write got error (0x10000100)
[ 7.205398] tegradc 15210000.display: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 7.205402] tegradc 15210000.display: dp: failed to exit panel power save mode (0xfffffff2)
[ 7.205443] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[ 7.205447] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[ 7.231519] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 7.231525] Extcon AUX1(HDMI) disable
[ 7.232481] tegra_cec 3960000.tegra_cec: Sent <Text View On> res: -113.
[ 7.232486] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 7.267651] tegradc 15200000.display: unblank
[ 7.272744] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 7.274572] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 7.275919] usb 1-2.1: new low-speed USB device number 3 using tegra-xusb
[ 7.278619] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 7.278622] Extcon AUX1(HDMI) enable
[ 7.291350] tegradc 15200000.display: sync windows ret = 247
[ 7.307955] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 7.380044] usb 1-2.1: New USB device found, idVendor=413c, idProduct=301a, bcdDevice= 1.00
[ 7.380935] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 7.385312] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.385318] usb 1-2.1: Product: Dell MS116 USB Optical Mouse
[ 7.385322] usb 1-2.1: Manufacturer: PixArt
[ 7.388923] input: PixArt Dell MS116 USB Optical Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:413C:301A.0001/input/input1
[ 7.399919] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 7.401231] hid-generic 0003:413C:301A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-3610000.xhci-2.1/input0
[ 7.408401] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 2
[ 7.495928] usb 1-2.2: new low-speed USB device number 4 using tegra-xusb
[ 7.503517] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 1
[ 7.516093] extcon-disp-state external-connection:disp-state: cable 53 state 1
[ 7.517050] Freeing unused kernel memory: 3968K
[ 7.517456] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 0
[ 7.518934] tegradc 15210000.display: dp: aux write got error (0x10000100)
[ 7.518940] tegradc 15210000.display: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 7.519629] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 2
[ 7.521109] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 1
[ 7.522608] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 0
[ 7.523292] Extcon HDMI: HPD enabled
[ 7.523299] tegradc 15200000.display: hdmi: plugged
[ 7.524087] tegradc 15210000.display: dp: aux write got error (0x10000100)
[ 7.528016] Run /init as init process
[ 7.534762] tegradc 15210000.display: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 7.541840] with arguments:
[ 7.541843] /init
[ 7.541845] nv-auto-config
[ 7.541852] with environment:
[ 7.551453] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 2
[ 7.557589] HOME=/
[ 7.557611] TERM=linux
[ 7.608476] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 1
[ 7.614462] usb 1-2.2: New USB device found, idVendor=413c, idProduct=2113, bcdDevice=33.08
[ 7.615341] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 0
[ 7.622023] usb 1-2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 7.630528] tegradc 15210000.display: dp: aux write got error (0x10000100)
[ 7.636530] usb 1-2.2: Product: Dell KB216 Wired Keyboard
[ 7.643447] tegradc 15210000.display: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 7.655833] input: Dell KB216 Wired Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:413C:2113.0002/input/input2
[ 7.658338] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 2
[ 7.660382] Root device found: mmcblk0p1
[ 7.682054] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 1
[ 7.689384] tegradc 15210000.display: dp: aux write retry (0x10000100) -- 0
[ 7.696199] tegradc 15210000.display: dp: aux write got error (0x10000100)
[ 7.696206] tegradc 15210000.display: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 7.696210] tegradc 15210000.display: dp: failed to exit panel power save mode (0xfffffff2)
[ 7.696215] hpd: edid read prepare failed
[ 7.696218] hpd: DC from connected to disconnected
[ 7.728217] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3610000.xhci-2.2/input0
[ 7.732556] Found dev node: /dev/mmcblk0p1
[ 7.744672] input: Dell KB216 Wired Keyboard System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:413C:2113.0003/input/input3
[ 7.780754] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.791184] Rootfs mounted over mmcblk0p1
[ 7.816225] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:413C:2113.0003/input/input4
[ 7.818389] hid-generic 0003:413C:2113.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3610000.xhci-2.2/input1
[ 7.823649] Switching from initrd to actual rootfs
[ 7.972470] systemd[1]: System time before build time, advancing clock.
[ 8.304593] systemd[1]: systemd 245.4-4ubuntu3.21 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 8.310542] systemd[1]: Detected architecture arm64.
[ 8.351061] systemd[1]: No hostname configured.
[ 8.352758] systemd[1]: Set hostname to <localhost>.
[ 8.703940] tegradc 15210000.display: sync_windows timeout
[ 8.707855] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 8.709606] tegradc 15210000.display: blank - powerdown
[ 8.712809] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 8.714513] Extcon DP: HPD disabled
[ 8.716404] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[ 9.060811] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.062844] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 9.064748] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 9.070844] systemd[1]: Created slice system-modprobe.slice.
[ 9.075366] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.077769] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.081355] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.083079] systemd[1]: Reached target Slices.
[ 9.086696] systemd[1]: Reached target Swap.
[ 9.090943] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 9.094891] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.098700] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.103288] systemd[1]: Listening on Journal Audit Socket.
[ 9.107324] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.111425] systemd[1]: Listening on Journal Socket.
[ 9.115454] systemd[1]: Listening on udev Control Socket.
[ 9.119299] systemd[1]: Listening on udev Kernel Socket.
[ 9.127569] systemd[1]: Mounting Huge Pages File System...
[ 9.136320] systemd[1]: Mounting POSIX Message Queue File System...
[ 9.147060] systemd[1]: Mounting Kernel Debug File System...
[ 9.155929] systemd[1]: Mounting Kernel Trace File System...
[ 9.166170] systemd[1]: Starting Journal Service...
[ 9.174695] systemd[1]: Starting Set the console keyboard layout...
[ 9.183260] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 9.191561] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 9.200203] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 9.208581] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 9.216413] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 9.224875] systemd[1]: Starting Load Kernel Module ramoops...
[ 9.232719] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 9.240105] systemd[1]: Started Nameserver information manager.
[ 9.251574] systemd[1]: Reached target Network (Pre).
[ 9.268670] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 9.271762] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 9.280555] systemd[1]: Starting Load Kernel Modules...
[ 9.288349] random: crng init done
[ 9.289849] random: 27 urandom warning(s) missed due to ratelimiting
[ 9.291781] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 9.299075] systemd[1]: Starting udev Coldplug all Devices...
[ 9.339847] systemd[1]: Mounted Huge Pages File System.
[ 9.349980] systemd[1]: Mounted POSIX Message Queue File System.
[ 9.353977] systemd[1]: Mounted Kernel Debug File System.
[ 9.357478] systemd[1]: Mounted Kernel Trace File System.
[ 9.357499] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 9.371532] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 9.373621] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 9.378351] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[ 9.380700] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 9.381026] nvmap_page_pool_init: Total RAM pages: 3813691
[ 9.381030] nvmap_page_pool_init: nvmap page pool size: 476711 pages (1862 MB)
[ 9.387589] nvmap_background_zero_thread: PP zeroing thread starting.
[ 9.388178] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[ 9.391271] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 9.392530] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 9.392768] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 9.396481] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 9.400924] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 9.404533] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 9.408828] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 9.414085] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 9.418747] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 9.422881] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 9.427510] systemd[1]: modprobe@ramoops.service: Succeeded.
[ 9.431912] systemd[1]: Finished Load Kernel Module ramoops.
[ 9.441361] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 9.455257] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 9.457575] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 9.463663] systemd[1]: Starting Load/Save Random Seed...
[ 9.472020] systemd[1]: Starting Create System Users...
[ 9.480063] systemd[1]: Finished Set the console keyboard layout.
[ 9.518586] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 9.539180] systemd[1]: Finished Load/Save Random Seed.
[ 9.554053] systemd[1]: Finished Load Kernel Modules.
[ 9.559260] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 9.566219] systemd[1]: Mounting Kernel Configuration File System...
[ 9.574101] systemd[1]: Started OP-TEE Client Supplicant.
[ 9.582191] systemd[1]: Starting Apply Kernel Variables...
[ 9.590599] systemd[1]: nvfb-udev.service: Succeeded.
[ 9.595586] systemd[1]: Finished NVIDIA specific first-boot udev script.
[ 9.599704] systemd[1]: Mounted Kernel Configuration File System.
[ 9.662901] systemd[1]: Finished Apply Kernel Variables.
[ 9.681603] systemd[1]: Finished Create System Users.
[ 9.689700] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 9.765864] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 9.768962] systemd[1]: Started Journal Service.
[ 9.826978] systemd-journald[261]: Received client request to flush runtime journal.
[ 11.086464] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 11.185609] spi-tegra114 3230000.spi: Adding to iommu group 2
[ 11.256385] tegra-hda 3510000.hda: Adding to iommu group 32
[ 11.257487] tegra-hda 3510000.hda: Override SDO lines to 4
[ 11.281204] r8168 0004:01:00.0: Adding to iommu group 6
[ 11.281548] r8168 Gigabit Ethernet driver 8.051.02-NAPI loaded
[ 11.281652] r8168 0004:01:00.0: enabling device (0000 -> 0003)
[ 11.295208] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 11.309135] cpu-throttle-alert cooling device registered.
[ 11.309650] gpu-throttle-alert cooling device registered.
[ 11.310036] aux-throttle-alert cooling device registered.
[ 11.310431] hot-surface-alert cooling device registered.
[ 11.366108] nvadsp 2993000.adsp: Adding to iommu group 33
[ 11.366310] nvadsp 2993000.adsp: in probe()...
[ 11.375609] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 11.376807] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 11.393865] r8168 0004:01:00.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[ 11.414066] tegra-i2c 3180000.i2c: I2C transfer timed out
[ 11.417643] imx219 9-0010: imx219_board_setup: error during i2c read probe (-110)
[ 11.424941] imx219 9-0010: board setup failed
[ 11.426752] imx219: probe of 9-0010 failed with error -110
[ 11.428194] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input5
[ 11.431550] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input6
[ 11.432078] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input7
[ 11.432328] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input8
[ 11.433316] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 11.435819] r8168 0004:01:00.0 (unnamed net_device) (uninitialized): Random ether addr de:1b:12:0f:66:b1
[ 11.436559] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 11.443773] r8168 Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 11.548003] tegra-i2c 3180000.i2c: I2C transfer timed out
[ 11.550333] imx219 10-0010: imx219_board_setup: error during i2c read probe (-110)
[ 11.556921] imx219 10-0010: board setup failed
[ 11.558310] imx219: probe of 10-0010 failed with error -110
[ 11.564971] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 33
[ 11.565021] tegra210_adsp_audio_probe: platform probe started
[ 11.566851] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 11.568545] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 11.578283] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 11.581169] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 11.583587] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 11.585317] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 11.585330] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 11.585335] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 11.585447] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 11.642126] tegra-asoc: sound: Adding to iommu group 33
[ 11.940616] tegra210-adsp tegra210-adsp: Loaded app wire
[ 11.940632] tegra210-adsp tegra210-adsp: Loaded app apm
[ 11.940640] tegra210-adsp tegra210-adsp: Loaded app adma
[ 11.940647] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 11.940654] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000b53a243d
[ 11.960104] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 12.031759] cryptd: max_cpu_qlen set to 1000
[ 12.719538] using random self ethernet address
[ 12.721546] using random host ethernet address
[ 12.800304] FAN rising trip_level:1 cur_temp:50200 trip_temps[2]:63000
[ 13.253099] loop: module loaded
[ 13.706050] Mass Storage Function, version: 2009/09/11
[ 13.706063] LUN: removable file: (no medium)
[ 13.715822] using random self ethernet address
[ 13.717452] using random host ethernet address
[ 13.732428] irq: IRQ268: trimming hierarchy from :interrupt-controller@3881000
[ 13.821965] rndis0: HOST MAC e2:77:9d:eb:1d:28
[ 13.821979] rndis0: MAC e2:77:9d:eb:1d:29
[ 13.822725] usb0: HOST MAC e2:77:9d:eb:1d:2a
[ 13.822732] usb0: MAC e2:77:9d:eb:1d:2b
[ 13.825119] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 13.856036] l4tbr0: port 1(rndis0) entered blocking state
[ 13.856071] l4tbr0: port 1(rndis0) entered disabled state
[ 13.856623] device rndis0 entered promiscuous mode
[ 13.909947] eth1: 0xffff800010ef5000, ce:4c:60:f2:e2:24, IRQ 266
[ 13.972917] l4tbr0: port 2(usb0) entered blocking state
[ 13.972942] l4tbr0: port 2(usb0) entered disabled state
[ 13.973441] device usb0 entered promiscuous mode
[ 14.061257] IRQ266: set affinity failed(-22).
[ 14.063191] CPU4: shutdown
[ 14.064652] psci: CPU4 killed (polled 0 ms)
[ 14.113200] IRQ266: set affinity failed(-22).
[ 14.113389] CPU5: shutdown
[ 14.114683] psci: CPU5 killed (polled 0 ms)
[ 14.209110] nvgpu: 17000000.gv11b gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 15.534549] nvethernet 2490000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 15.534602] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 23.979360] tegradc 15200000.display: unblank
[ 23.979390] tegradc 15210000.display: blank - powerdown
[ 24.117542] nvidia: loading out-of-tree module taints kernel.
[ 24.130992] NVRM: No NVIDIA GPU found.
[ 26.707473] Please wait for auto system configuration setup to complete...
[ 26.945891] tegradc 15200000.display: blank - powerdown
[ 27.008212] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 27.008222] Extcon AUX1(HDMI) disable
[ 27.031774] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 27.032688] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 27.032794] tegradc 15210000.display: blank - powerdown
[ 27.045957] tegradc 15200000.display: blank - powerdown
[ 27.046080] tegradc 15200000.display: unblank
[ 27.047251] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 27.047454] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 27.054432] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 27.056117] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 27.060549] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 27.060554] Extcon AUX1(HDMI) enable
[ 27.072891] tegradc 15200000.display: sync windows ret = 247
[ 31.508133] tegradc 15200000.display: unblank
[ 31.508165] tegradc 15210000.display: blank - powerdown
[ 31.610741] NVRM: No NVIDIA GPU found.
[ 33.664371] fuse: init (API version 7.32)
[ 35.153522] NVRM: No NVIDIA GPU found.
[ 37.855967] vdd-1v8-sd: disabling
[ 37.855978] vdd-3v3-cvb: disabling
[ 37.855984] vdd-1v8-cvb: disabling
[ 37.855989] vdd-epb-1v0: disabling
[ 37.855994] vdd-fan: disabling
[ 37.856000] vdd_sys_en: disabling
[ 170.442604] tegradc 15200000.display: blank - powerdown
[ 170.506288] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 170.506293] Extcon AUX1(HDMI) disable
[ 170.529464] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 170.530290] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 170.530379] tegradc 15210000.display: blank - powerdown
[ 170.545539] tegradc 15200000.display: blank - powerdown
[ 170.545581] tegradc 15200000.display: unblank
[ 170.546671] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 170.546868] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 170.553059] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 170.554550] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 170.558172] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 170.558177] Extcon AUX1(HDMI) enable
[ 170.571338] tegradc 15200000.display: sync windows ret = 247
[ 189.159625] tegra-xudc 3550000.xudc: ep 0 disabled
[ 189.218389] device usb0 left promiscuous mode
[ 189.218441] l4tbr0: port 2(usb0) entered disabled state
[ 189.478442] device rndis0 left promiscuous mode
[ 189.478473] l4tbr0: port 1(rndis0) entered disabled state
[ 196.293198] using random self ethernet address
[ 196.294812] using random host ethernet address
[ 197.289978] Mass Storage Function, version: 2009/09/11
[ 197.290002] LUN: removable file: (no medium)
[ 197.304785] using random self ethernet address
[ 197.306681] using random host ethernet address
[ 197.336486] rndis0: HOST MAC e2:77:9d:eb:1d:28
[ 197.336497] rndis0: MAC e2:77:9d:eb:1d:29
[ 197.351745] usb0: HOST MAC e2:77:9d:eb:1d:2a
[ 197.351755] usb0: MAC e2:77:9d:eb:1d:2b
[ 197.365064] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 197.476032] l4tbr0: port 1(rndis0) entered blocking state
[ 197.476077] l4tbr0: port 1(rndis0) entered disabled state
[ 197.488408] device rndis0 entered promiscuous mode
[ 197.621791] l4tbr0: port 2(usb0) entered blocking state
[ 197.621839] l4tbr0: port 2(usb0) entered disabled state
[ 197.623154] device usb0 entered promiscuous mode
[ 206.062381] nvgpu: 17000000.gv11b tpc_pg_mask_store:1070 [INFO] no value change, same mask already set
[ 206.068988] pstore: Using crash dump compression: deflate
[ 206.069097] printk: console [ramoops-1] enabled
[ 206.069107] pstore: Registered ramoops as persistent store backend
[ 206.069114] ramoops: using 0x200000@0xc8200000, ecc: 0
[ 206.453108] zram: Added device: zram0
[ 206.453464] zram: Added device: zram1
[ 206.453812] zram: Added device: zram2
[ 206.454159] zram: Added device: zram3
[ 206.613162] zram0: detected capacity change from 0 to 1952612352
[ 206.740206] Adding 1906844k swap on /dev/zram0. Priority:5 extents:1 across:1906844k SS
[ 206.750948] zram1: detected capacity change from 0 to 1952612352
[ 206.800226] Adding 1906844k swap on /dev/zram1. Priority:5 extents:1 across:1906844k SS
[ 206.806366] zram2: detected capacity change from 0 to 1952612352
[ 206.884596] Adding 1906844k swap on /dev/zram2. Priority:5 extents:1 across:1906844k SS
[ 206.910734] zram3: detected capacity change from 0 to 1952612352
[ 206.956044] Adding 1906844k swap on /dev/zram3. Priority:5 extents:1 across:1906844k SS
[ 207.617561] tegradc 15200000.display: unblank
[ 207.617593] tegradc 15210000.display: blank - powerdown
[ 207.768611] NVRM: No NVIDIA GPU found.
[ 233.700646] tegradc 15200000.display: blank - powerdown
[ 233.754823] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 233.754830] Extcon AUX1(HDMI) disable
[ 233.779455] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 233.780699] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 233.780813] tegradc 15210000.display: blank - powerdown
[ 234.024116] tegradc 15200000.display: blank - powerdown
[ 234.024147] tegradc 15200000.display: unblank
[ 234.031055] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 234.031568] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 234.040349] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 234.042644] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 234.046400] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 234.046406] Extcon AUX1(HDMI) enable
[ 234.046447] tegradc 15200000.display: unblank
[ 234.046481] tegradc 15210000.display: blank - powerdown
[ 234.210590] NVRM: No NVIDIA GPU found.
