Hello, @gtj
Thanks for sharing a good answer.
I was also looking for a way to boot xavier nx from usb stick using usb hub.
I know that it doesn’t work because of the cboot error you mentioned.
In the past, when using a USB stick only as an external storage device due to insufficient emmc capacity, when installing packages with apt-get, etc., it was continuously installed in emmc, and eventually emmc was full.
Using the method mentioned above
Even if you install packages with apt-get, etc., doesn’t emmc get full?
It’s because I don’t know how to install only the app partition in emmc.
May I ask for a guide or link to make it easy to follow?
Thank you.
