hello,
I want to display the pointCloud used pcl and vtk on qtdesigner ,how can I compile the pcl and vtk?
and I want to the version of pcl and vtk ,I has compiled the vtk,when I compiled the pcl ,the error that was
inernal error was occured,but I could compile the pcl alone successed.
Thank you!
What are the exact source code downloads you are using for the compile? What is the exact L4T version you are using (e.g., “head -n 1 /etc/nv_tegra_release”)?
hello,linuxdev
The exact L4T version is 3.1.
I solved the problem by trying a lot of ways,this error is caused by insufficient memory .
thank you !
Hi, lihuayang
Can you give me an explanation? I’m doing the same job, but I can’t find the Qt5UiPlugin file in qt on tx2 and can’t compile VTK.
thanks.
