Hi there,
I want to use the perf tool for some tests on my Jetson Xavier NX DevKit with JP5.0.1 installed (Ubuntu 20.04).
Problem and steps tried
I tried to install it through apt with sudo apt install linux-tools-common. When I then run the command with perf, I get the following message:
$ perf
WARNING: perf not found for kernel 5.10.65
You may need to install the following packages for this specific kernel:
linux-tools-5.10.65-tegra
linux-cloud-tools-5.10.65-tegra
You may also want to install one of the following packages to keep up to date:
linux-tools-tegra
linux-cloud-tools-tegra
When I try to install the recommended packages, I only get the message that the package could not be found:
$ sudo apt install linux-tools-5.10.65-tegra
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package linux-tools-5.10.65-tegra
E: Couldn't find any package by glob 'linux-tools-5.10.65-tegra'
So I tried to compile it from the kernel source after I found the following link. When I go the directory /usr/src/linux-headers-5.10.65-tegra-ubuntu20.04_aarch64/kernel-5.10/tools/perf and run sudo make I receive the following message and I am not sure how to proceed now:
$ sudo make
BUILD: Doing 'make -j6' parallel build
Makefile.perf:8: ../scripts/utilities.mak: No such file or directory
make[1]: *** No rule to make target '../scripts/utilities.mak'. Stop.
make: *** [Makefile:70: all] Error 2
My Question
What is the best way to get perf working on my setup?
Additional info:
$ uname -a
Linux xavier03 5.10.65-tegra #1 SMP PREEMPT Mon May 16 20:58:07 PDT 2022 aarch64 aarch64 aarch64 GNU/Linux
