HI:
How to configure pcie0 and pcie1 of TX2 to pcie? Currently there is a pcie which defaults to usb. I want to configure all pcie interfaces to pcie.
Please modify the ODMDATA to 0x90000 in p2771-0000.conf.common and reflash your board.
Wǒ bù xūyào xiūgǎi qítā de shèbèi shù wénjiàn ma
15/5000
Do I need to modify other device tree files
If you only want pcie0 and pcie1 then don’t need to modify device tree.
Which file to modify on the TX2i module?
Not on the TX2i module. This file is on your ubuntu host where you use to flash jetpack.
I modified the file TX2 of the host ubuntu to solve the configuration problem. But using the same method, the TX2i problem still exists
You can check current ODMDATA setting on TX2/TX2i by the node
/proc/device-tree/chosen/plugin-manager/odmdata
If the odmdata on TX2i is wrong, then check the p2771-0000.common.conf again. Your change probably didn’t take effect.
