This is on Jetpack 3.3
I am unsuccessfully trying to configure the USB lane mapping for configuration 1 on the TX2i. The main goal is to switch enable PCIe on PEX1. I was successfully able to follow the instructions in the following link to get the it working on the TX2.
[url]https://devtalk.nvidia.com/default/topic/1023160/jetson-tx2/tx2-using-pcix1-instead-of-usb3-default-config-1-/post/5208073/#5208073[/url]
Trying to follow this same process for the TX2i has not been successful. Below are the configuration changes I made to the device tree:
I set ODMDATA=0x90000 in p2771-0000.conf.common.
In tegra186-quill-p3489-1000-a00-plugin-manager.dtsi and tegra186-quill-p3489-1000-a00-00-base.dts set xhci@3530000 with
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>;
phy-names = “utmi-0”;
In tegra186-quill-p3489-1000-a00-00-base.dts set the status to disabled for usb2-std-A-port2 and usb3-std-A-port2
In tegra186-quill-common-p3489-1000-a00.dtsi enable pcie0_lane2_mux by setting the status to “okay”.
In tegra186-quill-power-tree-p3489-1000-a00-00.dtsi under pinctrl@3520000 set vbus-2-supply = <&battery_reg>;
comment out fragment-500-e3325-pcie in tegra186-quill-p3489-1000-a00-plugin-manager.dtsi
Am I missing something for the TX2i configuration? Could someone give me a step by step list of all the changes that need to be made in the device tree to enable configuration 1 on the tx2i?
I believe it is set in tegra186-quill-p3489-1000-a00-00-base.dts
pcie-controller@10003000 {
status = "okay";
pci@1,0 {
nvidia,num-lanes = <2>;
status = "okay";
pci@2,0 {
nvidia,num-lanes = <1>;
status = "disabled";
pci@3,0 {
nvidia,disable-clock-request;
status = "okay";
I added nvidia,disable-clock-request; to pci@3,0 as per the link you sent me and I still don’t get the PCIe card to show up on the TX2i like it does on the TX2.
looks like pci@3,0 is okay, but it is not showing the card.
nvidia@tegra-ubuntu:~$ xxd /proc/device-tree/pcie-controller@10003000/pci@3\,0/status
00000000: 6f6b 6179 00 okay.
I attached all the device tree files I edited if that helps.
p2771-0000.conf.common.txt (8.37 KB)
tegra186-quill-common-p3489-1000-a00.txt (2.53 KB)
tegra186-quill-p3489-1000-a00-00-base.txt (5.72 KB)
tegra186-quill-power-tree-p3489-1000-a00-00.txt (8.61 KB)
tegra186-quill-p3489-1000-a00-plugin-manager.txt (9.18 KB)
Please also modify below line in p2771-0000.conf.common
elif [ "${bid}" \= "3489" ]; then
<b>ODMDATA=0x90000;</b>
tofab="-a00";
pmicfab="-a00";
bpfdtbfab="-a00";
tbcdtbfab="-a00";
kerndtbfab="-a00";
if [ "${bdv}" \< "300" ]; then
bpfdtbfab="-evt";
fi
And check if you see enable-pcie-on-uphy-lane0 instead of enable-xusb-on-uphy-lane0
$ ls /proc/device-tree/chosen/plugin-manager/odm-data
That was the problem. Thank you!
