We have a TX2 carrier board with config4 setting.
After we modified dtb to config4, the PCIe#1_0 did not work.
Our pin mapping:
[USB1]
USB1_D (A38, A39)
USB_SS0 (F43, F44, C43, C44)
USB_SS0 connect to a USB hub and the hub connect to two USB type A port.
[USB2]
USB1_D (A38, A39)
USB_SS1 (G42, G43, D42, D43)
[PCIe#1_0]
Tx2 PEX2 connect to an ethernet convreter
Followed Jetson/TX2 USB - eLinux.org to modify ODMDATA to 0x7090000 to use config#4 USB lane mapping.
as we run lspci and PCIe#1_0 does not see any pci port.
Due to it connects to a etherent converter, pci poer should show data as we run lspci.
Could we missed any?
Thank you for any advice.
Modified hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts. as below.
xudc@3550000 {
status = "okay";
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(1)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(0)>;
phy-names = "usb2", "usb3";
xhci@3530000 {
status = "okay";
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(2)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(0)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(1)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(2)>;
phy-names = "utmi-0", "utmi-1", "utmi-2", "usb3-0", "usb3-1", "usb3-2";
pinctrl@3520000 {
status = "okay";
pinctrl-0 = <&tegra_xusb_padctl_pinmux_default>;
pinctrl-1 = <&vbus_en0_sfio_tristate_state>;
pinctrl-2 = <&vbus_en1_sfio_tristate_state>;
pinctrl-3 = <&vbus_en0_sfio_passthrough_state>;
pinctrl-4 = <&vbus_en1_sfio_passthrough_state>;
pinctrl-5 = <&vbus_en0_default_state>;
pinctrl-6 = <&vbus_en1_default_state>;
pinctrl-names = "default",
"vbus_en0_sfio_tristate", "vbus_en1_sfio_tristate",
"vbus_en0_sfio_passthrough", "vbus_en1_sfio_passthrough",
"vbus_en0_default", "vbus_en1_default";
tegra_xusb_padctl_pinmux_default: pinmux {
/* Quill does not support usb3-micro AB */
usb2-micro-AB {
nvidia,lanes = "otg-0";
nvidia,function = "xusb";
nvidia,port-cap = <TEGRA_PADCTL_PORT_OTG_CAP>;
status = "okay";
usb2-micro-AB {
status = "okay";
usb2-std-A-port2 {
nvidia,lanes = "otg-1";
nvidia,port-cap = <TEGRA_PADCTL_PORT_HOST_ONLY>;
status = "okay";
usb3-std-A-port2 {
nvidia,lanes = "usb3-0";
status = "okay";
usb3-std-A-port3 {
nvidia,lanes = "usb3-2";
status = "okay";
usb3-std-A-port4 {
nvidia,lanes = "usb3-1";
status = "okay";
pcie-controller@10003000 {
status = "okay";
pci@1,0 {
nvidia,num-lanes = <2>;
nvidia,disable-clock-request;
status = "okay";
pci@2,0 {
nvidia,num-lanes = <1>;
status = "okay";
pci@3,0 {
status = "disabled";
attached the log
tx2_conf4_usb-1.txt (83.9 KB)
