I have 2 PCIe on my custom board and need it to works as config 6 on table 1 from Platform
Adaptation and Bring-Up Guide.
I was set ODMDATA = 0x03090000 and changed tegra186-quill-p3310-1000-c03-00-base.dts PCI part to:
pcie-controller@10003000 {
pci@1,0 {
nvidia,num-lanes = <2>;
nvidia,disable-clock-request;
pci@2,0 {
nvidia,num-lanes = <0>;
pci@3,0 {
nvidia,num-lanes = <1>;
But the dmesg says the kernel is trying to configure PCI0 as 4 lanes:
[ 0.461434] iommu: Adding device 10003000.pcie-controller to group 48
[ 0.461456] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 1.033926] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 1.035091] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 1.035505] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 1.038915] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 1.149899] ehci-pci: EHCI PCI platform driver
[ 1.149964] ohci-pci: OHCI PCI platform driver
[ 1.470434] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.883211] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.289937] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.291965] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.696682] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.103363] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.518454] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.520513] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.725015] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.725323] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
The plugin-manager is disabled from DT.
I’v extracted the DT from /proc/device-tree and I’m sharing it here.
Here can I modify the num-lanes to the correct value?
Is there anything else I have to do to put these PCI to work?
device-tree.dts.txt (461 KB)
Hi Wayne, the file I sent was extracted from /proc/device-tree, so I believe it’s have the information needed, and for pcie-controller@10003000 it’s show:
pci@2,0 {
nvidia,afi-ctl-offset = <0x118>;
assigned-addresses = <0x82001000 0x0 0x10001000 0x0 0x1000>;
device_type = "pci";
nvidia,num-lanes = <0x0>;
ranges;
status = "disabled";
#address-cells = <0x3>;
#size-cells = <0x2>;
reg = <0x1000 0x0 0x0 0x0 0x0>;
nvidia,disable-aspm-states = <0xf>;
pci@1,0 {
nvidia,afi-ctl-offset = <0x110>;
assigned-addresses = <0x82000800 0x0 0x10000000 0x0 0x1000>;
nvidia,num-lanes = <0x4>;
ranges;
status = "okay";
reg = <0x800 0x0 0x0 0x0 0x0>;
pci@3,0 {
nvidia,afi-ctl-offset = <0x19c>;
assigned-addresses = <0x82001800 0x0 0x10004000 0x0 0x1000>;
nvidia,num-lanes = <0x1>;
ranges;
status = "okay";
reg = <0x1800 0x0 0x0 0x0 0x0>;
But on my tegra186-quill-p3310-1000-c03-00-base.dts it is:
pci@1,0 {
pci@2,0 {
pci@3,0 {
So, what is wrong?
I’ll take a look on bootloader logs.
For such case, I think you should check bootloader log for plugin-manager.
kayccc
November 7, 2019, 1:45am
#5
Hi alfredosalvarani,
Have you managed to get issue resolved?
Any result can be shared?
Yes.
The plugin manager was modifying my settings and there was an error in the hardware RX / TX lines, we fixed it and added it to the Device Tree:
pci@1,0 {
pci@2,0 {
status = "okay";
pci@3,0 {
plugin-manager {
/delete-node/ fragment-500-pcie-config;
In addition, we found that our actual configuration (because of the USB 3.0 hardware connection) should be 4 in Table 1 of the “Platform Adaptation and Bring-Up Guide”. So I changed the ODMDATA to 0x7090000 and now I have 3 USB3.0 ports (only 2 connected), 2 USB2.0 ports and 2 PCIE (1 line) working on my custom board.
kayccc
November 14, 2019, 3:17am
#7
Great! Glad to know issue resolved, thanks for the sharing!
