PCIe-USB LANE MAPPING
We’re using Config#5
Could you verify whether the following DT entries are correct? When I check the PCIe stat I see that it’s using x1 not x2. Any help is appreciated.
Thanks,
Hakim
pcie-controller@10003000 {
status = “okay”;
pci@1,0 {
nvidia,num-lanes = <1>;
status = “okay”;
pci@2,0 {
status = “okay”;
pci@3,0 {
nvidia,num-lanes = <2>;
status = “okay”;
Please refer to this thread
[url]https://devtalk.nvidia.com/default/topic/1002494/jetson-tx2/usb-lane-mapping/post/5180828/#5180828[/url]
Beside device tree, you also need to modify ODMDATA and cfg files.
r28.1 https://developer.nvidia.com/embedded/dlc/l4t-documentation-28-1
Sorry, I did not provide all info.
I’m using 28.1RC and will port to 28.1 release. I followed the platform adaptation and bring up guide and don’t see any changes between 27.1 and 28.1.
I see cfg files are already changed in 28.1RC from 27.1.
I’ve made changes entries for USB in DT and ODMDATA is set as ODMDATA=0x2090000; I’ve all USB working properly. I also find all PCIe working but I don’t get the extra lane that the config#5 should provide.
I’ve a few questions
Does PCIe DT entries look correct? I don’t see info about these in the guide.
What else do I need in cfg files?
Is config#5 verified?
Should I try these in 28.1 release?
Following is DT entries for USB
xudc@3550000 {
status = “okay”;
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>;
phy-names = “usb2”;
/dvdd-pex-supply = <&spmic_ldo8>;
dvdd-pex-pll-supply = <&spmic_ldo8>;
xhci@3530000 {
	status = "okay";
	phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>,
		<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(1)>,
		<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(2)>,
		<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(1)>;
	phy-names = "utmi-0", "utmi-1", "utmi-2", "usb3-1";
pinctrl@3520000 {
	status = "okay";
	vbus-2-supply = <&battery_reg>;
/*dvdd_pex-supply = <&spmic_ldo8>;*/
	pinctrl-0 = <&tegra_xusb_padctl_pinmux_default>;
	/*pinctrl-1 = <&vbus_en0_sfio_tristate_state>;
	pinctrl-2 = <&vbus_en1_sfio_tristate_state>;
	pinctrl-3 = <&vbus_en0_sfio_passthrough_state>;
	pinctrl-4 = <&vbus_en1_sfio_passthrough_state>;
	pinctrl-5 = <&vbus_en0_default_state>;
	pinctrl-6 = <&vbus_en1_default_state>;*/
	pinctrl-names = "default",
		"vbus_en0_sfio_tristate", "vbus_en1_sfio_tristate",
		"vbus_en0_sfio_passthrough", "vbus_en1_sfio_passthrough",
		"vbus_en0_default", "vbus_en1_default";
	tegra_xusb_padctl_pinmux_default: pinmux {
		/* Quill does not support usb3-micro AB */
		usb2-micro-AB {
			nvidia,lanes = "otg-0";
			nvidia,function = "xusb";
			nvidia,port-cap = <TEGRA_PADCTL_PORT_OTG_CAP>;
			nvidia,oc-pin = <0>;
			status = "okay";
		usb2-std-A-port2 {
			nvidia,lanes = "otg-1";
			nvidia,port-cap = <TEGRA_PADCTL_PORT_HOST_ONLY>;
			nvidia,oc-pin = <1>;
			status = "okay";
		e3325-usb3-std-A-HS {
			nvidia,lanes = "otg-2";
			status = "okay";
		usb3-std-A-port2 {
			nvidia,lanes = "usb3-0";
    status = "disabled";
		e3325-usb3-std-A-SS {
			nvidia,lanes = "usb3-1";
			status = "okay";
Hi hj-ca,
So PCIe#0_0, PCIe#0_1 and PCIe#1_0 work but PCIe#2_0 does not work?
Please also share info via devmem2
[url]USB Lane Mapping - Jetson TX2 - NVIDIA Developer Forums
We’ve been able to see PCIe#0_0 and PCIe#2_0.
The device on PCIe#0_0 is x2 and should be connecting to both PCIe#0_0 and PCIe#0_1
We got it working in 28.1 Release using the following DT,
status = “okay”;
pci@1,0 {
status = “okay”;
pci@2,0 {
status = “okay”;
pci@3,0 {
status = “okay”;
A little more information in the guide for these entries would have been helpful.
Looks like nvidia,num-lanes has to be correctly configured. Will check to improve the documentary.
