How to configure renderer when using ROS camera
I am using a headless Isaac Sim container to render a simulation and publish RGB images via ROS2.
I am basically following this page to use an action graph for publishing ROS messages: 7.2.3. ROS2 Cameras β€” Omniverse IsaacSim latest documentation
So far I have not found a way to configure the renderer settings using this approach. A simple example: I want the images to be rendered by path tracing instead of the default realtime renderer. How would I approach this, preferably programmatically via Python?
Thanks for any help
Bruno
@bruno.vetter i wonder if this is relevant in your situation?
Looks promising, thanks I will try.
