is there any reason you don’t want to use the pre-built SD card image?
For that case, you may try QEMU+chroot to install packages into the rootfs before flashing it to your device.
(Run all of the following commands with sudo privilege.)
Run these commands to prepare for the environment:
mount --bind /dev Linux_for_Tegra/rootfs/dev
mount --bind /dev/pts Linux_for_Tegra/rootfs/dev/pts
mount --bind /proc Linux_for_Tegra/rootfs/proc
mount --bind /sys Linux_for_Tegra/rootfs/sys
cp /etc/resolv.conf Linux_for_Tegra/rootfs/etc/resolv.conf
cp /usr/bin/qemu-aarch64-static Linux_for_Tegra/rootfs/usr/bin
Un-mount those folders and delete the QEMU binary from Linux_for_Tegra/rootfs/usr/bin, and generate the SD card image as you would do previously.
However, you should note that the pre-built OpenCV binaries do not come with CUDA support, and you would need to compile it yourself if you need CUDA acceleration.
