How to develop a multi-VC MIPI camera?
We have a MIPI camera, but if the MIPI output only has one VC0, we can obtain images. However, if the MIPI outputs VC0 and VC1, we are unable to get images from VC0. Also, what are the methods to correctly obtain images from VC0 and VC1?
Below is the log of the output for VC0 and VC1:
root@ubuntu:/home/Desktop/driver# echo . >/sys/kernel/debug/tracing/trace
root@ubuntu:/home/Desktop/driver# v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-mmap --set-ctrl=sensor_mode=1 --stream-count=1 -d /dev/video0
^C
root@ubuntu:/home/Desktop/driver# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 166/166   #P:8
#                                _-------=> irqs-off
#                               / _------=> need-resched
#                              | / _-----=> need-resched-lazy
#                              || / _----=> hardirq/softirq
#                              ||| / _---=> preempt-depth
#                              |||| / _--=> preempt-lazy-depth
#                              ||||| / _-=> migrate-disable
#                              |||||| /     delay
#           TASK-PID     CPU#  |||||||  TIMESTAMP  FUNCTION
        v4l2-ctl-3979    [005] .......  2675.455278: tegra_channel_open: vi-output, ovx3c 9-0036
        v4l2-ctl-3979    [005] .......  2675.471825: tegra_channel_set_power: ovx3c 9-0036 : 0x1
        v4l2-ctl-3979    [005] .......  2675.471834: camera_common_s_power: status : 0x1
        v4l2-ctl-3979    [005] .......  2675.471841: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3979    [005] .......  2675.471842: csi_s_power: enable : 0x1
        v4l2-ctl-3979    [005] .......  2675.473382: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
 vi-output, ovx3-3980    [002] .......  2675.483709: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:1546 pid:3980 tid:3980
 vi-output, ovx3-3980    [002] .......  2675.483720: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:1546 pid:3980 tid:3980
 vi-output, ovx3-3980    [002] .......  2675.483722: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:1546 pid:3980 tid:3980
 vi-output, ovx3-3980    [002] .......  2675.483724: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:1546 pid:3980 tid:3980
        v4l2-ctl-3979    [006] .......  2675.483846: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-3979    [006] .......  2675.486653: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-3979    [006] .......  2675.486656: csi_s_stream: enable : 0x1
        v4l2-ctl-3979    [006] .......  2675.486965: tegra_channel_set_stream: ovx3c 9-0036 : 0x1
     kworker/2:2-222     [002] .......  2675.502760: rtcpu_string: tstamp:84420069792 id:0x04010000 str:"VM0 activating."
     kworker/2:2-222     [002] .......  2675.502765: rtcpu_vinotify_event: tstamp:84420823960 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:2701449573056 data:0x799d580010000000
     kworker/2:2-222     [002] .......  2675.502766: rtcpu_vinotify_event: tstamp:84420824098 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:2701449615168 data:0x0000000031000001
     kworker/2:2-222     [002] .......  2675.502766: rtcpu_vinotify_event: tstamp:84420824255 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:2701449633280 data:0x799d550010000000
     kworker/2:2-222     [002] .......  2675.502767: rtcpu_vinotify_event: tstamp:84420824389 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:2701449653536 data:0x0000000007020001
     kworker/2:2-222     [002] .......  2675.502767: rtcpu_vinotify_event: tstamp:84420824539 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:2701449695936 data:0x0000000031000002
     kworker/2:2-222     [002] .......  2676.134755: rtcpu_vinotify_event: tstamp:84439812787 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:2702067671904 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2676.134758: rtcpu_vinotify_event: tstamp:84439812946 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:2702067671968 data:0x0000000800000000
     kworker/2:2-222     [002] .......  2676.134759: rtcpu_vinotify_event: tstamp:84439813083 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:2702067680928 data:0x0000000000000001
     kworker/2:2-222     [002] .......  2676.134759: rtcpu_vinotify_event: tstamp:84439813235 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:2702067713376 data:0x0000000008020001
 vi-output, ovx3-3981    [005] .......  2676.202490: tegra_channel_capture_frame: sof:2702.67680928
 vi-output, ovx3-3981    [005] .......  2676.202492: tegra_channel_capture_frame: eof:2702.167727040
 vi-output, ovx3-3980    [002] .......  2676.202693: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:1546 pid:3980 tid:3980
     kworker/2:2-222     [002] .......  2676.246743: rtcpu_vinotify_error: tstamp:84442699022 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702166234048 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.246746: rtcpu_vinotify_event: tstamp:84442748709 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2702166128608 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2676.246747: rtcpu_vinotify_event: tstamp:84442748884 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702166234048 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.246748: rtcpu_vinotify_event: tstamp:84442749020 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:2702167654752 data:0x0000000004370002
     kworker/2:2-222     [002] .......  2676.246748: rtcpu_vinotify_event: tstamp:84442749174 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:2702167655712 data:0x0000000000000000
     kworker/2:2-222     [002] .......  2676.246749: rtcpu_vinotify_event: tstamp:84442749307 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:2702167677024 data:0x0000000002020001
     kworker/2:2-222     [002] .......  2676.246750: rtcpu_vinotify_event: tstamp:84442749460 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:2702167655776 data:0x0000000004380040
     kworker/2:2-222     [002] .......  2676.246751: rtcpu_vinotify_event: tstamp:84442749609 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:2702167728800 data:0x0000000001020001
     kworker/2:2-222     [002] .......  2676.246751: rtcpu_vinotify_event: tstamp:84444045092 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2702209187328 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2676.306729: rtcpu_vinotify_error: tstamp:84445823240 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702266209024 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.362735: rtcpu_vinotify_event: tstamp:84446215593 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2702266103424 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2676.362736: rtcpu_vinotify_event: tstamp:84446215754 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702266209024 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.362737: rtcpu_vinotify_event: tstamp:84447300579 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2702309162176 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2676.418734: rtcpu_vinotify_error: tstamp:84448947453 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702366183840 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.418735: rtcpu_vinotify_event: tstamp:84449469991 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2702366078400 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2676.418736: rtcpu_vinotify_event: tstamp:84449470129 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702366183840 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.474728: rtcpu_vinotify_event: tstamp:84450554972 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2702409137120 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2676.530747: rtcpu_vinotify_error: tstamp:84452071759 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702466158816 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.530749: rtcpu_vinotify_event: tstamp:84452182600 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2702466053344 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2676.530750: rtcpu_vinotify_event: tstamp:84452182755 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702466158816 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.586730: rtcpu_vinotify_event: tstamp:84453810452 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2702509112064 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2676.642730: rtcpu_vinotify_error: tstamp:84455195889 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702566133760 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.642731: rtcpu_vinotify_event: tstamp:84455438068 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2702566028160 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2676.642732: rtcpu_vinotify_event: tstamp:84455438206 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702566133760 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.698725: rtcpu_vinotify_event: tstamp:84457065942 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2702609086912 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2676.754726: rtcpu_vinotify_error: tstamp:84458320098 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702666108576 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.754727: rtcpu_vinotify_event: tstamp:84458693551 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2702666003136 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2676.754727: rtcpu_vinotify_event: tstamp:84458693717 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702666108576 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.754728: rtcpu_vinotify_event: tstamp:84459661264 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2702709061888 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2676.814731: rtcpu_vinotify_error: tstamp:84461444323 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702766083552 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.814733: rtcpu_vinotify_event: tstamp:84461460194 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2702765978112 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2676.814733: rtcpu_vinotify_event: tstamp:84461460330 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702766083552 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.870725: rtcpu_vinotify_event: tstamp:84463088097 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2702809036800 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2676.926722: rtcpu_vinotify_error: tstamp:84464568533 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702866058496 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.926723: rtcpu_vinotify_event: tstamp:84464715675 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2702865952896 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2676.926724: rtcpu_vinotify_event: tstamp:84464715827 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702866058496 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2676.986716: rtcpu_vinotify_event: tstamp:84466343545 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2702909011648 data:0x0000000000000021
        v4l2-ctl-3979    [006] .......  2676.987231: tegra_channel_close: vi-output, ovx3c 9-0036
     kworker/2:2-222     [002] .......  2677.046716: rtcpu_vinotify_error: tstamp:84467692746 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702966033344 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.046717: rtcpu_vinotify_event: tstamp:84467971150 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2702965927872 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.046718: rtcpu_vinotify_event: tstamp:84467971286 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2702966033344 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.046718: rtcpu_vinotify_event: tstamp:84469056158 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703008986624 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2677.106714: rtcpu_vinotify_error: tstamp:84470816991 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703066008288 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.166714: rtcpu_vinotify_event: tstamp:84471226640 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703065902848 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.166714: rtcpu_vinotify_event: tstamp:84471226798 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703066008288 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.166715: rtcpu_vinotify_event: tstamp:84472311611 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703108961536 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2677.222720: rtcpu_vinotify_error: tstamp:84473942445 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703165983232 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.222721: rtcpu_vinotify_event: tstamp:84473942762 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703165877632 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.222721: rtcpu_vinotify_event: tstamp:84474480898 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703165983232 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.278718: rtcpu_vinotify_event: tstamp:84475566972 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703208936384 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2677.334718: rtcpu_vinotify_event: tstamp:84477060976 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703265852640 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.334718: rtcpu_vinotify_error: tstamp:84477065395 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703265958048 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.334719: rtcpu_vinotify_event: tstamp:84477573870 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703265958048 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.394710: rtcpu_vinotify_event: tstamp:84478658839 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703308911360 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2677.450715: rtcpu_vinotify_error: tstamp:84480189613 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703365933024 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.450718: rtcpu_vinotify_event: tstamp:84480286462 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703365827584 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.450718: rtcpu_vinotify_event: tstamp:84480286600 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703365933024 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.506902: rtcpu_vinotify_event: tstamp:84481914350 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703408886304 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2677.506906: rtcpu_vinotify_error: tstamp:84483313830 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703465907968 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.562728: rtcpu_vinotify_event: tstamp:84483541936 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703465802368 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.562730: rtcpu_vinotify_event: tstamp:84483542094 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703465907968 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.562731: rtcpu_vinotify_event: tstamp:84485169810 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703508861120 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2677.618713: rtcpu_vinotify_error: tstamp:84486438044 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703565882816 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.618714: rtcpu_vinotify_event: tstamp:84486797424 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703565777376 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.618714: rtcpu_vinotify_event: tstamp:84486797561 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703565882816 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.674710: rtcpu_vinotify_event: tstamp:84487882408 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703608836096 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2677.734706: rtcpu_vinotify_error: tstamp:84489562353 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703665857792 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.734707: rtcpu_vinotify_event: tstamp:84490051815 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703665752352 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.734708: rtcpu_vinotify_event: tstamp:84490051968 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703665857792 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.794703: rtcpu_vinotify_event: tstamp:84491137887 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703708811040 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2677.850709: rtcpu_vinotify_error: tstamp:84492686766 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703765832704 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.850710: rtcpu_vinotify_event: tstamp:84492687400 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703765727104 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.850710: rtcpu_vinotify_event: tstamp:84492687537 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703765832704 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.850711: rtcpu_vinotify_event: tstamp:84494067498 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703808785856 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2677.906707: rtcpu_vinotify_error: tstamp:84495810697 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703865807552 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.966703: rtcpu_vinotify_event: tstamp:84496236912 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703865702112 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2677.966704: rtcpu_vinotify_event: tstamp:84496237070 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703865807552 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2677.966705: rtcpu_vinotify_event: tstamp:84497321889 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2703908760832 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2678.022706: rtcpu_vinotify_error: tstamp:84498934901 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703965782528 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.022707: rtcpu_vinotify_event: tstamp:84498949493 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2703965677088 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2678.022708: rtcpu_vinotify_event: tstamp:84498949629 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2703965782528 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.078704: rtcpu_vinotify_event: tstamp:84500577376 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2704008735776 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2678.138696: rtcpu_vinotify_error: tstamp:84502059124 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704065757440 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.138697: rtcpu_vinotify_event: tstamp:84502204985 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2704065651872 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2678.138698: rtcpu_vinotify_event: tstamp:84502205141 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704065757440 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.194703: rtcpu_vinotify_event: tstamp:84503832866 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2704108710624 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2678.250701: rtcpu_vinotify_error: tstamp:84505183367 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704165732288 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.250701: rtcpu_vinotify_event: tstamp:84505460472 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2704165626880 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2678.250702: rtcpu_vinotify_event: tstamp:84505460610 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704165732288 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.250702: rtcpu_vinotify_event: tstamp:84506545447 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2704208685600 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2678.310694: rtcpu_vinotify_error: tstamp:84508307592 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704265707296 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.366701: rtcpu_vinotify_event: tstamp:84508715949 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2704265601856 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2678.366701: rtcpu_vinotify_event: tstamp:84508716107 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704265707296 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.366702: rtcpu_vinotify_event: tstamp:84509648725 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2704308660512 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2678.422698: rtcpu_vinotify_error: tstamp:84511433127 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704365682208 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.422699: rtcpu_vinotify_event: tstamp:84511433437 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2704365576608 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2678.422699: rtcpu_vinotify_event: tstamp:84511970459 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704365682208 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.482691: rtcpu_vinotify_event: tstamp:84513056570 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2704408635360 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2678.538696: rtcpu_vinotify_error: tstamp:84514556015 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704465657024 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.538697: rtcpu_vinotify_event: tstamp:84514684145 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2704465551616 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2678.538697: rtcpu_vinotify_event: tstamp:84514684299 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704465657024 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.594695: rtcpu_vinotify_event: tstamp:84516310928 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2704508610336 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2678.650693: rtcpu_vinotify_error: tstamp:84517680210 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704565632000 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.650694: rtcpu_vinotify_event: tstamp:84517938534 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2704565526592 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2678.650694: rtcpu_vinotify_event: tstamp:84517938669 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704565632000 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.650695: rtcpu_vinotify_event: tstamp:84519023511 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:2704608585248 data:0x0000000000000021
     kworker/2:2-222     [002] .......  2678.710688: rtcpu_vinotify_error: tstamp:84520804425 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704665606976 data:0x0000000000000569
 vi-output, ovx3-3981    [004] .......  2678.723842: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
        v4l2-ctl-3979    [006] .......  2678.724352: tegra_channel_set_stream: enable : 0x0
        v4l2-ctl-3979    [006] .......  2678.724354: tegra_channel_set_stream: ovx3c 9-0036 : 0x0
        v4l2-ctl-3979    [006] .......  2678.724930: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3979    [006] .......  2678.724932: csi_s_stream: enable : 0x0
        v4l2-ctl-3979    [006] .......  2678.729222: tegra_channel_set_power: ovx3c 9-0036 : 0x0
        v4l2-ctl-3979    [006] .......  2678.729250: camera_common_s_power: status : 0x0
        v4l2-ctl-3979    [006] .......  2678.729255: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-3979    [006] .......  2678.729256: csi_s_power: enable : 0x0
     kworker/2:2-222     [002] .......  2678.766708: rtcpu_vinotify_event: tstamp:84521194010 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:2704665501376 data:0x0000000000000011
     kworker/2:2-222     [002] .......  2678.766711: rtcpu_vinotify_event: tstamp:84521194170 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:2704665606976 data:0x0000000000000569
     kworker/2:2-222     [002] .......  2678.766712: rtcpu_vinotify_error: tstamp:84521527013 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:2704688442112 data:0x0000000000000010
     kworker/2:2-222     [002] .......  2678.766713: rtcpu_vinotify_error: tstamp:84521528148 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:2704688442112 data:0x0000000000000121
     kworker/2:2-222     [002] .......  2678.766715: rtcpu_nvcsi_intr: tstamp:84521673722 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766716: rtcpu_nvcsi_intr: tstamp:84521673722 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766717: rtcpu_nvcsi_intr: tstamp:84521673722 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/2:2-222     [002] .......  2678.766718: rtcpu_nvcsi_intr: tstamp:84521683669 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766718: rtcpu_nvcsi_intr: tstamp:84521683669 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766719: rtcpu_nvcsi_intr: tstamp:84521683669 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/2:2-222     [002] .......  2678.766719: rtcpu_nvcsi_intr: tstamp:84521697689 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766720: rtcpu_nvcsi_intr: tstamp:84521697689 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766721: rtcpu_nvcsi_intr: tstamp:84521697689 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/2:2-222     [002] .......  2678.766721: rtcpu_nvcsi_intr: tstamp:84521708263 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:1 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766722: rtcpu_nvcsi_intr: tstamp:84521708263 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:1 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766722: rtcpu_nvcsi_intr: tstamp:84521708263 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/2:2-222     [002] .......  2678.766723: rtcpu_nvcsi_intr: tstamp:84521710753 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:1 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766724: rtcpu_nvcsi_intr: tstamp:84521710753 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:1 status:0x00000004
     kworker/2:2-222     [002] .......  2678.766724: rtcpu_nvcsi_intr: tstamp:84521710753 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000110
     kworker/2:2-222     [002] .......  2678.766725: rtcpu_vinotify_event: tstamp:84521736167 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:2704688442112 data:0x0000000000000010
     kworker/2:2-222     [002] .......  2678.766729: rtcpu_vinotify_event: tstamp:84521736318 cch:-1 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:2704688442112 data:0x0000000000000121
     kworker/2:2-222     [002] .......  2678.766730: rtcpu_vinotify_event: tstamp:84521736457 cch:-1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x02 frame:0 vi_tstamp:2704688442112 data:0x0438200001000000
     kworker/2:2-222     [002] .......  2678.766731: rtcpu_vinotify_event: tstamp:84521736610 cch:-1 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:2704688442176 data:0x0000000800000000
root@ubuntu:/home/Desktop/driver# sudo dmesg | tail -100
[ 2675.486984] ovx3c 9-0036: set mode 1...
[ 2675.738189] ovx3c 9-0036: set max96716 init success ..., ret=0
[ 2676.085813] ovx3c 9-0036: set mode 1, ret=0
[ 2676.085834] start stream...
[ 2676.202470] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 64
[ 2678.722703] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 2678.722721] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2678.724122] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 2678.724364] stop stream...
hello DDEnginee,
please refer to Jetson Virtual Channel with GMSL Camera Framework.
you may see-also reference driver which works with virtual channels.
i.e. hardware/nvidia/t23x/nv-public/overlay/tegra234-camera-ar0234-a00.dtsi
We refer to modifying DTS, but DMSG will report an error when checking the log
[  160.428452] ovx3c 9-0037: load ko version [2.3.0]
[  160.428465] ovx3c 9-0037: channel not found
[  160.428466] ovx3c 9-0037: ovx3c_probe: channel -97
[  160.428469] ovx3c 9-0037: ovx3c_probe: sensor_index = 1
[  160.428554] ovx3c 9-0037: [ovx3c_power_get:548] power get
[  160.428612] ovx3c 9-0037: tegracam sensor driver:ovx3c_v2.0.6
[  160.428676] tegra-camrtc-capture-vi tegra-capture-vi: subdev ovx3c 9-0037 bound
[  160.429677] ovx3c 9-0036: load ko version [2.3.0]
[  160.429684] ovx3c 9-0036: channel not found
[  160.429686] ovx3c 9-0036: ovx3c_probe: channel -97
[  160.429688] ovx3c 9-0036: ovx3c_probe: sensor_index = 0
[  160.429745] ovx3c 9-0036: [ovx3c_power_get:548] power get
[  160.429809] debugfs: Directory 'ovx3c_b' with parent '/' already present!
[  160.429814] ovx3c 9-0036: tegracam sensor driver:ovx3c_v2.0.6
[  160.429848] tegra-camrtc-capture-vi tegra-capture-vi: subdev ovx3c 9-0036 bound
The kernel also reported some errors:
[    3.166399] i2c i2c-2: Added multiplexed i2c bus 9
[    3.166501] sysfs: cannot create duplicate filename '/devices/platform/bus@0/bus@0:cam_i2cmux/channel-0'
[    3.166518] CPU: 5 PID: 106 Comm: kworker/u16:1 Not tainted 5.15.148-tegra #6
[    3.166524] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.4.3-gcid-38968081 01/08/2025
[    3.166529] Workqueue: events_unbound deferred_probe_work_func
[    3.166582] Call trace:
[    3.166585]  dump_backtrace+0x0/0x1f0
[    3.166613]  show_stack+0x34/0x50
[    3.166616]  dump_stack_lvl+0x68/0x84
[    3.166645]  dump_stack+0x18/0x34
[    3.166648]  sysfs_warn_dup+0x70/0x90
[    3.166674]  sysfs_do_create_link_sd+0x110/0x120
[    3.166679]  sysfs_create_link+0x58/0x80
[    3.166681]  i2c_mux_add_adapter+0x2c4/0x4e0
[    3.166703]  i2c_mux_gpio_probe+0x224/0x530
[    3.166709]  platform_probe+0x74/0xf0
[    3.166717]  really_probe+0xcc/0x470
[    3.166720]  __driver_probe_device+0x110/0x170
[    3.166723]  driver_probe_device+0x54/0x130
[    3.166726]  __device_attach_driver+0xc8/0x170
[    3.166728]  bus_for_each_drv+0x8c/0xe0
[    3.166738]  __device_attach+0xb4/0x1f0
[    3.166739]  device_initial_probe+0x2c/0x40
[    3.166741]  bus_probe_device+0xa8/0xb0
[    3.166742]  deferred_probe_work_func+0xac/0x100
[    3.166744]  process_one_work+0x208/0x4d0
[    3.166757]  worker_thread+0x2c8/0x490
[    3.166760]  kthread+0x184/0x190
[    3.166765]  ret_from_fork+0x10/0x20
[    3.166773] ------------[ cut here ]------------
[    3.166774] can't create symlink to channel 0
[    3.166857] WARNING: CPU: 5 PID: 106 at drivers/i2c/i2c-mux.c:425 i2c_mux_add_adapter+0x2d8/0x4e0
[    3.166876] Modules linked in:
[    3.166884] CPU: 5 PID: 106 Comm: kworker/u16:1 Not tainted 5.15.148-tegra #6
[    3.166886] Hardware name: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.4.3-gcid-38968081 01/08/2025
[    3.166888] Workqueue: events_unbound deferred_probe_work_func
[    3.166895] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    3.166899] pc : i2c_mux_add_adapter+0x2d8/0x4e0
[    3.166901] lr : i2c_mux_add_adapter+0x2d8/0x4e0
[    3.166905] sp : ffff800009013ab0
[    3.166905] x29: ffff800009013ab0 x28: ffff00008536c580 x27: 0000000000000007
[    3.166908] x26: ffffca4a743b4860 x25: ffff0003f02f8ae0 x24: ffff0000853a58f8
[    3.166910] x23: 0000000000000000 x22: 0000000000000000 x21: ffff00008536c580
[    3.166912] x20: ffff0000853a2800 x19: ffff0000853a2870 x18: ffffffffffffffff
[    3.166915] x17: 30407375622f6d72 x16: 6f6674616c702f73 x15: ffffca4a7529d1bb
[    3.166917] x14: 0000000000000000 x13: ffffca4a7529d1b8 x12: 206f74206b6e696c
[    3.166918] x11: 656820747563205b x10: 000000000000000a x9 : ffff800009013ab0
[    3.166920] x8 : 000000000000000a x7 : 6d79732065746165 x6 : 000000000000000a
[    3.166922] x5 : 000000000000000c x4 : 00000000fffff186 x3 : ffffca4a74eb62d8
[    3.166924] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff000080e1be00
[    3.166925] Call trace:
[    3.166926]  i2c_mux_add_adapter+0x2d8/0x4e0
[    3.166928]  i2c_mux_gpio_probe+0x224/0x530
[    3.166932]  platform_probe+0x74/0xf0
[    3.166937]  really_probe+0xcc/0x470
[    3.166938]  __driver_probe_device+0x110/0x170
[    3.166940]  driver_probe_device+0x54/0x130
[    3.166941]  __device_attach_driver+0xc8/0x170
[    3.166943]  bus_for_each_drv+0x8c/0xe0
[    3.166946]  __device_attach+0xb4/0x1f0
[    3.166947]  device_initial_probe+0x2c/0x40
[    3.166949]  bus_probe_device+0xa8/0xb0
[    3.166950]  deferred_probe_work_func+0xac/0x100
[    3.166952]  process_one_work+0x208/0x4d0
[    3.166961]  worker_thread+0x2c8/0x490
[    3.166963]  kthread+0x184/0x190
[    3.166966]  ret_from_fork+0x10/0x20
[    3.166974] ---[ end trace 81a1c2eedc4ec86f ]---
Can you help me check where the device tree is set incorrectly?
log2.txt (64.7 KB)
tegra234-p3767-camera-p3768-ovx3c-A-mulit-vc.dts.txt (15.6 KB)
hello DDEnginee,
are you using SerDes chips, which using Gigabit Multimedia Serial Link (GMSL) protocol?
you should also add device tree property for gmsl-link{}.
We currently do not use serdes, only the sensor is connected to mipi 2lane, and the sensor will output two frames, vc0 and vc1. Currently, only outputting vc0 can produce images, but outputting vc0 and vc1 together cannot obtain images
hello DDEnginee,
please refer to developer guide, VC it works with GMSL Protocol.
this is not supported.
We have modified according to the GMSL format, but still cannot obtain the image without reporting any VC errors
tegra234-p3767-camera-p3768-ovx3c-A-mulit-vc.dts.txt (20.4 KB)
        v4l2-ctl-2664    [007] .......   871.576258: tegra_channel_open: vi-output, ovx3c 9-0037
        v4l2-ctl-2664    [007] .......   871.581279: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
 vi-output, ovx3-2665    [007] .......   871.582487: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:32 pid:2665 tid:2665
 vi-output, ovx3-2665    [007] .......   871.582493: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:32 pid:2665 tid:2665
 vi-output, ovx3-2665    [007] .......   871.582494: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:32 pid:2665 tid:2665
        v4l2-ctl-2664    [004] .......   871.582530: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-2664    [004] .......   871.584308: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-2664    [004] .......   871.584311: csi_s_stream: enable : 0x1
        v4l2-ctl-2664    [004] .......   871.584721: tegra_channel_set_stream: ovx3c 9-0037 : 0x1
     kworker/1:2-167     [001] .......   871.612541: rtcpu_vinotify_event: tstamp:28402487682 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:908862462368 data:0x799d580010000000
     kworker/1:2-167     [001] .......   871.612543: rtcpu_vinotify_event: tstamp:28402487821 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:908862504480 data:0x0000000031000001
     kworker/1:2-167     [001] .......   871.612544: rtcpu_vinotify_event: tstamp:28402487985 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:908862522656 data:0x799d550010000000
     kworker/1:2-167     [001] .......   871.612545: rtcpu_vinotify_event: tstamp:28402488119 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:908862542944 data:0x0000000007020001
     kworker/1:2-167     [001] .......   871.612545: rtcpu_vinotify_event: tstamp:28402488271 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:908862585344 data:0x0000000031000002
     kworker/1:2-167     [001] .......   871.612547: rtcpu_vinotify_error: tstamp:28402520628 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:908880524448 data:0x0000000000000569
     kworker/1:2-167     [001] .......   871.668525: rtcpu_vinotify_event: tstamp:28403030614 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:908880515392 data:0x0000000000000011
     kworker/1:2-167     [001] .......   871.668526: rtcpu_vinotify_event: tstamp:28403030773 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:908880524448 data:0x0000000000000569
     kworker/1:2-167     [001] .......   871.668527: rtcpu_vinotify_event: tstamp:28404115616 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:908921956416 data:0x0000000000000021
     kworker/1:2-167     [001] .......   871.724469: rtcpu_vinotify_error: tstamp:28405597264 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:908978978048 data:0x0000000000000569
     kworker/1:2-167     [001] .......   871.724471: rtcpu_vinotify_event: tstamp:28405743189 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:908978872448 data:0x0000000000000011
     kworker/1:2-167     [001] .......   871.724471: rtcpu_vinotify_event: tstamp:28405743325 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:908978978048 data:0x0000000000000569
     kworker/1:2-167     [001] .......   871.780428: rtcpu_vinotify_event: tstamp:28407371068 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909021931168 data:0x0000000000000021
     kworker/1:2-167     [001] .......   871.836408: rtcpu_vinotify_error: tstamp:28408721482 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909078952832 data:0x0000000000000569
     kworker/1:2-167     [001] .......   871.836410: rtcpu_vinotify_event: tstamp:28408998673 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909078847392 data:0x0000000000000011
     kworker/1:2-167     [001] .......   871.836410: rtcpu_vinotify_event: tstamp:28408998828 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909078952832 data:0x0000000000000569
     kworker/1:2-167     [001] .......   871.892379: rtcpu_vinotify_event: tstamp:28410083683 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909121906112 data:0x0000000000000021
     kworker/1:2-167     [001] .......   871.948332: rtcpu_vinotify_error: tstamp:28411846017 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909178927744 data:0x0000000000000569
     kworker/1:2-167     [001] .......   871.948333: rtcpu_vinotify_event: tstamp:28411846642 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909178822304 data:0x0000000000000011
     kworker/1:2-167     [001] .......   871.948334: rtcpu_vinotify_event: tstamp:28411846777 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909178927744 data:0x0000000000000569
     kworker/1:2-167     [001] .......   871.948335: rtcpu_vinotify_event: tstamp:28413230044 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909221880960 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.004303: rtcpu_vinotify_error: tstamp:28414969910 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909278902624 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.060268: rtcpu_vinotify_event: tstamp:28415400548 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909278797024 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.060270: rtcpu_vinotify_event: tstamp:28415400704 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909278902624 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.060270: rtcpu_vinotify_event: tstamp:28416485514 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909321855776 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.116233: rtcpu_vinotify_error: tstamp:28418094126 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909378877408 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.116234: rtcpu_vinotify_event: tstamp:28418113120 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909378771968 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.116235: rtcpu_vinotify_event: tstamp:28418113254 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909378877408 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.172199: rtcpu_vinotify_event: tstamp:28419741025 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909421830656 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.228155: rtcpu_vinotify_error: tstamp:28421218339 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909478852320 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.228155: rtcpu_vinotify_event: tstamp:28421368603 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909478746880 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.228156: rtcpu_vinotify_event: tstamp:28421368756 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909478852320 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.284123: rtcpu_vinotify_event: tstamp:28422995393 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909521805536 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.340098: rtcpu_vinotify_error: tstamp:28424342554 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909578827200 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.340099: rtcpu_vinotify_event: tstamp:28424622998 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909578721600 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.340100: rtcpu_vinotify_event: tstamp:28424623134 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909578827200 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.396066: rtcpu_vinotify_event: tstamp:28425709113 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909621780320 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.452036: rtcpu_vinotify_error: tstamp:28427466770 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909678801952 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.452037: rtcpu_vinotify_event: tstamp:28427878487 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909678696512 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.452038: rtcpu_vinotify_event: tstamp:28427878643 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909678801952 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.452038: rtcpu_vinotify_event: tstamp:28428807927 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909721755232 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.507999: rtcpu_vinotify_error: tstamp:28430591061 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909778776896 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.508001: rtcpu_vinotify_event: tstamp:28430595689 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909778671456 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.508002: rtcpu_vinotify_event: tstamp:28430595822 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909778776896 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.563970: rtcpu_vinotify_event: tstamp:28432219213 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909821730112 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.619923: rtcpu_vinotify_error: tstamp:28433715197 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909878751744 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.619924: rtcpu_vinotify_event: tstamp:28433846818 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909878646176 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.619924: rtcpu_vinotify_event: tstamp:28433846975 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909878751744 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.675882: rtcpu_vinotify_event: tstamp:28435474698 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:909921704864 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.731851: rtcpu_vinotify_error: tstamp:28436839409 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909978726560 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.731852: rtcpu_vinotify_event: tstamp:28437102305 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:909978621088 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.731853: rtcpu_vinotify_event: tstamp:28437102443 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:909978726560 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.787832: rtcpu_vinotify_event: tstamp:28438187289 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910021679808 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.843784: rtcpu_vinotify_error: tstamp:28439963630 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910078701472 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.843786: rtcpu_vinotify_event: tstamp:28440356678 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910078596032 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.843786: rtcpu_vinotify_event: tstamp:28440356832 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910078701472 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.903754: rtcpu_vinotify_event: tstamp:28441442760 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910121654656 data:0x0000000000000021
     kworker/1:2-167     [001] .......   872.903756: rtcpu_vinotify_error: tstamp:28443087845 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910178676352 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.959729: rtcpu_vinotify_event: tstamp:28443612172 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910178570752 data:0x0000000000000011
     kworker/1:2-167     [001] .......   872.959731: rtcpu_vinotify_event: tstamp:28443612310 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910178676352 data:0x0000000000000569
     kworker/1:2-167     [001] .......   872.959732: rtcpu_vinotify_event: tstamp:28444697158 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910221629472 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.015683: rtcpu_vinotify_event: tstamp:28446207664 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910278545664 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.015685: rtcpu_vinotify_error: tstamp:28446212053 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910278651136 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.015685: rtcpu_vinotify_event: tstamp:28446705153 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910278651136 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.071655: rtcpu_vinotify_event: tstamp:28447790134 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910321604384 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.127614: rtcpu_vinotify_error: tstamp:28449336275 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910378626016 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.127615: rtcpu_vinotify_event: tstamp:28449417740 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910378520576 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.127616: rtcpu_vinotify_event: tstamp:28449417874 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910378626016 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.183575: rtcpu_vinotify_event: tstamp:28451045615 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910421579264 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.239542: rtcpu_vinotify_error: tstamp:28452460510 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910478600896 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.239543: rtcpu_vinotify_event: tstamp:28452673250 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910478495296 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.239544: rtcpu_vinotify_event: tstamp:28452673408 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910478600896 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.295514: rtcpu_vinotify_event: tstamp:28454300034 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910521554016 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.351487: rtcpu_vinotify_error: tstamp:28455584749 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910578575680 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.351488: rtcpu_vinotify_event: tstamp:28455927666 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910578470240 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.351489: rtcpu_vinotify_event: tstamp:28455927805 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910578575680 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.351489: rtcpu_vinotify_event: tstamp:28457013714 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910621528928 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.407454: rtcpu_vinotify_error: tstamp:28458708968 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910678550592 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.467399: rtcpu_vinotify_event: tstamp:28459183119 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910678445152 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.467400: rtcpu_vinotify_event: tstamp:28459183277 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910678550592 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.467401: rtcpu_vinotify_event: tstamp:28460268134 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910721503808 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.523394: rtcpu_vinotify_error: tstamp:28461833465 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910778525440 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.523395: rtcpu_vinotify_event: tstamp:28461834125 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910778419872 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.523396: rtcpu_vinotify_event: tstamp:28461834261 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910778525440 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.579351: rtcpu_vinotify_event: tstamp:28463197775 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910821478592 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.635307: rtcpu_vinotify_error: tstamp:28464957342 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910878500256 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.635308: rtcpu_vinotify_event: tstamp:28465368278 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910878394816 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.635308: rtcpu_vinotify_event: tstamp:28465368469 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910878500256 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.691268: rtcpu_vinotify_event: tstamp:28466453258 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:910921453504 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.747231: rtcpu_vinotify_error: tstamp:28468081595 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910978475168 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.747231: rtcpu_vinotify_event: tstamp:28468085236 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:910978369728 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.747232: rtcpu_vinotify_event: tstamp:28468085374 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:910978475168 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.803209: rtcpu_vinotify_event: tstamp:28469708770 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911021428384 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.803211: rtcpu_vinotify_error: tstamp:28471205797 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911078450048 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.803212: rtcpu_vinotify_event: tstamp:28471336346 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911078344448 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.803212: rtcpu_vinotify_event: tstamp:28471336503 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911078450048 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.859191: rtcpu_vinotify_event: tstamp:28472964229 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911121403168 data:0x0000000000000021
     kworker/1:2-167     [001] .......   873.915144: rtcpu_vinotify_error: tstamp:28474330008 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911178424832 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.915146: rtcpu_vinotify_event: tstamp:28474591801 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911178319392 data:0x0000000000000011
     kworker/1:2-167     [001] .......   873.915146: rtcpu_vinotify_event: tstamp:28474591940 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911178424832 data:0x0000000000000569
     kworker/1:2-167     [001] .......   873.971097: rtcpu_vinotify_event: tstamp:28475676796 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911221378080 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.027082: rtcpu_vinotify_error: tstamp:28477454191 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911278399744 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.027084: rtcpu_vinotify_event: tstamp:28477846184 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911278294304 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.027084: rtcpu_vinotify_event: tstamp:28477846338 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911278399744 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.083045: rtcpu_vinotify_event: tstamp:28478795353 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911321352992 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.138997: rtcpu_vinotify_error: tstamp:28480578440 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911378374624 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.138998: rtcpu_vinotify_event: tstamp:28480613994 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911378269024 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.138998: rtcpu_vinotify_event: tstamp:28480614186 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911378374624 data:0x0000000000000569
 vi-output, ovx3-2666    [005] .......   874.152329: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
 vi-output, ovx3-2665    [007] .......   874.152533: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:32 pid:2665 tid:2665
 vi-output, ovx3-2665    [007] .......   874.152540: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:32 pid:2665 tid:2665
 vi-output, ovx3-2665    [007] .......   874.152541: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:32 pid:2665 tid:2665
 vi-output, ovx3-2665    [007] .......   874.152543: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:32 pid:2665 tid:2665
     kworker/1:2-167     [001] .......   874.194961: rtcpu_vinotify_event: tstamp:28482242219 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911421327744 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.194962: rtcpu_vinotify_event: tstamp:28482783875 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:911432514016 data:0x799d580010000000
     kworker/1:2-167     [001] .......   874.194963: rtcpu_vinotify_event: tstamp:28482784033 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:911432556096 data:0x0000000031000001
     kworker/1:2-167     [001] .......   874.194963: rtcpu_vinotify_event: tstamp:28482784167 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:911432574272 data:0x799d550010000000
     kworker/1:2-167     [001] .......   874.194964: rtcpu_vinotify_event: tstamp:28482784321 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:911432594560 data:0x0000000007020001
     kworker/1:2-167     [001] .......   874.194964: rtcpu_vinotify_event: tstamp:28482784454 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:911432636928 data:0x0000000031000002
     kworker/1:2-167     [001] .......   874.250928: rtcpu_vinotify_error: tstamp:28483702652 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911478349408 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.250929: rtcpu_vinotify_event: tstamp:28483868552 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911478243968 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.250930: rtcpu_vinotify_event: tstamp:28483868688 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911478349408 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.306895: rtcpu_vinotify_event: tstamp:28485496468 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911521302656 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.306897: rtcpu_vinotify_error: tstamp:28486826864 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911578324320 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.366857: rtcpu_vinotify_event: tstamp:28487124076 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911578218848 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.366858: rtcpu_vinotify_event: tstamp:28487124239 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911578324320 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.366859: rtcpu_vinotify_event: tstamp:28488209059 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911621277536 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.422822: rtcpu_vinotify_error: tstamp:28489951367 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911678299200 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.422824: rtcpu_vinotify_event: tstamp:28489952003 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911678193600 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.422824: rtcpu_vinotify_event: tstamp:28489952145 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911678299200 data:0x0000000000000569
        v4l2-ctl-2664    [003] .......   874.439841: tegra_channel_close: vi-output, ovx3c 9-0037
     kworker/1:2-167     [001] .......   874.478794: rtcpu_vinotify_event: tstamp:28491301737 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911721252320 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.534775: rtcpu_vinotify_error: tstamp:28493075296 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911778273984 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.534777: rtcpu_vinotify_event: tstamp:28493472210 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911778168512 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.534778: rtcpu_vinotify_event: tstamp:28493472366 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911778273984 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.590734: rtcpu_vinotify_event: tstamp:28494557190 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911821227264 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.646703: rtcpu_vinotify_error: tstamp:28496199509 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911878248896 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.646704: rtcpu_vinotify_event: tstamp:28496726607 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911878143488 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.646704: rtcpu_vinotify_event: tstamp:28496726744 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911878248896 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.702653: rtcpu_vinotify_event: tstamp:28497812677 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:911921202112 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.702654: rtcpu_vinotify_error: tstamp:28499323722 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911978223744 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.702655: rtcpu_vinotify_event: tstamp:28499440287 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:911978118176 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.702657: rtcpu_vinotify_event: tstamp:28499440441 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:911978223744 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.758630: rtcpu_vinotify_event: tstamp:28501067072 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912021176896 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.814605: rtcpu_vinotify_error: tstamp:28502447970 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912078198560 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.814606: rtcpu_vinotify_event: tstamp:28502694676 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912078093120 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.814607: rtcpu_vinotify_event: tstamp:28502694815 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912078198560 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.870550: rtcpu_vinotify_event: tstamp:28504322513 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912121151840 data:0x0000000000000021
     kworker/1:2-167     [001] .......   874.926522: rtcpu_vinotify_error: tstamp:28505572127 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912178173472 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.926522: rtcpu_vinotify_event: tstamp:28505950152 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912178068032 data:0x0000000000000011
     kworker/1:2-167     [001] .......   874.926523: rtcpu_vinotify_event: tstamp:28505950310 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912178173472 data:0x0000000000000569
     kworker/1:2-167     [001] .......   874.982480: rtcpu_vinotify_event: tstamp:28506913294 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912221126688 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.038465: rtcpu_vinotify_error: tstamp:28508696367 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912278148384 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.038467: rtcpu_vinotify_event: tstamp:28508716766 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912278042784 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.038467: rtcpu_vinotify_event: tstamp:28508716900 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912278148384 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.094432: rtcpu_vinotify_event: tstamp:28510344645 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912321101504 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.150391: rtcpu_vinotify_error: tstamp:28511820585 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912378123136 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.150392: rtcpu_vinotify_event: tstamp:28511972285 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912378017696 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.150393: rtcpu_vinotify_event: tstamp:28511972442 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912378123136 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.206352: rtcpu_vinotify_event: tstamp:28513600168 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912421076416 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.206353: rtcpu_vinotify_error: tstamp:28514944793 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912478098048 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.262327: rtcpu_vinotify_event: tstamp:28515227774 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912477992608 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.262328: rtcpu_vinotify_event: tstamp:28515227945 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912478098048 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.262329: rtcpu_vinotify_event: tstamp:28516312751 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912521051296 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.318291: rtcpu_vinotify_error: tstamp:28518069011 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912578072928 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.318293: rtcpu_vinotify_event: tstamp:28518483255 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912577967360 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.318294: rtcpu_vinotify_event: tstamp:28518483408 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912578072928 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.374248: rtcpu_vinotify_event: tstamp:28519568242 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912621026080 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.430211: rtcpu_vinotify_error: tstamp:28521193313 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912678047712 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.430211: rtcpu_vinotify_event: tstamp:28521198035 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912677942272 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.430212: rtcpu_vinotify_event: tstamp:28521198175 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912678047712 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.486196: rtcpu_vinotify_event: tstamp:28522823730 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912721000992 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.542169: rtcpu_vinotify_event: tstamp:28524313031 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912777917184 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.542171: rtcpu_vinotify_error: tstamp:28524317438 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912778022624 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.542171: rtcpu_vinotify_event: tstamp:28524830568 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912778022624 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.598132: rtcpu_vinotify_event: tstamp:28525915549 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912820975872 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.654085: rtcpu_vinotify_error: tstamp:28527441655 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912877997504 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.654086: rtcpu_vinotify_event: tstamp:28527543247 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912877891936 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.654087: rtcpu_vinotify_event: tstamp:28527543383 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912877997504 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.654088: rtcpu_vinotify_event: tstamp:28529171127 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:912920950656 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.710048: rtcpu_vinotify_error: tstamp:28530565832 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912977972288 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.710049: rtcpu_vinotify_event: tstamp:28530798735 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:912977866880 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.710050: rtcpu_vinotify_event: tstamp:28530798924 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:912977972288 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.766021: rtcpu_vinotify_event: tstamp:28532426634 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913020925568 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.821984: rtcpu_vinotify_error: tstamp:28533690081 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913077947232 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.821985: rtcpu_vinotify_event: tstamp:28534054217 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913077841792 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.821986: rtcpu_vinotify_event: tstamp:28534054355 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913077947232 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.877949: rtcpu_vinotify_event: tstamp:28535139167 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913120900448 data:0x0000000000000021
     kworker/1:2-167     [001] .......   875.937904: rtcpu_vinotify_error: tstamp:28536814298 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913177922080 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.937905: rtcpu_vinotify_event: tstamp:28537308579 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913177816512 data:0x0000000000000011
     kworker/1:2-167     [001] .......   875.937906: rtcpu_vinotify_event: tstamp:28537308739 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913177922080 data:0x0000000000000569
     kworker/1:2-167     [001] .......   875.993882: rtcpu_vinotify_event: tstamp:28538394650 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913220875232 data:0x0000000000000021
     kworker/1:2-167     [001] .......   876.049856: rtcpu_vinotify_error: tstamp:28539938823 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913277896896 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.049857: rtcpu_vinotify_event: tstamp:28539939453 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913277791456 data:0x0000000000000011
     kworker/1:2-167     [001] .......   876.049858: rtcpu_vinotify_event: tstamp:28539939592 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913277896896 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.049858: rtcpu_vinotify_event: tstamp:28541324234 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913320850176 data:0x0000000000000021
     kworker/1:2-167     [001] .......   876.105817: rtcpu_vinotify_error: tstamp:28543062722 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913377871808 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.165773: rtcpu_vinotify_event: tstamp:28543493644 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913377766400 data:0x0000000000000011
     kworker/1:2-167     [001] .......   876.165774: rtcpu_vinotify_event: tstamp:28543493802 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913377871808 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.165774: rtcpu_vinotify_event: tstamp:28544579693 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913420825024 data:0x0000000000000021
     kworker/1:2-167     [001] .......   876.221803: rtcpu_vinotify_error: tstamp:28546186944 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913477846688 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.221807: rtcpu_vinotify_event: tstamp:28546207324 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913477741088 data:0x0000000000000011
     kworker/1:2-167     [001] .......   876.221808: rtcpu_vinotify_event: tstamp:28546207460 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913477846688 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.277731: rtcpu_vinotify_event: tstamp:28547834099 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913520799840 data:0x0000000000000021
     kworker/1:2-167     [001] .......   876.333676: rtcpu_vinotify_error: tstamp:28549311153 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913577821504 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.333678: rtcpu_vinotify_event: tstamp:28549461682 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913577716064 data:0x0000000000000011
     kworker/1:2-167     [001] .......   876.333679: rtcpu_vinotify_event: tstamp:28549461836 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913577821504 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.389641: rtcpu_vinotify_event: tstamp:28551089588 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913620774752 data:0x0000000000000021
     kworker/1:2-167     [001] .......   876.445607: rtcpu_vinotify_error: tstamp:28552435369 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913677796416 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.445608: rtcpu_vinotify_event: tstamp:28552717195 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913677690976 data:0x0000000000000011
     kworker/1:2-167     [001] .......   876.445609: rtcpu_vinotify_event: tstamp:28552717333 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913677796416 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.445610: rtcpu_vinotify_event: tstamp:28553802201 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913720749632 data:0x0000000000000021
     kworker/1:2-167     [001] .......   876.501580: rtcpu_vinotify_error: tstamp:28555559583 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913777771296 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.557565: rtcpu_vinotify_event: tstamp:28555972686 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913777665696 data:0x0000000000000011
     kworker/1:2-167     [001] .......   876.557566: rtcpu_vinotify_event: tstamp:28555972841 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913777771296 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.557568: rtcpu_vinotify_event: tstamp:28556900743 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913820724416 data:0x0000000000000021
     kworker/1:2-167     [001] .......   876.613518: rtcpu_vinotify_error: tstamp:28558683881 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913877746080 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.613519: rtcpu_vinotify_event: tstamp:28558688792 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913877640640 data:0x0000000000000011
     kworker/1:2-167     [001] .......   876.613520: rtcpu_vinotify_event: tstamp:28558688925 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913877746080 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.669472: rtcpu_vinotify_event: tstamp:28560312303 cch:-1 vi:0 tag:FE channel:0x01 frame:0 vi_tstamp:913920699328 data:0x0000000000000021
 vi-output, ovx3-2666    [007] .......   876.710256: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
        v4l2-ctl-2664    [003] .......   876.710536: tegra_channel_set_stream: enable : 0x0
        v4l2-ctl-2664    [003] .......   876.710538: tegra_channel_set_stream: ovx3c 9-0037 : 0x0
        v4l2-ctl-2664    [003] .......   876.710969: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-2664    [003] .......   876.710971: csi_s_stream: enable : 0x0
     kworker/1:2-167     [001] .......   876.725464: rtcpu_vinotify_error: tstamp:28561808011 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913977720992 data:0x0000000000000569
     kworker/1:2-167     [001] .......   876.725467: rtcpu_vinotify_event: tstamp:28561939890 cch:-1 vi:0 tag:FS channel:0x01 frame:0 vi_tstamp:913977615552 data:0x0000000000000011
     kworker/1:2-167     [001] .......   876.725468: rtcpu_vinotify_event: tstamp:28561940050 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x42 frame:0 vi_tstamp:913977720992 data:0x0000000000000569
We want to know why multiple VC configurations can cause kernel errors? Even with the addition of serdes configuration, is it an error in the reuse of i2c? How to make good modifications?
hello DDEnginee,
may I know how’s the pattern looks like when the sensor output two frames, vc0 and vc1 to CSI channel.
At present, the sensor outputs images of vc0, which I can use video0 to obtain. However, when the sensor outputs images of vc0 and Vc1, I can only obtain the image of vc1 through video1, but the image of vc0 cannot be obtained by video0. This feeling is strange, as the image obtained by vc1 looks normal
hello DDEnginee,
I meant.. how’s the streaming routing to CSI channel? how’s the VC0/VC1 coming to CSI?
it’s by default to support camera stream continuously sending to CSI brick.
Currently, we can use the sensor to obtain two frames of images, but the kernel is still reporting errors. What exactly is the problem?
hello DDEnginee,
camera software stack by default to expect camera stream sending to CSI brick continuously.
as mentioned, VC it works with GMSL Protocol, your use-case with the sensor will output two frames, vc0 and vc1 is not supported.
We also use max96717F and max96716 for serdes transmission, but there are still kernel errors. The modified dts is this reference.
hello DDEnginee,
just an FYI, your sensor running with virtual channels (VC) that were used to carry separate streams simultaneously. this is not supported at the current Jetpack release version.
please have a separate forum thread for tracking the issue with GMSL Protocol.
