Hello. When I use Franka in this case and combine it with the example code to drive the robotic arm, Franka can never find the exact position of the Cube. How should I modify it?I attached my code
# Copyright (c) 2020-2023, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
from omni.isaac.examples.base_sample import BaseSample
# This extension has franka related tasks and controllers as well
from omni.isaac.franka import Franka
from omni.isaac.core.objects import DynamicCuboid
from omni.isaac.franka.controllers import PickPlaceController
import numpy as np
from omni.isaac.core.utils.stage import add_reference_to_stage
i=0
class ManipulatorRobot(BaseSample):
def __init__(self) -> None:
super().__init__()
return
def setup_scene(self):
world = self.get_world()
world.scene.add_default_ground_plane()
# Robot specific class that provides extra functionalities
# such as having gripper and end_effector instances.
add_reference_to_stage(usd_path="D:/software/omniverse/content/isaac_sim-assets-1-2023.1.1/Assets/Isaac/2023.1.1/Isaac/Robots/Clearpath/RidgebackFranka/ridgeback_franka.usd",prim_path="/World")
franka = world.scene.add(Franka(prim_path="/World", name="fancy_franka"))
# add a cube for franka to pick up
world.scene.add(
DynamicCuboid(
prim_path="/World/random_cube",
name="fancy_cube",
position=np.array([0.3, 0.3, 0.3]),
scale=np.array([0.0515, 0.0515, 0.0515]),
color=np.array([0, 0, 1.0]),
return
async def setup_post_load(self):
self._world = self.get_world()
self._franka = self._world.scene.get_object("fancy_franka")
self._fancy_cube = self._world.scene.get_object("fancy_cube")
# Initialize a pick and place controller
self._controller = PickPlaceController(
name="pick_place_controller",
gripper=self._franka.gripper,
robot_articulation=self._franka,
self._world.add_physics_callback("sim_step", callback_fn=self.physics_step)
# World has pause, stop, play..etc
# Note: if async version exists, use it in any async function is this workflow
self._franka.gripper.set_joint_positions(self._franka.gripper.joint_opened_positions)
#await self._world.play_async()
return
def physics_step(self, step_size):
cube_position, _ = self._fancy_cube.get_world_pose()
goal_position = np.array([-0.5, 0.8, 0])
current_joint_positions = self._franka.get_joint_positions()
actions = self._controller.forward(
picking_position=cube_position,
placing_position=goal_position,
current_joint_positions=current_joint_positions,
print("cube_position "+str(cube_position))
print("current_joint_positions "+str(current_joint_positions))
self._franka.apply_action(actions)
# Only for the pick and place controller, indicating if the state
# machine reached the final state.
if self._controller.is_done():
self._world.pause()
return
# This function is called after Reset button is pressed
# Resetting anything in the world should happen here
async def setup_post_reset(self):
self._controller.reset()
return
