In the official SPI demo for spe-fw, SPI2 is used. However SPI2 is hidden in PCIe x16 connector (J6) of AGX Xavier devkit. We can’t find a convenient and reliable method to connect it. So we want to enable SPI1 based on the official SPI2 demo. The L4T verison is r32.7.3 and SPE is r32.6.1. But we encountered some issues when we flashed the firmware. We modified relevant file from both Linux kernel and spe-fw side.
We compiled the spe-fw without any error or warning, then rename to spe_t194.bin and copy to Linux_for_Tegra/bootloader/
We made sure the board in Force Recovery Mode before flash. For Xavier, we saw 7019 after running lsusb . Then the board was flashed by the following command:
sudo ./flash.sh jetson-xavier mmcblk0p1
Then the following error occurred:
[ 8.0278 ] Sending bootloader and pre-requisite binaries
[ 8.0304 ] tegrarcm_v2 --download blob blob.bin
[ 8.0320 ] Applet version 01.00.0000
[ 8.1061 ] Sending blob
[ 8.1064 ] [................................................] 100%
[ 8.9149 ]
[ 8.9194 ] tegrarcm_v2 --boot recovery
[ 8.9210 ] Applet version 01.00.0000
[ 8.9985 ]
[ 10.0041 ] tegrarcm_v2 --isapplet
[ 10.0067 ] USB communication failed.Check if device is in recovery
[ 10.1087 ]
[ 10.1134 ] tegrarcm_v2 --ismb2
The flashing process hangs. This error is similar to this topic. The debug UART may break the flashing process. And if I used the previous spe_t194.bin which enables SPI2 with official demo, it works well. I think there must be something I didn’t modify correctly for SPI1.
In addition, from TRM manual, I find that only SPI2 is the local peripheral of SPE. If I enable SPI1, the DMA channel also could be implemented correctly in function spi_app_init() in ‘l4t-rt/rt-aux-cpu-demo/app/spi-app.c’.
void spi_app_init(void)
int ret;
struct tegra_spi_client_setup spi_test_device[] = {
.chip_select = 0,
.set_rx_tap_delay = false,
.spi_max_clk_rate = SPI_TEST_CLOCK_RATE,
.spi_no_dma = false,
struct tegra_spi_master_init master_test_conf[] = {
.dma_id = &tegra_gpcdma_id_aon,
.dma_channel.tx = SPI_TEST_DMA_TX_CHANNEL,
.dma_channel.rx = SPI_TEST_DMA_RX_CHANNEL,
.dma_slave_req = GPCDMA_AO_CHANNEL_CH0_CSR_0_REQ_SEL_SPI,
I think all of values about DMA must be modified. But I don’t find any demo for it. Maybe, for SPI1, only IPO mode can be used? or maybe SPI1 can not be used in spe-fw?
I need your help to give me some advises about how to enable SPI1 on spe-fw.
