How to enable Harmonizer at training time with Nurec 26.04 container
I am following the steps in Reconstruct an AV Scene with NuRec — NVIDIA Omniverse NuRec to reconstruct my AD data.
Environment:
Container: nvcr.io/nvidia/nre/nre-ga:26.04
HW: NVIDIA GeForce RTX Blackwell
How could we enable Harmonizer at training time? I checked the available configs, and it seems that only difix.training.enabled=true will enable that at training time. However, enabling it will result in a download model error (reported at How can I enable Difix (Fixer) for training/testing? )
Do we need to use other configs, set model name, URL, etc.?
Thanks & Best Regards,
Tin Dao
You need to have EA access, (Early Access from nvidia contact point)
In next release, it doesn’t require to have EA access.
In the meantime, You might want to download from huggingface directly.
Step would be following
  • Download once (public HF)
    huggingface-cli download nvidia/difix --local-dir ./difix_weights
  • Then mount it into the container’s cache dir and point NuRec at it
    docker run … \
    –volume $(pwd)/difix_weights:/root/.cache/nre/difix \
    nvcr.io/nvidia/nre/nre-ga:26.04 \
    mode=train … \
    difix=cosmos_difix \
    difix.training.enabled=true \
    difix.cache_dir=/root/.cache/nre/difix \
    difix.model_filename=<the_downloaded_filename>.pt
then It might not hit NGC.
Thank you for your response.
I checked nvidia/difix · Hugging Face (models are in safetensors format) and tried to use it with the NuRec container but got the error below.
NuRec run command:
docker run …
–volume /work/nurec/models/difix:/workdir/difix
mode=train …
difix=cosmos_difix
difix.cache_dir=/workdir/difix/unet
difix.model_filename=diffusion_pytorch_model.safetensors
Error message:
NuRec::NRend][INFO] ::: Parsed model . with 0 particles
[NuRec::NRend][INFO] ::: Model nre::sh-gaussians => nre_sh-gaussians@26.4.146 opened
[2026-07-24 09:23:11,723][INFO] Gaussian3DNRenderer: enable_ray_based_culling: True
[2026-07-24 09:23:11,761][INFO] Loading slang module: /tmp/collector_4cd71d17.slang for configurations: [CollectorConfiguration(parameters=(‘PositionsRotationsDensitiesCollector_Deformable’, ‘ScalesCollector_Exp’, ‘SphericalFeaturesCollector_Copy<3,45>’))]
wandb: WARNING The anonymous setting has no effect and will be removed in a future version.
ValidationError
1 validation error for Settings
mode
Input should be ‘online’, ‘offline’, ‘shared’, ‘disabled’, ‘dryrun’ or ‘run’ [type=literal_error, input_value=‘’, input_type=str]
For further information visit Validation errors | Pydantic Docs
Actually, my original question was about enabling Harmonizer (nvidia/Harmonizer · Hugging Face) at training-time. I also tried to download the Harmonizer model and use it with the NuRec container but got the same error.
NuRec run command:
docker run …
–volume /work/nurec/models/harmonizer:/workdir/harmonizer
mode=train …
difix=cosmos_difix
difix.cache_dir=/workdir/harmonizer
difix.model_filename=harmonizer_nontemporal.pt
Error message:
[NuRec::NRend][INFO] ::: Parsed model . with 0 particles
[2026-07-24 09:39:50,876][INFO] Gaussian3DNRenderer: enable_ray_based_culling: True
[2026-07-24 09:39:50,928][INFO] Loading slang module: /tmp/collector_4cd71d17.slang for configurations: [CollectorConfiguration(parameters=(‘PositionsRotationsDensitiesCollector_Deformable’, ‘ScalesCollector_Exp’, ‘SphericalFeaturesCollector_Copy<3,45>’))]
ValidationError
mode
Do we need to change/add other configs to make it work?
Tin Dao
You might try following, (It happens earlier because an empty WANDB_MODE is passed into the container. Removing WANDB_MODE, setting it to disabled, or adding logger=dummy fixes it.)
-e WANDB_MODE=disabled \
-v “$PWD/harmonizer_weights:/root/.cache/nre/harmonizer:ro” \
mode=train \
logger=dummy \
difix.cache_dir=/root/.cache/nre/harmonizer \
difix.model_url=https://huggingface.co/nvidia/Harmonizer/resolve/main/harmonizer_nontemporal.pt \
difix.model_filename=harmonizer_nontemporal.pt \
difix.model_resolution=‘[576,1024]’
Thank @dkoy8927,
Your command works, and I could train with harmonizer_nontemporal. However, the result was not good with my data. Therefore, I tried to use “temporal harmonization” with the command:
mode=train
logger=dummy
difix=cosmos_difix
difix.model_url=https://huggingface.co/nvidia/Harmonizer/resolve/main/diffusion_harmonizer.pkl
difix.model_filename=diffusion_harmonizer.pkl
difix.model_resolution=[576,1024]
Unfortunately, I got the following errors. Do we need to add other configs to use temporal harmonization?
[2026-07-27 10:50:39,577][INFO] Using cached Difix model (/workdir/models/harmonizer/diffusion_harmonizer.pkl).
[2026-07-27 10:50:39,578][INFO] DifixModelFactory: checkpoint ready at /workdir/models/harmonizer/diffusion_harmonizer.pkl
[2026-07-27 10:50:39,578][INFO] Using cached Difix model (/workdir/models/harmonizer/diffusion_harmonizer.pkl).
[2026-07-27 10:50:40,368][INFO] Loading model with TE saved at /workdir/models/harmonizer/diffusion_harmonizer.pkl, True
[2026-07-27 10:50:40,368][INFO] has rmsnorm_fwd_inf_ts: True
RuntimeError
PytorchStreamReader failed locating file constants.pkl: file not found
Tin Dao
diffusion_harmonizer.pkl cannot be used as a drop-in replacement for harmonizer_nontemporal.pt in NuRec 26.04. The cosmos_difix integration is invoking the TorchScript loader, while diffusion_harmonizer.pkl is the full temporal checkpoint used by the standalone NVIDIA/harmonizer Python pipeline. The missing constants.pkl error confirms the checkpoint-format mismatch.
You need to wait next release
