Hi, Guys,
The Orin can boot into linux kernel shell but w/o HDMI output on our customized carry board with JP5.0_DP. As far as we know, the Devkit w/o HDMI port, but work w/ DP.
Refer to the Orin TRM, there’s a Cortex-R5, which run the firmware “dce.bin” (which reside on “A_dce-fw” and “B_dce-fw” partitions) to driver the Display Controller unit, so if that means need a special version of “dce.bin” firmware to support the HDMI output? How can I enable HDMI output base on it? Thank you!
Thanks,
Haiping
