How to enable IEEE1588 ptp on orin sdk
Hello NV Supprot teams:
We use the AGX orin development platform for autonomous driving applications.
SDK version is JetPack 5.0.2, bsp version is linux 35.1.
Please tell us how to porting PTP network synchronization protocol. Is there a step-by-step user guide? Thank you.
please check if this helps.
Hi ,Wayne
We will check and feedback to you,thanks.
Hi ,WayneWWW
How to verify PTP network sync when we use single orin with a linux virtual machine?
No idea. no experience with that.
Hi Wayne
We use sdk verision is Jetson Linux 35.1,kernel version is kernel-5.10.
Please confirm whether this version supports IEEE 1588v2 protocol,thanks.
My previous comment means I don’t know about your usecase between a Orin and linux VM.
Did you try that PTP test on 2 Orin device?
Hi Wayne
I understand what you said in the last reply, We only have one orin device right now.
We will confirm the dual orin use case after a few days.
Jetson Linux 35.1 supports PTP or not, we want to make sure.
Hi wayne
we used two orin device to test ptp as follows:
Host side
ifconfig eth0 down
ifconfig eth0 up
ifconfig eth0 0.0.0.0
ip addr add 10.0.0.1/24 dev eth0
ip link set dev eth0 up
timedatectl set-ntp false
date 010100002018
phc_ctl /dev/ptp0 set
phc_ctl /dev/ptp0 get
Slave side
ifconfig eth0 down
ifconfig eth0 up
ip addr add 10.0.0.2/24 dev eth0
The date obtained from the slave is January 1, 1970, not January 1, 2008. Please give me some advice, thank you.
Could we just forget about what you are doing now and just run below commands and share result first?
host
$ sudo ptp4l -i eth0 -m
Slave
$ sudo ptp4l -i eth0 -m -s
According to your suggestion, the result is as follows:
Eth0 as master, eth1 is slave.
Hi , have any news for this issue?
We are checking this. Will reply later.
We tried the phc_ctl script to sync up time. Before doing phc_ctl to sync time, you need to run ptp4l command too.
Master:
Slave:
[Master]
# phc_ctl /dev/ptp0 get
phc_ctl[92332.285]: clock time is 1514764821.904995580 or Mon Jan  1 00:00:21 2018
[Slave]
phc_ctl[3678.214]: clock time is 0.000000000 or Thu Jan  1 00:00:00 1970
After start running ptp command and check on Slave:
phc_ctl[4491.644]: clock time is 1514765726.075818891 or Mon Jan  1 00:15:26 2018
Hi ,The test results are as follows:
Please help us to check ,thanks.
可以麻煩你先自己讀一下你們那邊顯示的error log嗎
比方說我看到上面直接寫 “no such device”…
Hi ,Sirs
To summarize the test steps.
Host side:
ifconfig eth0 down
ifconfig eth0 up
date 010100002018
Slave side:
ifconfig eth down
ifconfig eth0 up
We still did not get the exact host time, may I ask whether this test sequence is correct or wrong?
Sorry for the late response, is this still an issue to support? Thanks
We have fixed this issue, thanks.
Glad to know issue resolved, would you might to share the root case and how to fix it? Thanks
