- Basic Info:
hardware: jetson-agx-orin-devkit
JetPack : 6.2
Jetson Linux : 36.4.3
I already build the uefi as the wiki say, The default build not enable more debug log
But I want to enable more debug info, how to config it or enable
JetPack : 6.2
To enable more debug logs in the UEFI build for Jetson AGX Orin, you’ll need to modify the UEFI configuration. Here’s a step-by-step guide to help you achieve this:
Config.plist or platform.config. This file contains the build settings and configuration options for the UEFI firmware.DEBUG settings in the Config.plist file. You can do this by adding or modifying the following lines:<key>DEBUG</key>
<dict>
<key>DEBUG_LOG_LEVEL</key>
<string>DEBUG</string>
<key>DEBUG_LOG_MODULES</key>
<array>
<string>ALL</string>
</array>
</dict>
This will set the debug log level to DEBUG and enable logging for all modules.
Config.plist file, you’ll need to rebuild the UEFI firmware using the build_uefi.sh script (or the equivalent command for your build environment).flash.sh script (or the equivalent command for your build environment).Comparison with other Jetson modules:
The process of enabling debug logs in the UEFI build is similar across different Jetson modules, including Jetson Orin NX and Jetson Orin Nano. However, the specific configuration files and build scripts may vary depending on the module and the version of the Jetson Linux Developer Guide you are using.
Additional tips:
Config.plist file before modifying it, in case you need to revert to the original settings.DEBUG_LOG_MODULES array. For example:<key>DEBUG_LOG_MODULES</key>
<array>
<string>PCIe</string>
<string>USB</string>
</array>
This will enable debug logs only for the PCIe and USB modules.
By following these steps, you should be able to enable more debug logs in the UEFI build for your Jetson AGX Orin device.
