Is it possible to using tegraflash.py to erase data on Nano eMMC, like this post ?
Could help provide the command ? Thanks
How to Clear the Data on eMMC - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums
You can check your flash log from flash.sh. It should include the content to erase the disk.
Hi Wayne,
The log tell us that script can help erase APP partition “tegradevflash --instance 2-1.5 --pt flash.xml.bin --storageinfo 22434_storage_info.bin --erase APP”. Can we also using the same script to erase the other partitions with type: boot_config_table, bootloader, partition_table, WB0 ?
You can try. Don’t guarantee it would work.
sudo ./tegraflash.py --chip 0x21 --applet nvtboot_recovery.bin --bl cboot.bin --cmd “erase <partition_name>”
From the beginning, we only suggest user to follow the official way to use tool. Official way means
May I know the official way is ??
Official way means flash.sh. There is no method to directly only erase emmc.
