Hi all,
I created a new partition CFG to store user config data in this way such as below page:
But,when I packaged firmware with nvmassflashgen.sh script, and then burned with nvmflash.sh ,i found that my partition data was erased and cfg data was gone.
So,How can I keep my config data partition from being erased by nvmflash.sh burned.
did you modify the Nano’s default xml file, or you have a customize xml file to define your partition layout.
could you please try the normal flash.sh for flashing, are you able to see your user defined partition?
hello JerryChang,
I modified the xml, my partition is normal and mount succeed, and I can see my defined partition data, but the problem is, my partition be erased by nvmflash.sh upgrade.
hello JerryChang,
i reviewed it. my partition exists but it was formatted and the partition data was gone, i found that the upgrade will erases all partition information
hello zndxwjun,
what’s your step in detail, did you have apt upgrade in your process?
