Hi,all
in jetpack 4.6.x we can use below method to control GPIO pin
sudo busybox devmem 0x02430038 w 0x054 # soc_gpio43_pq7:
echo 423 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio423/direction
echo 1 > /sys/class/gpio/gpio423/value
how about in jetpack 5.0.2?
and how to check GPIO setting in jetpack 5.0.2?
below is in 4.6.x method
sudo cat /sys/kernel/debug/tegra_pinctrl_reg | grep soc_gpio43
Moving this topic to the Jetson category for better visibility.
Discussions relating to the Jetson DevKits and other Embedded computing devices
hello ashingtsai,
you may have the same process as JP-4.6 to toggle the pin.
however, the GPIO numbers has changed since k-5.10, please also refer to developer guide, Identifying the GPIO Number .
thanks
this portion i already know ,thank you.
Since the GPIO numbers have changed in JP 5.0.2, does that mean I can’t use the same pinmux file from JP 4.6, even though the hardware is the same?
