please refer to the following discussion. The major steps are described. You need to adapt the instructions to your media storage.
Please keep in mind that in this case the componets that are being offloaded to a second media are the kernel and kernel device tree. The primary storage media can still be mounted.
Thanks for your all reply. I could copy the rootfs to external eMMC and boot the system from external eMMC successfully.
I still meet a problem. I had to modify the extlinux.conf in rootfs that at the Jetson Nono’s internal eMMC to changed that the device will be booted from the external eMMC.
But If I format the Jetson Nano’s internal eMMC. The device will not boot into the system.
Is it possible to flash whole image via basic flashing procedures likes below?
