Jetson nano Flash emmc -> sd card
Hi. I want to flash Jetson nano emmc(P3448-0020/P3449-0000) → Jetson nano devkit(P3448-0000/P3449-0000)
What should I do?
I’ve tried
sudo ./flash -r jetson-nano-emmc mmcblk0p1
sudo ./flash -r jetson-nano-devkit mmcblk0p1
sudo ./flash -r -k APP jetson-nano-devkit mmcblk0p1
but I failed to boot.
Hi jahanda
Have you tried to flash board through NVIDIA SDK Manager?
Or you can refer to the following flash procedure
Quick Start — Jetson Linux<br/>Developer Guide 34.1 documentation
I also want to add, other than flashing through SDKM, if you do a command line flash, have you considered flashing everything (which takes barely any more time)? Example:
sudo ./flash jetson-nano-emmc mmcblk0p1
I say this because it sounds like the boot content is failing. You can’t just flash the rootfs/APP unless all other content is correct and matches the release of the rootfs.
I succeeded flash emmc to sd_card.
The reason for the failure was that I tried it with a formatted sd card.
After installing the jetpack on the sd card and upgrading the apt, I tried sudo./flash -r -k APP Jetson-nano-devkit mmcblk0p1 and succeeded.
Thank you.
Additionally, it failed without apt update and apt upgrade.
