Cosmos Transfer 2.5: Keeping Isaac Sim materials vs adding visible rain (vis fixes drift, but rain becomes invisible)
Hi all — I’m using Cosmos Transfer 2.5 (Control2World / World Transfer) to create outdoor weather variations (light→visible rain) from an Isaac Sim scene for robotics training. I ran into two linked problems:
Without appearance anchoring, the model “repaints” the world (water becomes asphalt, textures disappear, terrain changes).
After fixing that drift by adding vis control, the scene identity is preserved… but now rain is basically invisible, even when I push the prompt.
I’d appreciate guidance on the right way to get clearly visible rain while preserving Isaac Sim materials.
Setup
Windows 11 + WSL2 (Ubuntu) + Docker Desktop
NVIDIA GPU: Blackwell Pro 6000
Cosmos Transfer2.5 running in Docker with
/workspacemounted to repo and/datamounted to~/cosmos_data -
Inputs: Isaac Sim exported:
rgb.mp4 -
edges.mp4 -
depth.mp4
Important: my model expects a 93-frame chunk (state_t=24 → pixel_frames=(24−1)*4+1=93), so I run:
max_frames: 93 -
num_video_frames_per_chunk: 93
What I see (please refer to attached videos)
(Video 1) Baseline Isaac Sim render (no Cosmos)
➡️ Correct materials/textures: sea looks like sea, dock concrete texture correct, container materials/logos correct.
(Video 2) First Cosmos rain attempt (edge+depth only)
➡️ Rain appears, but major semantic/material drift:
Sea/water region turns into asphalt/ground
Carefully authored textures/logos get washed out / repainted
Background asphalt/ground turns into green grass / terrain change
Basically the scene identity is lost.
(Video 3) Cosmos with vis control added (edge+depth+vis)
➡️ Scene identity is preserved (sea stays water, textures mostly preserved), but:
Rain is so subtle it’s effectively invisible
Minor issue: container text/logos get smeared, but the bigger issue is no visible raindrops
(Video 4) “More rain” attempt (higher guidance/steps, rain-heavy prompt)
➡️ Still no visible raindrops. Looks like the original scene with slightly different lighting at most.
Working configs (shortened)
A) Drift case (rain visible, but scene repainted)
"prompt": "Realistic rainy weather... wet surfaces...",
"negative_prompt": "...",
"guidance": 3.0,
"num_steps": 35,
"max_frames": 93,
"num_video_frames_per_chunk": 93,
"edge": { "control_path": ".../edges.mp4", "control_weight": 1.0 },
"depth": { "control_path": ".../depth.mp4", "control_weight": 1.0 }
B) Identity preserved (but rain invisible)
"prompt": "Apply a light rain overlay to the existing video. Preserve original textures/materials. Keep sea water as water. No terrain changes.",
"negative_prompt": "grass, vegetation, terrain change, material change, repainting, water turning into ground, texture removal, ...",
"guidance": 3.0,
"num_steps": 30,
"max_frames": 93,
"edge": { "control_path": ".../edges.mp4", "control_weight": 0.9 },
"depth": { "control_path": ".../depth.mp4", "control_weight": 0.6 },
"vis": { "control_weight": 0.7 }
C) “More rain” attempt (still invisible)
"prompt": "Apply a clearly visible rain overlay... Add visible rain streaks/raindrops, splashes, ripples on water...",
"negative_prompt": "terrain/material change, repainting, grass, ...",
"guidance": 5.0,
"num_steps": 45,
"max_frames": 93,
"vis": { "control_weight": 0.6 }
My question to the community
What is the recommended way in Cosmos Transfer 2.5 to get clearly visible rain without repainting the scene?
Specifically:
Control weight strategy:
Is there a best-practice range forvisvsedge/depthwhen you want appearance preservation but also strong weather effects?-
Should
visbe lower (e.g. 0.3–0.5) and compensate with guidance/steps? -
Does Cosmos normalize weights internally when sum > 1.0, and does that affect how strong the edit can be?
Prompting strategy:
Is there a known prompt pattern that produces visible raindrops (streaks, splashes) rather than only “wet look”?
Should the prompt focus on “overlay” only, or are there recommended tokens / phrasing Cosmos responds to? -
Do I need segmentation/masks for water & ground?
If rain requires more freedom (lower vis), is the right approach to use segmentation masks (freeze water region / freeze textures) so the model can add rain but not change materials? -
Is there a limitation here?
Is Cosmos Transfer more tuned for lighting/wetness changes than explicit raindrop particles?
If so, do you recommend adding visible rain as a post-process (RTX renderer / compositing) while using Cosmos only for lighting/wetness?
I can share full logs/configs if needed — but the key symptoms are:
Edge+depth only → rain appears, but world repaints (water→asphalt, textures→gone, grass appears)
Add vis → identity preserved, but rain becomes nearly invisible, even with stronger prompt/steps
Thanks in advance!
