Maintain Ground Truth in Cosmos-Transfer2.5
Hi Team,
I am trying to generate a synthetic data (video) where only environment should be changed. I am using cosmos-transfer2.5. I have multiple format videos like rbg, segmented, edge and depth. These are used as input. I have added a text input mentioning the scene along with the changes in the environment. I am giving control parameters as edge at 1 and segmentation at 0.4-0.8 and depth at 0.6-1. But the output is varying very much. It is not retaining the ground truth as seen on the rgb video.
How to achieve this? I want everything that is seen on rgb video as same only the weather/environment to be changed.
Have you taken a look at the Cosmos Cookbook? This would be the first place to check best practices. For example in the robotics section the examples shown have the full parameters, and you should be able to repro to get a baseline.
