How to get depth image in Isaac sim
The version I used is 4.0.0, and I used the following code to try to get the depth image, but it failed. How to get depth image?
self._camera = scene.add(Camera(
            prim_path="/World/camera1",
            name="camera1",
            position=self.camera_position,
            frequency=20,
            resolution=(256, 256),
            orientation=rot_utils.euler_angles_to_quats(np.array([0, 20, 180]), degrees=True),
self._camera.initialize()
self._camera.add_motion_vectors_to_frame()
self._camera.add_distance_to_camera_to_frame()
self._camera.get_data() # error 'Camera' object has no attribute 'get_data'
self._camera.get_depth() # return None
setup the depth annotator
you can find more information on the depth annotator here:
https://docs.omniverse.nvidia.com/extensions/latest/ext_replicator/annotators_details.html
thank you! I solved the problem using the following code.
self._camera.get_current_frame()["distance_to_camera"]
Well done!
