Hello, I am publishing a depth image using ROS1 Camera Helper. I am trying to get the depth from an object of in these scene to the camera. But when I am subscribing in ROS and performing the decoding the values are strange. I am confused if its about the unit Issac sim uses or my interpretation in ROS. Would really appreciate some help.
cv_bridge::CvImagePtr cv_ptr = cv_bridge::toCvCopy(msg, sensor_msgs::image_encodings::TYPE_32FC1);
float depth_value = depth_image.at(center_x, center_y);
