Calculate Distance from Isaac sim depth images
I am new to Omniverse and I want to use Isaac sim to generate synthetic images. I want to ask if there is a way we can predict the distance (in any distance unit) of an object to the camera by using the generated depth images’ numpy files.
Hi @toufic.kashmar. Welcome to the forums! Let me check with the dev team on that.
The devs say you can use numpy.load() to read the images and check the distances per pixel:
import numpy as np
path = r"C:\path\to\distance_to_camera_16.npy"
test = np.load(path)
The distances represent distance from the camera in meters.
Thank you @mati-nvidia for your answer.
I am actually using the np.load() function, but I am not sure what the values of the array stand for. What do the returned values of the npy array mean?
@toufic.kashmar The dev team has informed me that the units are in meters. The depth map represents distance from camera.
