In my project, I was trying to send camera data (rgb and depth) into ROS, and then convert it to point cloud via this node http://wiki.ros.org/depth_image_proc
While using it with gazebo, it works out perfectly:
Original pointcloud, published by simulated camera:
Estimated pointcloud from depth image:
Both pointclouds in the same time:
As can be seen it’s pretty the same, what means, that this node works, as expected. But when I’m trying to use same node with data from Isaac Sim, point cloud look distorted and shifted:
BTW, here is depth image from GazeboSim:
And from Isaac Sim:
Looks like CamerInfo, or Depth Image itself is wrong in Isaac Sim. Is it planned by the Isaac Sim team, to implement point cloud publishing from a simulated camera? Or maybe you have a solution, how to fix this problem?
