We want to simulate a 3D depth camera in Isaac Sim to move the axis of a robot and for AI but without the use of the Isaac SDK and a “simulated robot”. But we can’t find any examples or references for this. Is that possible or is the SDK always needed for simulation?
Hi @jo-mo - You can find more information about depth here: 3. Cameras — Omniverse IsaacSim latest documentation
I have tested all the things in the documentation with ROS2 and it worked. But is there no way to do the 3D-depth part without the use of ROS2 or Isaac SDK ? We just want to use Issac Sim (and Python, Actiongraph etc.) like in the Leonardo Demo. But unfortunately the 3D cameras there are not simulated.
Hi there
would using depth data from replicator annotators work for your case?
You can take a look at this snippet example on how to access annotator data:
- Frequently Used Python Snippets — Omniverse IsaacSim latest documentation
Best,
Andrei
the code in the snippets only work in standalone mode, but not as code in an extension. When running it as extension I will only get errors when calling world.step() and if I don’t call it, I will get empty data from the annotators.
I see, when used in extension or script editor you should use step_async, here is an example on how you can do that:
I came across this thread while working on a similar depth-camera simulation problem, and it’s interesting to see how the discussion started around Replicator depth annotators.
We recently worked on a related approach where the goal was to simulate a specific physical iToF depth camera in Isaac Sim, rather than using only a generic simulated depth sensor.
The interesting part for us was being able to model the physical camera characteristics — including:
- resolution and depth modes
- depth range
- field of view
- camera geometry
- calibration and transforms
- ROS 2 topics for depth, point clouds and IMU data
This makes it possible to use the simulated camera for things like camera placement, coverage analysis and multi-camera configurations before moving to the physical hardware.
We also tried this in two scenarios: a UR10 manipulation setup and a four-camera AMR navigation setup.
For anyone still working on this type of problem, I’m curious how you’re approaching it today. Are you mainly using Isaac Sim’s built-in/Replicator depth capabilities as a generic sensor, or are you trying to model the characteristics of a specific physical depth camera for sim-to-real development?
We documented our approach here:
