How to get video-viewer.py to receive stream from raspberry pi
I have the following on a raspberry pi zero w,
raspivid -t 0 -w 1296 -h 730 -fps 30 -b 2000000 -awb auto -n -o - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=0.0.0.0 port=8554
rpi ip address set to static = 10.0.0.15
and on the Jetson Nano, running Jetpack 4.4 openvc 4.5.2 compiled with cuda support, able to receive video feed from rpi using the following python code without lag.
-----xxxxxxxxxxxxxxxxxxxx------------------xxxxxxxxxxxxxxxxxxxxxxx
import cv2
print(cv2.version)
dispW=1296
dispH=730
flip=2
tested working parameter
camSet=’ tcpclientsrc host=10.0.0.15 port=8554 ! gdpdepay ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv flip-method=β€˜+str(flip)+’ ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw, width=β€˜+str(dispW)+’, height=β€˜+str(dispH)+’,format=BGR ! appsink drop=true sync=false ’
cam= cv2.VideoCapture(camSet)
while True:
ret, frame = cam.read()
cv2.imshow(β€˜nanoCam’,frame)
#cv2.moveWindow(β€˜nanoCam’,0,0)
if cv2.waitKey(1)==ord(β€˜q’):
break
cam.release()
cv2.destroyAllWindows()
I would like to use the following nice tool but I am having zero luck!!
run as:
I have tried this β€œpython3 video-viewer.py rtp://10.0.0.15:8554 --input-codec=h264” and no dice.
(I have a reolink ip camera, and the video-viewer.py works with that stream on the jetson nano although its very delayed video etc)
getting following error, if anyone can guide in the right direction, would appreciate your help (I am not most familiar with gstreamer and all of the things that going on etc):
test@nano-desktop:~/jetson-inference/build/aarch64/bin$ python3 video-viewer.py rtp://10.0.0.15:8554 --input-codec=h264
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstDecoder – creating decoder for 10.0.0.15
[gstreamer] gstDecoder – resource discovery not supported for RTP streams
[gstreamer] gstDecoder – pipeline string:
[gstreamer] udpsrc port=8554 multicast-group=10.0.0.15 auto-multicast=true caps=β€œapplication/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264” ! rtph264depay ! h264parse ! omxh264dec ! video/x-raw ! appsink name=mysink
[video] created gstDecoder from rtp://10.0.0.15:8554
gstDecoder video options:
– URI: rtp://10.0.0.15:8554
- protocol: rtp
- port: 8554
– deviceType: ip
– ioType: input
– codec: h264
– width: 0
– height: 0
– frameRate: 0.000000
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: none
– loop: 0
– rtspLatency 2000
[OpenGL] glDisplay – X screen 0 resolution: 2560x1440
[OpenGL] glDisplay – X window resolution: 2560x1440
[OpenGL] glDisplay – display device initialized (2560x1440)
[video] created glDisplay from display://0
glDisplay video options:
– URI: display://0
- protocol: display
– deviceType: display
– ioType: output
– codec: raw
– width: 2560
– height: 1440
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: none
– loop: 0
– rtspLatency 2000
[gstreamer] opening gstDecoder for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstDecoder – failed to set pipeline state to PLAYING (error 0)
video-viewer: failed to capture video frame
video-viewer: shutting down…
video-viewer: shutdown complete
Hi @therock112, can you try changing to udpsink and removing gddpay? Also insert the IP address of your Jetson where it says $JETSON_IP
raspivid -t 0 -w 1296 -h 730 -fps 30 -b 2000000 -awb auto -n -o - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! udpsink host=$JETSON_IP port=8554
And then run video-viewer like this:
python3 video-viewer.py rtp://@:8554 --input-codec=h264
made the recommended changes and still getting failed to capture video frame error
tried the python video-viewer.py code which just sits and then I also tried the c compiled video-viewer and getting the following info:
any suggestions?
test@nano-desktop:~/jetson-inference/build/aarch64/bin$ ./video-viewer rtp://@:8554 --input-codec=h264
[gstreamer] gstDecoder – creating decoder for 127.0.0.1
[gstreamer] udpsrc port=8554 multicast-group=127.0.0.1 auto-multicast=true caps=β€œapplication/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264” ! rtph264depay ! h264parse ! omxh264dec ! video/x-raw ! appsink name=mysink
[video] created gstDecoder from rtp://@:8554
– URI: rtp://@:8554
- protocol: rtp
- port: 8554
– deviceType: ip
– ioType: input
– codec: h264
– width: 0
– height: 0
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: none
– loop: 0
– rtspLatency 2000
– URI: display://0
- protocol: display
– ioType: output
– codec: raw
– width: 2560
– height: 1440
– bitRate: 0
– numBuffers: 4
– zeroCopy: true
– flipMethod: none
– loop: 0
– rtspLatency 2000
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from NULL to READY ==> h264parse0
[gstreamer] gstreamer changed state from NULL to READY ==> rtph264depay0
[gstreamer] gstreamer changed state from NULL to READY ==> udpsrc0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer changed state from READY to PAUSED ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> h264parse0
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtph264depay0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> udpsrc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> h264parse0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtph264depay0
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> udpsrc0
If you run ifconfig on your Jetson, do you see the RX packets/data increasing after you start the streaming from the rPi?
In the meantime, since you already have it working with cv2.VideoCapture(), you can use cudaFromNumpy() function to convert it to CUDA image like in this example:
https://github.com/dusty-nv/jetson-utils/blob/c373f49cf21ad2cae7e4d7da7c41f4fd6473958f/python/examples/cuda-from-cv.py#L45
what I would really like to do is feed the video stream from the raspberry pi into the following following detectnet code:
Yep. def seeing a ton of packets coming into the Jetson nano from the rpi. Not sure why the python code cant display the video stream.
Since you have the video decoding working through cv2.VideoCapture, try modifying the script like so:
# input = jetson.utils.videoSource(opt.input_URI, argv=sys.argv)  # comment this out
output = jetson.utils.videoOutput(opt.output_URI, argv=sys.argv+is_headless)
cam = cv2.VideoCapture(camSet)
rgb_img = None
while True:
  ret, cv_frame = cam.read()
  bgr_img = jetson.utils.cudaFromNumpy(cv_img, isBGR=True)
  if rgb_img is None:
      rgb_img = jetson.utils.cudaAllocMapped(width=bgr_img.width,
							                 height=bgr_img.height,
							                 format='rgb8')
  jetson.utils.cudaConvertColor(bgr_img, rgb_img)
  detections = net.Detect(rgb_img)
  output.Render(rgb_img)
its working!! Thank you @dusty_nv !!
for anyone interested, run the following on the Nano, the sender runs on a raspberry pi zero with wifi:
use the tcp streamer posted above and receive with the below with detection, has about .5 second to 1 second delay, not bad!
import argparse
import sys
print(cv2.version)
dispW=1296
dispH=730
flip=2
camSet=’ tcpclientsrc host=IP of Streamer port=your_srvr_port ! gdpdepay ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv flip-method=β€˜+str(flip)+’ ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw, width=β€˜+str(dispW)+’, height=β€˜+str(dispH)+’,format=BGR ! appsink drop=true sync=false’
parser = argparse.ArgumentParser(description=β€œLocate objects in a live camera stream using an object detection DNN.”,
formatter_class=argparse.RawTextHelpFormatter, epilog=jetson.inference.detectNet.Usage() +
jetson.utils.videoSource.Usage() + jetson.utils.videoOutput.Usage() + jetson.utils.logUsage())
parser.add_argument(β€œinput_URI”, type=str, default=β€œβ€, nargs=β€˜?’, help=β€œURI of the input stream”)
parser.add_argument(β€œoutput_URI”, type=str, default=β€œβ€, nargs=β€˜?’, help=β€œURI of the output stream”)
parser.add_argument(β€œβ€“network”, type=str, default=β€œssd-mobilenet-v2”, help=β€œpre-trained model to load (see below for options)”)
parser.add_argument(β€œβ€“overlay”, type=str, default=β€œbox,labels,conf”, help=β€œdetection overlay flags (e.g. --overlay=box,labels,conf)\nvalid combinations are: β€˜box’, β€˜labels’, β€˜conf’, β€˜none’”)
parser.add_argument(β€œβ€“threshold”, type=float, default=0.5, help=β€œminimum detection threshold to use”)
is_headless = [β€œβ€“headless”] if sys.argv[0].find(β€˜console.py’) != -1 else [β€œβ€]
try:
opt = parser.parse_known_args()[0]
except:
print(β€œβ€)
parser.print_help()
sys.exit(0)
load the object detection network
net = jetson.inference.detectNet(opt.network, sys.argv, opt.threshold)
rgb_img = None
bgr_img = None
while True:
bgr_img = jetson.utils.cudaFromNumpy(cv_frame, isBGR=True)
if rgb_img is None:
rgb_img = jetson.utils.cudaAllocMapped(width=bgr_img.width, height=bgr_img.height, format=β€˜rgb8’)
break
cam.release()
I am trying to stream RTP from a Pi Zero to video-view on a the Jetson Nano 2GB. I am trying to follow c++ track on the jetson-inference tutorial. So far, I am still trying to set things up. I’ve got the LogiTech USB camera to work but my goal is to use multiple Pi Zeros to stream video to the Jetson Nano. I’ve also got the Pi Zero streaming RTSP using vlc. I was able to view the stream using
video-viewer with the following
rtsp://192.168.0.45:8554/stream
where 192.168.0.45 is the Pi Zero’s IP address.
But as @dusty_nv pointed out in the project video, RTSP with vlc has high latency. For me it was 3 to 4 sec delay in the video. I was hoping RTP would help.
So far, I have not been successful following what @dusty_nv suggested here. I still got β€œvideo-viewer: failed to capture video frame” message and nothing displayed.
I’ve played around with what was suggested and kept adding more parameters in the video-viewer but that did not seem to help. I did check the RX packet size on the Jetson Nano and it seems to be receiving packets. Below is what I ran on the Raspberry Pi Zero and it’s terminal output (192.168.0.39 is the Jetson Nano’s IP address)
pi@raspberrypi:~ $ raspivid -o - -t 0 -rot 90 -w 1296 -h 730 -fps 30 -b 2000000 | gst-launch-1.0 -v fdsrc ! h264parse !
 rtph264pay config-interval=1 pt=96 ! udpsink host=192.168.0.39 port=8554
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, width=(int)1296, height=(int)730, framerate=(fraction)0/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, profile=(string)high, level=(string)4, codec_data=(buffer)01640028ffe1000f27640028ac2b402882efc900f1226a01000528ee025cb0
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)640028, sprop-parameter-sets=(string)"J2QAKKwrQCiC78kA8SJq\,KO4CXLA\=", payload=(int)96, ssrc=(uint)2051456017, timestamp-offset=(uint)2088241829, seqnum-offset=(uint)13688
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)640028, sprop-parameter-sets=(string)"J2QAKKwrQCiC78kA8SJq\,KO4CXLA\=", payload=(int)96, ssrc=(uint)2051456017, timestamp-offset=(uint)2088241829, seqnum-offset=(uint)13688
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:sink: caps = video/x-h264, width=(int)1296, height=(int)730, framerate=(fraction)0/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, profile=(string)high, level=(string)4, codec_data=(buffer)01640028ffe1000f27640028ac2b402882efc900f1226a01000528ee025cb0
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: timestamp = 2088241829
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: seqnum = 13688
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
And, here is what I typed into the Jetson Nano and it’s output
root@jetsonNano1:/jetson-inference# video-viewer rtp://@:8554 --input-codec=h264 --input-width=1296 --input-height=730 --frameRate=30 --input-rate=2000000
[gstreamer] gstDecoder -- creating decoder for 127.0.0.1
[gstreamer] gstDecoder -- resource discovery not supported for RTP streams
[gstreamer] gstDecoder -- pipeline string:
[gstreamer] udpsrc port=8554 multicast-group=127.0.0.1 auto-multicast=true caps="application/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264" ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw, width=(int)1296, height=(int)730, format=(string)NV12 ! videorate drop-only=true max-rate=2000000 ! appsink name=mysink
  -- URI: rtp://@:8554
     - protocol:  rtp
     - port:      8554
  -- deviceType: ip
  -- ioType:     input
  -- codec:      h264
  -- width:      1296
  -- height:     730
  -- frameRate:  2000000.000000
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
[OpenGL] glDisplay -- X screen 0 resolution:  1920x1080
[OpenGL] glDisplay -- X window resolution:    1920x1080
[OpenGL] glDisplay -- display device initialized (1920x1080)
  -- URI: display://0
     - protocol:  display
  -- deviceType: display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- frameRate:  30.000000
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
[gstreamer] gstreamer changed state from NULL to READY ==> videorate0
[gstreamer] gstreamer changed state from NULL to READY ==> nvvconv0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videorate0
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvvconv0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videorate0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvvconv0
I know that @therock112 had this working in code. I am not at the stage to learn the coding yet. For now, I just want to get the Pi Zero streaming to work so I can continue the tutorial. With the Pi Zero wirelessly connected, it can be placed in a more convenient spots for experimentation and future demonstration.
Hi @francis.tse, here is the pipeline that I run from PC to generate a test RTP feed - I use this to test the reception/decode of RTP on the Jetson:
  • Remote host
    • gst-launch-1.0 -v videotestsrc ! video/x-raw,width=300,height=300,framerate=30/1 ! x264enc ! rtph264pay ! udpsink host=127.0.0.1 port=5000
  • On the Jetson
    • video-viewer rtp://@:5000
Can you try running that just to confirm that you can receive/view RTP ok on your Jetson?
From there, you can work backwards and narrow down what is different about the feed coming from the rPI. At a glance, I would start with trying a more standard resolution first (e.g. 1280x720)
Since I did not have a suitable PC to generated the test RTP feed, I used the Pi Zero to run the gst-launch command. To check if the Jetson is receiving the feed, I followed the Camera Streaming and Multimedia page to use vlc media player by creating a .sdp file on the Jetson with the following content
c=IN IP4 192.168.0.39
m=video 5000 RTP/AVP 96
a=rtpmap:96 H264/90000
When I double click on the file, vlc media player was launched and after some delay showed a color bar test pattern with a random B/W noise square on the lower right hand corner. To make sure this was generated by my command from the Pi Zero, I tried stopping the command on the Pi Zero and the vlc output on the Jetson stopped. I also increase the width and height in the command to 600x600 and the output size on the vlc player changed as expected. So it appears that the Pi Zero is generating the RTP output and the Jetson is receiving it.
However, I could not get it to work with video-viewer. Actually, I had to add --input-codec=h264 to the video-viewer command, otherwise I got a β€œfail to create decode for rtp://@5000” message. But, even with that, I still got β€œfailed to capture video frame”.
I tried replacing @ with the actual IP address of the Jetson which is 192.168.0.39. I also tried adding the input width and height but that still did not work. The following is the output I got from running video-viewer
root@jetsonNano1:/jetson-inference# video-viewer rtp://192.168.0.39:5000 --input-codec=h264 --input-width=600 --input-height=600
[gstreamer] gstDecoder -- creating decoder for 192.168.0.39
[gstreamer] udpsrc port=5000 multicast-group=192.168.0.39 auto-multicast=true caps="application/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264" ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw, width=(int)600, height=(int)600, format=(string)NV12 ! appsink name=mysink
[video]  created gstDecoder from rtp://192.168.0.39:5000
  -- URI: rtp://192.168.0.39:5000
     - protocol:  rtp
     - port:      5000
  -- deviceType: ip
  -- ioType:     input
  -- codec:      h264
  -- width:      600
  -- height:     600
  -- frameRate:  0.000000
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- URI: display://0
     - protocol:  display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
Seems like I am make a little bit of progress. Please advice what else to try.
Can you try this way instead:
video-viewer --debug --input-codec=h264 --input-width=600 --input-height=600 rtp://@:5000
Sometimes it can take some seconds for GStreamer to start receiving the RTP stream, so you may want to let it run for up to ~30 seconds before terminating it.
If this still doesn’t work, can you try changing the resolution of the feed to a standard size like 1280x720 or 800x600 or similar?
this is what I started with in my journey:
many rpi zero with camera sending rtp (not rtsp) stream to the jetson nano
this is based on the following tutorials by Paul McWhorter
https://www.youtube.com/watch?v=7Bz0QzlK6ps&list=PLGs0VKk2DiYxP-ElZ7-QXIERFFPkOuP4_&index=62
hope that helps someone.
I also posted my working code in the past to this thread, so it assists anyone looking for ideas and working code etc.
Tried the suggested and waited 2 minutes but still got β€œfailed to capture video frame”
root@jetsonNano1:/jetson-inference# video-viewer --debug --input-codec=h264 --input-width=600 --input-height=600 rtp://@:5000
[gstreamer] udpsrc port=5000 multicast-group=127.0.0.1 auto-multicast=true caps="application/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264" ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw, width=(int)600, height=(int)600, format=(string)NV12 ! appsink name=mysink
[video]  created gstDecoder from rtp://@:5000
  -- URI: rtp://@:5000
     - protocol:  rtp
     - port:      5000
  -- deviceType: ip
  -- ioType:     input
  -- codec:      h264
  -- width:      600
  -- height:     600
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- URI: display://0
     - protocol:  display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
^Creceived SIGINT
video-viewer:  shutting down...
[gstreamer] gstDecoder -- stopping pipeline, transitioning to GST_STATE_NULL
[gstreamer] gstDecoder -- pipeline stopped
Just thought I’d try a smaller image. Changed feed resolution to 300x300 but still got β€œfailed to capture video frame”
root@jetsonNano1:/jetson-inference# video-viewer --debug --input-codec=h264 --input-width=300 --input-height=300 rtp://@:5000
[gstreamer] udpsrc port=5000 multicast-group=127.0.0.1 auto-multicast=true caps="application/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264" ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw, width=(int)300, height=(int)300, format=(string)NV12 ! appsink name=mysink
     - protocol:  rtp
     - port:      5000
  -- deviceType: ip
  -- ioType:     input
  -- codec:      h264
  -- width:      300
  -- height:     300
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- URI: display://0
     - protocol:  display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
^Creceived SIGINT
Changed @ to 192.168.0.39 and got a core dump
root@jetsonNano1:/jetson-inference# video-viewer --debug --input-codec=h264 --input-width=300 --input-height=300 rtp://192.168.0.39:5000
[gstreamer] udpsrc port=5000 multicast-group=192.168.0.39 auto-multicast=true caps="application/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264" ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw, width=(int)300, height=(int)300, format=(string)NV12 ! appsink name=mysink
     - protocol:  rtp
     - port:      5000
  -- deviceType: ip
  -- ioType:     input
  -- codec:      h264
  -- width:      300
  -- height:     300
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- URI: display://0
     - protocol:  display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
(video-viewer:55): GStreamer-CRITICAL **: 16:32:59.617: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:55): GStreamer-CRITICAL **: 16:32:59.617: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:55): GStreamer-CRITICAL **: 16:32:59.617: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:55): GStreamer-CRITICAL **: 16:32:59.617: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:55): GStreamer-CRITICAL **: 16:32:59.617: gst_structure_get_string: assertion 'structure != NULL' failed
(video-viewer:55): GStreamer-CRITICAL **: 16:32:59.617: gst_mini_object_unref: assertion 'mini_object != NULL' failed
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 304x304 (x 11), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 300, nFrameHeight = 300
[gstreamer] gstDecoder -- onPreroll()
free(): invalid next size (normal)
Aborted (core dumped)
For whatever it’s worth, tried it again and this time there were more activity but still a core dump after waiting for about 40 secs
     - protocol:  rtp
     - port:      5000
  -- deviceType: ip
  -- ioType:     input
  -- codec:      h264
  -- width:      300
  -- height:     300
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- URI: display://0
     - protocol:  display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
Seems like I need to put in the Jetson’s IP address instead of rtp://@:5000.
After this, I tried the 800x600 feed with the Jetson’s IP address but still got the failure to capture video frame even after waiting for over 2 minutes
root@jetsonNano1:/jetson-inference# video-viewer --debug --input-codec=h264 --input-width=800 --input-height=600 rtp://192.168.0.39:5000
[gstreamer] udpsrc port=5000 multicast-group=192.168.0.39 auto-multicast=true caps="application/x-rtp,media=(string)video,clock-rate=(int)90000,encoding-name=(string)H264" ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw, width=(int)800, height=(int)600, format=(string)NV12 ! appsink name=mysink
     - protocol:  rtp
     - port:      5000
  -- deviceType: ip
  -- ioType:     input
  -- codec:      h264
  -- width:      800
  -- height:     600
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- URI: display://0
     - protocol:  display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
^Creceived SIGINT
Oops, I pasted the wrong output for the 300x300 case where I got the core dump after waiting for 40 secs where there were more activities
     - protocol:  rtp
     - port:      5000
  -- deviceType: ip
  -- ioType:     input
  -- codec:      h264
  -- width:      300
  -- height:     300
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- URI: display://0
     - protocol:  display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
(video-viewer:63): GStreamer-CRITICAL **: 16:37:04.048: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:63): GStreamer-CRITICAL **: 16:37:04.048: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:63): GStreamer-CRITICAL **: 16:37:04.048: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:63): GStreamer-CRITICAL **: 16:37:04.048: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:63): GStreamer-CRITICAL **: 16:37:04.048: gst_structure_get_string: assertion 'structure != NULL' failed
(video-viewer:63): GStreamer-CRITICAL **: 16:37:04.048: gst_mini_object_unref: assertion 'mini_object != NULL' failed
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(High\ Profile\)";
[gstreamer] gstDecoder -- map buffer size was less than max size (135000 vs 135007)
[gstreamer] gstDecoder recieve caps:  video/x-raw, width=(int)300, height=(int)300, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1, format=(string)NV12
[gstreamer] gstDecoder -- recieved first frame, codec=h264 format=nv12 width=300 height=300 size=135007
[gstreamer] gstDecoder -- recieved 300x300 frame (135007 bytes)
[cuda]   cudaAllocMapped 135007 bytes, CPU 0x100c60000 GPU 0x100c60000
[cuda]   cudaAllocMapped 135007 bytes, CPU 0x100c81000 GPU 0x100c81000
[cuda]   cudaAllocMapped 135007 bytes, CPU 0x100ca2000 GPU 0x100ca2000
[cuda]   cudaAllocMapped 135007 bytes, CPU 0x100cc3000 GPU 0x100cc3000
RingBuffer -- allocated 4 buffers (135007 bytes each, 540028 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
[cuda]   cudaAllocMapped 270000 bytes, CPU 0x100ce4000 GPU 0x100ce4000
nvbuf_utils: nvbuffer Payload Type not supported
NvBufferGetParams failed for dst_dmabuf_fd
nvbuffer_transform Failed
gst_nvvconv_transform: NvBufferTransform Failed
[gstreamer] gstDecoder -- end of stream (EOS)
[cuda]   cudaAllocMapped 270000 bytes, CPU 0x100d60000 GPU 0x100d60000
[cuda]   cudaAllocMapped 270000 bytes, CPU 0x100da2000 GPU 0x100da2000
[cuda]   cudaAllocMapped 270000 bytes, CPU 0x100de4000 GPU 0x100de4000
RingBuffer -- allocated 4 buffers (270000 bytes each, 1080000 bytes total)
video-viewer:  captured 1 frames (300 x 300)
[OpenGL] glDisplay -- set the window size to 300x300
[OpenGL] creating 300x300 texture (GL_RGB8 format, 270000 bytes)
[cuda]   registered openGL texture for interop access (300x300, GL_RGB8, 270000 bytes)
[gstreamer] gstDecoder -- end of stream (EOS) has been reached, stream has been closed
double free or corruption (!prev)
OK, it seems you may be onto something with using the Jetson’s IP instead of @. However there is some error occurring that I’m unfamiliar with:
My guess is it’s an unsupported resolution. Can you try 320x240 or 640x480?
Also, normally it should not take that long to start receiving the stream. If these devices are on wifi, how is the signal? Does running ifconfig on both devices show much packet loss?
@dusty_nv, thanks for your help. I’ve worked through Paul McWhorter’s tutorial that @therock112 pointed out. I was able to have the RTP stream show up on the Jetson via Python code. So I am now comfortable that it is possible to stream RTP from the Pi Zero to the Jetson Nano. Seems like it is time for me start working through the jetson-inference project examples and to gain a deeper understanding of the changes that @therock112 made to the imagenet.py code. This forum is very valuable and it has been a great learning experience so far.
OK great, glad to hear you got it working! Best of luck to you.
All seemed fine with the RTP streaming from the Pi Zero to the Nono 2GB until I tried integrating it with the detectnet.py code. I kept getting the β€œ[OpenGL] failed to create X11 Window.” error and no video output window was displayed. I started out by adding @therock112’s β€œload the object detection network” code. I tried many tweaks but still could not get rid of the error.
Then I started with @dusty_nv’s detectnet.py code that worked and simplified it to do what I need it to do. The intention is start with a known working code and then add the code to receive the RTP stream using cv2. Below is the simplified code:
import jetson.inference
import jetson.utils
# load the object detection network
net = jetson.inference.detectNet("facenet", threshold=0.3)
# create video sources & outputs
input = jetson.utils.videoSource('/dev/video0')
output = jetson.utils.videoOutput('display://0')
# process frames until the user exits
while True:
	# capture the next image
	img = input.Capture()
	detections = net.Detect(img)
	output.Render(img)
	output.SetStatus("{:s} | Network {:.0f} FPS".format("facenet", net.GetNetworkFPS()))
	# print the detections
	print("Detected {:d} faces".format(len(detections)))
	for detection in detections:
		print("face detected at: x = {:f}, y = {:f} ".format(detection.Center[0], detection.Center[1]))
	# exit on input/output EOS
	if not input.IsStreaming() or not output.IsStreaming():
		break
When I ran this code, I got a display window showing the live video from my webcam, a bounding box of detected faces and the printout of the info of the faces found. I added a 1 second delay to slow down the detection printout.
Below is the output from the terminal:
francis@nano4:~/python-test$ /usr/bin/python3 /home/francis/python-test/my-detectnet.py
jetson.inference -- detectNet loading build-in network 'facenet'
detectNet -- loading detection network model from:
          -- prototxt     networks/facenet-120/deploy.prototxt
          -- model        networks/facenet-120/snapshot_iter_24000.caffemodel
          -- input_blob   'data'
          -- output_cvg   'coverage'
          -- output_bbox  'bboxes'
          -- mean_pixel   0.000000
          -- mean_binary  NULL
          -- class_labels networks/facenet-120/class_labels.txt
          -- threshold    0.300000
          -- batch_size   1
[TRT]    TensorRT version 8.0.1
[TRT]    loading NVIDIA plugins...
[TRT]    Registered plugin creator - ::GridAnchor_TRT version 1
[TRT]    Registered plugin creator - ::GridAnchorRect_TRT version 1
[TRT]    Registered plugin creator - ::NMS_TRT version 1
[TRT]    Registered plugin creator - ::Reorg_TRT version 1
[TRT]    Registered plugin creator - ::Region_TRT version 1
[TRT]    Registered plugin creator - ::Clip_TRT version 1
[TRT]    Registered plugin creator - ::LReLU_TRT version 1
[TRT]    Registered plugin creator - ::PriorBox_TRT version 1
[TRT]    Registered plugin creator - ::Normalize_TRT version 1
[TRT]    Registered plugin creator - ::ScatterND version 1
[TRT]    Registered plugin creator - ::RPROI_TRT version 1
[TRT]    Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT]    Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[TRT]    Could not register plugin creator -  ::FlattenConcat_TRT version 1
[TRT]    Registered plugin creator - ::CropAndResize version 1
[TRT]    Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT]    Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[TRT]    Registered plugin creator - ::EfficientNMS_TRT version 1
[TRT]    Registered plugin creator - ::Proposal version 1
[TRT]    Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT]    Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT]    Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT]    Registered plugin creator - ::Split version 1
[TRT]    Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT]    Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT]    detected model format - caffe  (extension '.caffemodel')
[TRT]    desired precision specified for GPU: FASTEST
[TRT]    requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT]    [MemUsageChange] Init CUDA: CPU +203, GPU +0, now: CPU 226, GPU 1929 (MiB)
[TRT]    native precisions detected for GPU:  FP32, FP16
[TRT]    selecting fastest native precision for GPU:  FP16
[TRT]    attempting to open engine cache file /usr/local/bin/networks/facenet-120/snapshot_iter_24000.caffemodel.1.1.8001.GPU.FP16.engine
[TRT]    loading network plan from engine cache... /usr/local/bin/networks/facenet-120/snapshot_iter_24000.caffemodel.1.1.8001.GPU.FP16.engine
[TRT]    device GPU, loaded /usr/local/bin/networks/facenet-120/snapshot_iter_24000.caffemodel
[TRT]    [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 249, GPU 1928 (MiB)
[TRT]    Loaded engine size: 22 MB
[TRT]    [MemUsageSnapshot] deserializeCudaEngine begin: CPU 249 MiB, GPU 1928 MiB
[TRT]    Using cublas a tactic source
[TRT]    [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU +16, now: CPU 407, GPU 1942 (MiB)
[TRT]    Using cuDNN as a tactic source
[TRT]    [MemUsageChange] Init cuDNN: CPU +241, GPU -14, now: CPU 648, GPU 1928 (MiB)
[TRT]    [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 648, GPU 1916 (MiB)
[TRT]    Deserialization required 7387116 microseconds.
[TRT]    [MemUsageSnapshot] deserializeCudaEngine end: CPU 648 MiB, GPU 1919 MiB
[TRT]    [MemUsageSnapshot] ExecutionContext creation begin: CPU 648 MiB, GPU 1925 MiB
[TRT]    [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU -2, now: CPU 648, GPU 1923 (MiB)
[TRT]    [MemUsageChange] Init cuDNN: CPU +0, GPU +2, now: CPU 648, GPU 1926 (MiB)
[TRT]    Total per-runner device memory is 23652864
[TRT]    Total per-runner host memory is 88192
[TRT]    Allocated activation device memory of size 14508544
[TRT]    [MemUsageSnapshot] ExecutionContext creation end: CPU 648 MiB, GPU 1914 MiB
[TRT]
[TRT]    CUDA engine context initialized on device GPU:
[TRT]       -- layers       69
[TRT]       -- maxBatchSize 1
[TRT]       -- deviceMemory 14508544
[TRT]       -- bindings     3
[TRT]       binding 0
                -- index   0
                -- name    'data'
                -- type    FP32
                -- in/out  INPUT
                -- # dims  3
                -- dim #0  3
                -- dim #1  450
                -- dim #2  450
[TRT]       binding 1
                -- index   1
                -- name    'coverage'
                -- type    FP32
                -- in/out  OUTPUT
                -- # dims  3
                -- dim #0  1
                -- dim #1  28
                -- dim #2  28
[TRT]       binding 2
                -- index   2
                -- name    'bboxes'
                -- type    FP32
                -- in/out  OUTPUT
                -- # dims  3
                -- dim #0  4
                -- dim #1  28
                -- dim #2  28
[TRT]
[TRT]    binding to input 0 data  binding index:  0
[TRT]    binding to input 0 data  dims (b=1 c=3 h=450 w=450) size=2430000
[TRT]    binding to output 0 coverage  binding index:  1
[TRT]    binding to output 0 coverage  dims (b=1 c=1 h=28 w=28) size=3136
[TRT]    binding to output 1 bboxes  binding index:  2
[TRT]    binding to output 1 bboxes  dims (b=1 c=4 h=28 w=28) size=12544
[TRT]
[TRT]    device GPU, /usr/local/bin/networks/facenet-120/snapshot_iter_24000.caffemodel initialized.
[TRT]    detectNet -- number object classes:   1
[TRT]    detectNet -- maximum bounding boxes:  784
[TRT]    detectNet -- loaded 1 class info entries
[TRT]    detectNet -- number of object classes:  1
[gstreamer] gstCamera -- attempting to create device v4l2:///dev/video0
[gstreamer] gstCamera -- found v4l2 device: UVC Camera (046d:0825)
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)"UVC\ Camera\ \(046d:0825\)", v4l2.device.bus_info=(string)usb-70090000.xusb-3.1, v4l2.device.version=(uint)264701, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera -- found 38 caps for v4l2 device /dev/video0
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 5/1 };
[gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [9] video/x-raw, format=(string)YUY2, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [10] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [11] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [12] video/x-raw, format=(string)YUY2, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [13] video/x-raw, format=(string)YUY2, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [14] video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [15] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [16] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [17] video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [18] video/x-raw, format=(string)YUY2, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [19] image/jpeg, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [20] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [21] image/jpeg, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [22] image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [23] image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [24] image/jpeg, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [25] image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [26] image/jpeg, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [27] image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [28] image/jpeg, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [29] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [30] image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [31] image/jpeg, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [32] image/jpeg, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [33] image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [34] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [35] image/jpeg, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [36] image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [37] image/jpeg, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] gstCamera -- selected device profile:  codec=mjpeg format=unknown width=1280 height=720
[gstreamer] gstCamera pipeline string:
[gstreamer] v4l2src device=/dev/video0 ! image/jpeg, width=(int)1280, height=(int)720 ! jpegdec ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video0
[video]  created gstCamera from v4l2:///dev/video0
gstCamera video options:
  -- URI: v4l2:///dev/video0
     - protocol:  v4l2
  -- deviceType: v4l2
  -- ioType:     input
  -- codec:      mjpeg
  -- width:      1280
  -- height:     720
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- rtspLatency 2000
  -- URI: display://0
     - protocol:  display
  -- ioType:     output
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- rtspLatency 2000
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> jpegdec0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> jpegdec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> jpegdec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstCamera -- onPreroll
[gstreamer] gstCamera -- map buffer size was less than max size (1382400 vs 1382407)
[gstreamer] gstCamera recieve caps:  video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
[gstreamer] gstCamera -- recieved first frame, codec=mjpeg format=i420 width=1280 height=720 size=1382407
RingBuffer -- allocated 4 buffers (1382407 bytes each, 5529628 bytes total)
RingBuffer -- allocated 4 buffers (2764800 bytes each, 11059200 bytes total)
[OpenGL] glDisplay -- set the window size to 1280x720
[OpenGL] creating 1280x720 texture (GL_RGB8 format, 2764800 bytes)
[cuda]   registered openGL texture for interop access (1280x720, GL_RGB8, 2764800 bytes)
Detected 0 faces
Detected 1 faces
face detected at: x = 577.822266, y = 366.950012
Detected 0 faces
Detected 1 faces
face detected at: x = 589.777771, y = 365.299988
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 584.977783, y = 369.800018
Detected 1 faces
face detected at: x = 573.244446, y = 382.899994
Detected 1 faces
face detected at: x = 575.600037, y = 381.800018
Detected 1 faces
face detected at: x = 574.799988, y = 381.900024
Detected 1 faces
face detected at: x = 578.622192, y = 371.349976
Detected 1 faces
face detected at: x = 577.733337, y = 383.200012
Detected 1 faces
face detected at: x = 581.333374, y = 376.799988
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 584.844482, y = 370.299988
Detected 1 faces
face detected at: x = 584.311157, y = 378.600006
Detected 1 faces
face detected at: x = 580.266724, y = 375.000000
Detected 1 faces
face detected at: x = 576.088928, y = 384.350037
Detected 1 faces
face detected at: x = 571.644470, y = 380.099976
Detected 1 faces
face detected at: x = 574.622253, y = 381.349976
Detected 1 faces
face detected at: x = 588.977783, y = 361.500000
^CTraceback (most recent call last):
  File "/home/francis/python-test/my-detectnet.py", line 14, in <module>
KeyboardInterrupt
[gstreamer] gstCamera -- stopping pipeline, transitioning to GST_STATE_NULL
[gstreamer] gstCamera -- pipeline stopped
I then tried to add and test the RTP stream receiving code. However, just with adding the import cv2 statement, I started getting the β€œ[OpenGL] failed to create X11 Window.” error. Below is the new code with the added import statement
import jetson.utils
import cv2
while True:
	output.Render(img)
		break
Below is the output from the terminal when I ran the above code
          -- mean_binary  NULL
          -- batch_size   1
[TRT]    [MemUsageChange] Init CUDA: CPU +203, GPU +0, now: CPU 227, GPU 1930 (MiB)
[TRT]    [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 250, GPU 1927 (MiB)
[TRT]    [MemUsageSnapshot] deserializeCudaEngine begin: CPU 250 MiB, GPU 1927 MiB
[TRT]    [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU +24, now: CPU 408, GPU 1943 (MiB)
[TRT]    [MemUsageChange] Init cuDNN: CPU +241, GPU -13, now: CPU 649, GPU 1930 (MiB)
[TRT]    [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 648, GPU 1929 (MiB)
[TRT]    Deserialization required 11662953 microseconds.
[TRT]    [MemUsageSnapshot] deserializeCudaEngine end: CPU 648 MiB, GPU 1931 MiB
[TRT]    [MemUsageSnapshot] ExecutionContext creation begin: CPU 648 MiB, GPU 1918 MiB
[TRT]    [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +1, GPU +1, now: CPU 649, GPU 1919 (MiB)
[TRT]    [MemUsageChange] Init cuDNN: CPU +0, GPU +3, now: CPU 649, GPU 1922 (MiB)
[TRT]    [MemUsageSnapshot] ExecutionContext creation end: CPU 649 MiB, GPU 1926 MiB
[TRT]
[TRT]       -- layers       69
[TRT]       -- bindings     3
[TRT]       binding 0
                -- index   0
                -- name    'data'
                -- type    FP32
                -- in/out  INPUT
                -- # dims  3
                -- dim #0  3
                -- dim #1  450
                -- dim #2  450
[TRT]       binding 1
                -- index   1
                -- name    'coverage'
                -- type    FP32
                -- in/out  OUTPUT
                -- # dims  3
                -- dim #0  1
                -- dim #1  28
                -- dim #2  28
[TRT]       binding 2
                -- index   2
                -- name    'bboxes'
                -- type    FP32
                -- in/out  OUTPUT
                -- # dims  3
                -- dim #0  4
                -- dim #1  28
                -- dim #2  28
[TRT]
[TRT]
     - protocol:  v4l2
  -- deviceType: v4l2
  -- ioType:     input
  -- codec:      mjpeg
  -- width:      1280
  -- height:     720
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: none
  -- loop:       0
  -- rtspLatency 2000
jetson.utils -- no output streams, creating fake null output
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 710.400024, y = 279.250000
Detected 1 faces
face detected at: x = 729.777832, y = 254.700012
Detected 1 faces
face detected at: x = 732.888916, y = 296.700012
Detected 1 faces
face detected at: x = 727.155518, y = 314.600006
Detected 1 faces
face detected at: x = 721.688904, y = 321.450012
Detected 1 faces
face detected at: x = 727.733398, y = 317.750000
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 669.688904, y = 233.800018
Detected 1 faces
face detected at: x = 670.577759, y = 237.300003
Detected 1 faces
face detected at: x = 674.044434, y = 211.449997
Detected 1 faces
face detected at: x = 670.622253, y = 212.600006
Detected 1 faces
face detected at: x = 668.355591, y = 207.149994
Detected 1 faces
face detected at: x = 656.444458, y = 225.500015
Detected 1 faces
face detected at: x = 663.111084, y = 213.949997
Detected 1 faces
face detected at: x = 677.066711, y = 215.150009
Detected 1 faces
face detected at: x = 682.177795, y = 217.850006
Detected 1 faces
face detected at: x = 688.666687, y = 237.550003
Detected 1 faces
face detected at: x = 682.844482, y = 240.850006
Detected 1 faces
face detected at: x = 655.744446, y = 168.149994
Detected 1 faces
face detected at: x = 698.733337, y = 284.550018
  File "/home/francis/python-test/my-detectnet.py", line 15, in <module>
KeyboardInterrupt
Interestingly, the code seems to be running fine, detections were made and results printed out. It is just that there was no display of the live video with the bounding box output.
BTW, I did finished adding all of @therock112’s cv2 RTP stream receiving code. Running that code, I was able to received the RTP stream from the Pi Zero with detection result printouts although, again, the was no video window display.
Did I overlooked something that I am supposed to do to import cv2 to use the jetson.utils.videoOutput() class? Has anyone else come across the same error when adding cv2 code?
In my reply, I mentioned adding a 1 second delay. It helped with the verification that as I move my face around, a different detection result was generated. Adding the delay did not change the results I was seeing. So I did not include the code and output from those tests.
