Can you try doing the import cv2 after the output = jetson.utils.videoOutput('display://0') line?
It seems there is something in openCV that is messing up the OpenGL bindings - maybe OpenCV initializes its own GL extension manager.
I added the import cv2 after output like this
import jetson.inference
import jetson.utils
#import cv2
# load the object detection network
net = jetson.inference.detectNet("facenet", threshold=0.3)
# create video sources & outputs
input = jetson.utils.videoSource('/dev/video0')
import cv2
# process frames until the user exits
while True:
# capture the next image
img = input.Capture()
detections = net.Detect(img)
output.Render(img)
output.SetStatus("{:s} | Network {:.0f} FPS".format("facenet", net.GetNetworkFPS()))
# print the detections
print("Detected {:d} faces".format(len(detections)))
for detection in detections:
print("face detected at: x = {:f}, y = {:f} ".format(detection.Center[0], detection.Center[1]))
# exit on input/output EOS
if not input.IsStreaming() or not output.IsStreaming():
break
Now I get an import error
francis@nano4:~/python-test$ /usr/bin/python3 /home/francis/python-test/my-detectnet.py
jetson.inference -- detectNet loading build-in network 'facenet'
detectNet -- loading detection network model from:
-- prototxt networks/facenet-120/deploy.prototxt
-- model networks/facenet-120/snapshot_iter_24000.caffemodel
-- input_blob 'data'
-- output_cvg 'coverage'
-- output_bbox 'bboxes'
-- mean_pixel 0.000000
-- mean_binary NULL
-- class_labels networks/facenet-120/class_labels.txt
-- threshold 0.300000
-- batch_size 1
[TRT] TensorRT version 8.0.1
[TRT] loading NVIDIA plugins...
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::ScatterND version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] detected model format - caffe (extension '.caffemodel')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] [MemUsageChange] Init CUDA: CPU +203, GPU +0, now: CPU 226, GPU 1937 (MiB)
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /usr/local/bin/networks/facenet-120/snapshot_iter_24000.caffemodel.1.1.8001.GPU.FP16.engine
[TRT] loading network plan from engine cache... /usr/local/bin/networks/facenet-120/snapshot_iter_24000.caffemodel.1.1.8001.GPU.FP16.engine
[TRT] device GPU, loaded /usr/local/bin/networks/facenet-120/snapshot_iter_24000.caffemodel
[TRT] [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 249, GPU 1911 (MiB)
[TRT] Loaded engine size: 22 MB
[TRT] [MemUsageSnapshot] deserializeCudaEngine begin: CPU 249 MiB, GPU 1911 MiB
[TRT] Using cublas a tactic source
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU +7, now: CPU 407, GPU 1934 (MiB)
[TRT] Using cuDNN as a tactic source
[TRT] [MemUsageChange] Init cuDNN: CPU +241, GPU -22, now: CPU 648, GPU 1912 (MiB)
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 648, GPU 1919 (MiB)
[TRT] Deserialization required 7846345 microseconds.
[TRT] [MemUsageSnapshot] deserializeCudaEngine end: CPU 648 MiB, GPU 1916 MiB
[TRT] [MemUsageSnapshot] ExecutionContext creation begin: CPU 648 MiB, GPU 1917 MiB
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +3, now: CPU 648, GPU 1920 (MiB)
[TRT] [MemUsageChange] Init cuDNN: CPU +0, GPU +2, now: CPU 648, GPU 1922 (MiB)
[TRT] Total per-runner device memory is 23652864
[TRT] Total per-runner host memory is 88192
[TRT] Allocated activation device memory of size 14508544
[TRT] [MemUsageSnapshot] ExecutionContext creation end: CPU 648 MiB, GPU 1908 MiB
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] -- layers 69
[TRT] -- maxBatchSize 1
[TRT] -- deviceMemory 14508544
[TRT] -- bindings 3
[TRT] binding 0
-- index 0
-- name 'data'
-- type FP32
-- in/out INPUT
-- # dims 3
-- dim #0 3
-- dim #1 450
-- dim #2 450
[TRT] binding 1
-- index 1
-- name 'coverage'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 1
-- dim #1 28
-- dim #2 28
[TRT] binding 2
-- index 2
-- name 'bboxes'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 4
-- dim #1 28
-- dim #2 28
[TRT]
[TRT] binding to input 0 data binding index: 0
[TRT] binding to input 0 data dims (b=1 c=3 h=450 w=450) size=2430000
[TRT] binding to output 0 coverage binding index: 1
[TRT] binding to output 0 coverage dims (b=1 c=1 h=28 w=28) size=3136
[TRT] binding to output 1 bboxes binding index: 2
[TRT] binding to output 1 bboxes dims (b=1 c=4 h=28 w=28) size=12544
[TRT]
[TRT] device GPU, /usr/local/bin/networks/facenet-120/snapshot_iter_24000.caffemodel initialized.
[TRT] detectNet -- number object classes: 1
[TRT] detectNet -- maximum bounding boxes: 784
[TRT] detectNet -- loaded 1 class info entries
[TRT] detectNet -- number of object classes: 1
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera -- attempting to create device v4l2:///dev/video0
[gstreamer] gstCamera -- found v4l2 device: UVC Camera (046d:0825)
[gstreamer] v4l2-proplist, device.path=(string)/dev/video0, udev-probed=(boolean)false, device.api=(string)v4l2, v4l2.device.driver=(string)uvcvideo, v4l2.device.card=(string)"UVC\ Camera\ \(046d:0825\)", v4l2.device.bus_info=(string)usb-70090000.xusb-3.1, v4l2.device.version=(uint)264701, v4l2.device.capabilities=(uint)2216689665, v4l2.device.device_caps=(uint)69206017;
[gstreamer] gstCamera -- found 38 caps for v4l2 device /dev/video0
[gstreamer] [0] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [1] video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
[gstreamer] [2] video/x-raw, format=(string)YUY2, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [3] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [4] video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
[gstreamer] [5] video/x-raw, format=(string)YUY2, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 5/1 };
[gstreamer] [6] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [7] video/x-raw, format=(string)YUY2, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [8] video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [9] video/x-raw, format=(string)YUY2, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [10] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [11] video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [12] video/x-raw, format=(string)YUY2, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [13] video/x-raw, format=(string)YUY2, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [14] video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [15] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [16] video/x-raw, format=(string)YUY2, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [17] video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [18] video/x-raw, format=(string)YUY2, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [19] image/jpeg, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [20] image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [21] image/jpeg, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [22] image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [23] image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [24] image/jpeg, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [25] image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [26] image/jpeg, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [27] image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [28] image/jpeg, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [29] image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [30] image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [31] image/jpeg, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [32] image/jpeg, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [33] image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [34] image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [35] image/jpeg, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [36] image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] [37] image/jpeg, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
[gstreamer] gstCamera -- selected device profile: codec=mjpeg format=unknown width=1280 height=720
[gstreamer] gstCamera pipeline string:
[gstreamer] v4l2src device=/dev/video0 ! image/jpeg, width=(int)1280, height=(int)720 ! jpegdec ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully created device v4l2:///dev/video0
[video] created gstCamera from v4l2:///dev/video0
gstCamera video options:
-- URI: v4l2:///dev/video0
- protocol: v4l2
-- deviceType: v4l2
-- ioType: input
-- codec: mjpeg
-- width: 1280
-- height: 720
-- frameRate: 30.000000
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[OpenGL] glDisplay -- X screen 0 resolution: 1920x1080
[OpenGL] glDisplay -- X window resolution: 1920x1080
[OpenGL] glDisplay -- display device initialized (1920x1080)
[video] created glDisplay from display://0
glDisplay video options:
-- URI: display://0
- protocol: display
-- deviceType: display
-- ioType: output
-- codec: raw
-- width: 1920
-- height: 1080
-- frameRate: 0.000000
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
File "/home/francis/python-test/my-detectnet.py", line 10, in <module>
import cv2
File "/usr/lib/python3.6/dist-packages/cv2/__init__.py", line 89, in <module>
bootstrap()
File "/usr/lib/python3.6/dist-packages/cv2/__init__.py", line 79, in bootstrap
import cv2
ImportError: /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
Try running export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1 in your terminal before you launch the program.
Tried doing that with the import cv2 after output and this time it worked!!! What did I do? Is this something I need to do each time I run the program? I now see the video output with bounding box. Below is the result from terminal.
francis@nano4:~/python-test$ export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1
-- mean_binary NULL
-- batch_size 1
[TRT] [MemUsageChange] Init CUDA: CPU +203, GPU +0, now: CPU 226, GPU 1909 (MiB)
[TRT] [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 249, GPU 1929 (MiB)
[TRT] [MemUsageSnapshot] deserializeCudaEngine begin: CPU 249 MiB, GPU 1929 MiB
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU +17, now: CPU 407, GPU 1934 (MiB)
[TRT] [MemUsageChange] Init cuDNN: CPU +241, GPU -34, now: CPU 648, GPU 1900 (MiB)
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 648, GPU 1908 (MiB)
[TRT] Deserialization required 9074108 microseconds.
[TRT] [MemUsageSnapshot] deserializeCudaEngine end: CPU 648 MiB, GPU 1908 MiB
[TRT] [MemUsageSnapshot] ExecutionContext creation begin: CPU 648 MiB, GPU 1909 MiB
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +3, now: CPU 648, GPU 1911 (MiB)
[TRT] [MemUsageChange] Init cuDNN: CPU +0, GPU +9, now: CPU 648, GPU 1920 (MiB)
[TRT] [MemUsageSnapshot] ExecutionContext creation end: CPU 648 MiB, GPU 1919 MiB
[TRT]
[TRT] -- layers 69
[TRT] -- bindings 3
[TRT] binding 0
-- index 0
-- name 'data'
-- type FP32
-- in/out INPUT
-- # dims 3
-- dim #0 3
-- dim #1 450
-- dim #2 450
[TRT] binding 1
-- index 1
-- name 'coverage'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 1
-- dim #1 28
-- dim #2 28
[TRT] binding 2
-- index 2
-- name 'bboxes'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #0 4
-- dim #1 28
-- dim #2 28
[TRT]
[TRT]
- protocol: v4l2
-- deviceType: v4l2
-- ioType: input
-- codec: mjpeg
-- width: 1280
-- height: 720
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
-- URI: display://0
- protocol: display
-- ioType: output
-- codec: raw
-- width: 1920
-- height: 1080
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> jpegdec0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> jpegdec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> jpegdec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstCamera -- onPreroll
[gstreamer] gstCamera -- map buffer size was less than max size (1382400 vs 1382407)
[gstreamer] gstCamera recieve caps: video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)30/1
[gstreamer] gstCamera -- recieved first frame, codec=mjpeg format=i420 width=1280 height=720 size=1382407
RingBuffer -- allocated 4 buffers (1382407 bytes each, 5529628 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
RingBuffer -- allocated 4 buffers (2764800 bytes each, 11059200 bytes total)
[gstreamer] gstreamer message qos ==> v4l2src0
[OpenGL] glDisplay -- set the window size to 1280x720
[OpenGL] creating 1280x720 texture (GL_RGB8 format, 2764800 bytes)
[cuda] registered openGL texture for interop access (1280x720, GL_RGB8, 2764800 bytes)
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 987.955566, y = 291.000000
Detected 1 faces
face detected at: x = 994.755554, y = 252.699997
Detected 1 faces
face detected at: x = 984.311157, y = 310.000000
Detected 1 faces
face detected at: x = 972.488892, y = 309.250000
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 880.244507, y = 322.750000
Detected 1 faces
face detected at: x = 871.955566, y = 370.250000
Detected 1 faces
face detected at: x = 957.200012, y = 305.081238
Detected 1 faces
face detected at: x = 878.311157, y = 353.575012
Detected 1 faces
face detected at: x = 798.800049, y = 372.200012
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 931.422241, y = 322.599976
Detected 1 faces
face detected at: x = 935.244507, y = 324.450012
Detected 0 faces
Detected 1 faces
face detected at: x = 952.377808, y = 278.450012
Detected 1 faces
face detected at: x = 936.355591, y = 293.800018
Detected 1 faces
face detected at: x = 938.311157, y = 287.400024
Detected 1 faces
face detected at: x = 954.444458, y = 287.950012
Detected 1 faces
face detected at: x = 953.644470, y = 278.850006
Detected 1 faces
face detected at: x = 941.644409, y = 262.599976
Detected 0 faces
Detected 1 faces
face detected at: x = 896.266724, y = 258.899994
Detected 0 faces
Detected 1 faces
face detected at: x = 873.822266, y = 245.899994
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 892.933350, y = 246.099991
Detected 0 faces
Detected 1 faces
face detected at: x = 884.577759, y = 257.200012
Detected 1 faces
face detected at: x = 896.000000, y = 245.900009
Detected 0 faces
Detected 1 faces
face detected at: x = 855.511108, y = 250.900009
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 799.333374, y = 294.100006
Detected 1 faces
face detected at: x = 783.600037, y = 297.799988
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 780.266724, y = 312.350006
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 779.555542, y = 333.549988
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 787.733398, y = 329.150024
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 772.844482, y = 332.900024
Detected 0 faces
Detected 0 faces
Detected 1 faces
face detected at: x = 809.422241, y = 358.799988
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
Detected 0 faces
^CTraceback (most recent call last):
File "/home/francis/python-test/my-detectnet.py", line 16, in <module>
KeyboardInterrupt
[gstreamer] gstCamera -- stopping pipeline, transitioning to GST_STATE_NULL
[gstreamer] gstCamera -- pipeline stopped
BTW, I tried it with the additional cv2 code from @therock112 to receive the RTP stream and that is working as well. Now I can see the faces being detected from the broadcasting Pi Zero camera and the detection results on the terminal. Awesome!!!
You need to either run it once per terminal session (before launching detectnet) or put it in your user’s .bashrc
Thanks @dusty_nv!!!
For completeness, I will document what I did and how I tested it:
First, I added the “export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1” line to my .bashrc file with the Text Editor.
went to a terminal that had been open and ran the detection program. I had the ImportError.
did a “source .bashrc” and ran the program again and it ran fine with not error. There was a live video window showing the detection with bounding box and all.
also, I opened up a new terminal and ran the program immediately without doing anything else. Program ran as expected.
