I new to Mellanox the user guide is not helpful to me please can some one please show steps on how to change the dns
Hello Frank,
Thank you for posting your question on the NVIDIA Networking Community.
For changing the DNS setting on a Mellanox switch, you can use the following syntax:
Login into the switch through SSH → ssh -ladmin or through serial console
On the switch, use the following commands to change the DNS nameserver
mlnx-sw [standalone: master] > ena
mlnx-sw [standalone: master] # configure terminal
mlnx-sw [standalone: master] (config) # ip name-server 192.168.1.62
mlnx-sw [standalone: master] (config) # configuration write
The setting will be effective immediatly.
Thank you,
~NVIDIA Networking Technical Support
