Hello to all,
we’d like to use IMX377 from Leopard Imagin at the maximum frame rate.
How to change resolution and fps rate using driver, gstream or opencv?
Best regards.
Hello to all,
Best regards.
Does this sensor support 300fps!!
You need to check the sensor capability first. And make sure the 300fps mode is enable by sensor driver.
Yes it does
[url]https://www.sony-semicon.co.jp/products_en/IS/sensor2/img/products/IMX377CQT_ProductSummary_v1.5_20150414.pdf[/url]
In fact 299.7 fps is allowed. We need really to run @250fps/720p.
Where to find driver sources?
How can we increase IMX377 100fps?
You need get help fro Leopard to provide the sensor driver.
