hi, I am trying to load an articulation(simply a sphere with a D6 joint) into the scene, but I got the following error indicating the joint is not recognized, I wonder where could went wrong
the error I got:
File "/home/xinyili/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/asset_base.py", line 92, in <lambda>
lambda event, obj=weakref.proxy(self): obj._initialize_callback(event),
File "/home/xinyili/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/asset_base.py", line 263, in _initialize_callback
self._initialize_impl()
File "/home/xinyili/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/articulation/articulation.py", line 942, in _initialize_impl
self._process_cfg()
File "/home/xinyili/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/articulation/articulation.py", line 1069, in _process_cfg
indices_list, _, values_list = string_utils.resolve_matching_names_values(
File "/home/xinyili/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/utils/string.py", line 364, in resolve_matching_names_values
raise ValueError(
ValueError: Not all regular expressions are matched! Please check that the regular expressions are correct:
Available strings: []
[INFO]: Setup complete...
File "/home/xinyili/IsaacLab/3d_action.py", line 176, in <module>
main()
File "/home/xinyili/IsaacLab/3d_action.py", line 171, in main
run_simulator(sim, scene)
File "/home/xinyili/IsaacLab/3d_action.py", line 136, in run_simulator
scene.reset()
File "/home/xinyili/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/scene/interactive_scene.py", line 347, in reset
articulation.reset(env_ids)
File "/home/xinyili/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/articulation/articulation.py", line 166, in reset
for actuator in self.actuators.values():
AttributeError: 'Articulation' object has no attribute 'actuators'
I save the articulation in the isaacsim GUI by ‘save selected’ of the sphere and the joint where the sphere is set to be the articulation root, since I cannot upload usd file in the forum, here I attach the usda version of my articulation
#usda 1.0
defaultPrim = "Root"
upAxis = "Z"
def Xform "Root"
def Sphere "Sphere" (
apiSchemas = ["PhysicsArticulationRootAPI", "PhysxArticulationAPI", "PhysicsRigidBodyAPI", "PhysxRigidBodyAPI", "PhysicsCollisionAPI", "PhysxCollisionAPI"]
float3[] extent = [(-0.5, -0.5, -0.5), (0.5, 0.5, 0.5)]
bool physics:collisionEnabled = 1
bool physics:kinematicEnabled = 0
bool physics:rigidBodyEnabled = 1
double radius = 0.5
custom bool refinementEnableOverride = 1
custom int refinementLevel = 2
token ui:displayGroup = "Material Graphs"
token ui:displayName = "Sphere"
int ui:order = 1024
float3 xformOp:rotateXYZ = (0, -0, 0)
float3 xformOp:scale = (1, 1, 1)
double3 xformOp:translate = (0, 0, 0)
uniform token[] xformOpOrder = ["xformOp:translate", "xformOp:rotateXYZ", "xformOp:scale"]
def PhysicsJoint "D6Joint" (
apiSchemas = ["PhysicsLimitAPI:transX", "PhysicsLimitAPI:transY", "PhysicsLimitAPI:transZ", "PhysicsLimitAPI:rotX", "PhysicsLimitAPI:rotY", "PhysicsLimitAPI:rotZ"]
float limit:rotX:physics:high = -1
float limit:rotX:physics:low = 1
float limit:rotY:physics:high = -1
float limit:rotY:physics:low = 1
float limit:rotZ:physics:high = -1
float limit:rotZ:physics:low = 1
float limit:transX:physics:high = -1
float limit:transX:physics:low = 1
float limit:transY:physics:high = -1
float limit:transY:physics:low = 1
float limit:transZ:physics:high = -1
float limit:transZ:physics:low = 1
rel physics:body1 = </Root/Sphere>
float physics:breakForce = inf
float physics:breakTorque = inf
point3f physics:localPos0 = (0, 0, 0)
point3f physics:localPos1 = (0, 0, 0)
quatf physics:localRot0 = (1, 0, 0, 0)
quatf physics:localRot1 = (1, 0, 0, 0)
the code I use to load the articulation:
@configclass
class BouncingCfg(InteractiveSceneCfg):
sphere = ArticulationCfg(
prim_path="{ENV_REGEX_NS}/Sphere",
# spawn=sim_utils.SphereCfg(
spawn=sim_utils.UsdFileCfg(usd_path="/home/xinyili/IsaacLab/Sphere_joint.usd",
rigid_props=sim_utils.RigidBodyPropertiesCfg(
rigid_body_enabled=True,
max_linear_velocity=1000.0,
max_angular_velocity=1000.0,
max_depenetration_velocity=100.0,
enable_gyroscopic_forces=True,
articulation_props=sim_utils.ArticulationRootPropertiesCfg(
enabled_self_collisions=False,
solver_position_iteration_count=4,
solver_velocity_iteration_count=0,
sleep_threshold=0.005,
stabilization_threshold=0.001,
init_state=ArticulationCfg.InitialStateCfg(pos=[0, 0, 1], lin_vel=[10, 0.3, 0]),
actuators={
"actuator": ImplicitActuatorCfg(
joint_names_expr=["D6Joint"],
effort_limit=400.0,
velocity_limit=100.0,
stiffness=0.0,
damping=10.0,
def run_simulator(sim: sim_utils.SimulationContext, scene: InteractiveScene):
sphere = scene["sphere"]
sim_dt = sim.get_physics_dt()
scene.reset()
# Simulation loop
while simulation_app.is_running():
scene.write_data_to_sim()
sim.step()
scene.update(sim_dt)
def main():
sim_cfg = sim_utils.SimulationCfg(device=args_cli.device, dt=0.01)
sim = SimulationContext(sim_cfg)
sim.set_camera_view([5, 0.0, 8], [0.0, 0.0, 2.0])
scene_cfg = BouncingCfg(num_envs=args_cli.num_envs, env_spacing=20)
scene = InteractiveScene(scene_cfg)
sim.reset()
any help would be appreciated, thanks!
