How to make the fonts in Isaac Sim larger
I am a beginner on Isaac Sim, does someone know how to make the fonts larger in Isaac Sim?
Thank you for the question. Someone from our team will investigate about it and will get back to you.
has there been any progress on this? the default ui font size in isaac sim is way too small for me; it makes it very difficult for me to use the gui and gives me a lot of eye strain >.<
Please try setting font size globally through Windows or Ubuntu.
thanks for getting back to me!
unfortunately, that solution doesn’t really work for me, since my global font size in ubuntu is exactly where i want it. Is there no way to change the font size in the isaac sim ui separately from my global font size?
No there is no independent way to change the font size in any kit template. Not unless you start to edit and built your own kit file. The easiest way to make things bigger globally is to lower your resolution, or increase your font size for your OS. Those are your only two options.
gotcha. is there any work being done to fix this issue? in addition to improving everyone’s comfort, the ability to separately scale the font for an application is a simple and impactful way to improve accessibility for users with visual impairments
