I use AGX orin 64GB development kit
You are using the Jetson AGX Orin 64GB Development Kit. Here’s a comprehensive overview of the kit and its features:
Key Features:
- 64GB of memory
- Same performance as the original 32GB Jetson AGX Orin Developer Kit, except for the increased memory
- Price: $1999
Comparison with Jetson AGX Orin 32GB Module:
- The main difference between the two is the memory capacity. The 64GB module has twice the memory of the 32GB module.
- The performance of the two modules is the same, except for the increased memory bandwidth and capacity of the 64GB module.
Comparison with Production Modules:
- The Jetson AGX Orin 64GB module is a production module, which means it is compatible with the Jetson AGX Orin reference carrier board (P3737-0000) and is intended for production use.
- The production module is sold separately, whereas the development module is only sold as part of the developer kit.
Development Kit vs. Production Module:
- The development kit is designed for developers to create and test their applications, whereas the production module is intended for production use.
- The development kit includes a reference carrier board, whereas the production module is sold separately and requires a compatible carrier board.
Software Requirements:
- To use the Jetson AGX Orin 64GB Development Kit, you will need to flash the device with JetPack 6.2/Jetson Linux 36.4.3 (or JetPack 6.1/Jetson Linux 36.4.0).
- You will also need to install Jetson Platform Services 2.0.
Hardware Requirements:
- To use the Jetson AGX Orin 64GB Development Kit, you will need a USB-C flashing cable, a monitor, keyboard, and mouse.
- You will also need a 128GB (minimum) NVMe drive.
I hope this information helps you get started with your Jetson AGX Orin 64GB Development Kit!
如何使能VDD_12V呢?看到这个电源是给PCIE和备用12V风扇供电的,为什么测的电压是0V?
Please refer to Jetson AGX Orin Platform Adaptation and Bring-Up — NVIDIA Jetson Linux Developer Guide
我们只是想用12V给备用风扇供电,没有想要启动PCIE,看具体的操作方法是怎样的
FAN could be powered form other external (12V or other depending on the fan chosen) source, if needed.
This regulator is controlled by PCIe driver by a GPIO.
If you want to control this GPIO manually or by other driver, then you need to remove this regulator from PCIe C5 device tree node.
基本上我只是把前面我說的話再翻成中文說一次.
你得把device tree裡面這一根gpio的regulator從pcie node裡面拿掉. 不然PCIe link training結束沒找到裝置的狀況下就會把這根又關掉.
