How to massflash Jetson Orin Nano?
I had refer README_massflash.txt in old L4T directory before.
All contents in L4T 35.3.1 like below.
apply_binaries.sh                        odmfuseread.sh
bootloader                               odmfuse.sh
build_l4t_bup.sh                         p2822-0000+p2888-0001.conf
clara-agx-xavier-devkit.conf             p2822-0000+p2888-0004.conf
e3900-0000+p2888-0004-b00.conf           p2822-0000+p2888-0008.conf
flash.sh                                 p2822-0000+p2888-0008-maxn.conf
generate_capsule                         p2822-0000+p2888-0008-noecc.conf
holoscan-devkit.conf                     p2972-0000.conf.common
igx-orin-devkit.conf                     p2972-0000-devkit-maxn.conf
initrdlog                                p2972-0000-devkit-slvs-ec.conf
jetson_additional_board_spec.cfg         p2972.conf
jetson-agx-orin-devkit-as-jao-32gb.conf  p3449-0000+p3668-0000-qspi-sd.conf
jetson-agx-orin-devkit-as-nano4gb.conf   p3449-0000+p3668-0001-qspi-emmc.conf
jetson-agx-orin-devkit-as-nano8gb.conf   p3509-0000+p3668-0000-qspi.conf
jetson-agx-orin-devkit-as-nx-16gb.conf   p3509-0000+p3668-0000-qspi-sd.conf
jetson-agx-orin-devkit-as-nx-8gb.conf    p3509-0000+p3668-0001-qspi-emmc.conf
jetson-agx-orin-devkit.conf              p3509-a02+p3767-0000.conf
jetson-agx-orin-devkit-industrial.conf   p3509-a02+p3767-0000-maxn.conf
jetson-agx-orin-devkit-maxn.conf         p3668.conf.common
jetson-agx-xavier-devkit.conf            p3701.conf.common
jetson-agx-xavier-ind-noecc.conf         p3711-0000+p3701-0002.conf
jetson-agx-xavier-industrial.conf        p3737-0000+p3701-0000-as-p3701-0004.conf
jetson-agx-xavier-industrial-mxn.conf    p3737-0000+p3701-0000-as-p3767-0000.conf
jetson_board_spec.cfg                    p3737-0000+p3701-0000-as-p3767-0001.conf
jetson-orin-nano-devkit.conf             p3737-0000+p3701-0000-as-p3767-0003.conf
jetson-orin-nano-devkit-nvme.conf        p3737-0000+p3701-0000-as-p3767-0004.conf
jetson-xavier.conf                       p3737-0000+p3701-0000.conf
jetson-xavier-maxn.conf                  p3737-0000+p3701-0000-maxn.conf
jetson-xavier-nx-devkit.conf             p3740-0002-b00+p3701-0002.conf
jetson-xavier-nx-devkit-emmc.conf        p3740-0002-b01+p3701-0002.conf
jetson-xavier-nx-devkit-qspi.conf        p3740-0002-c01+p3701-0008.conf
jetson-xavier-slvs-ec.conf               p3767.conf.common
kernel                                   p3768-0000+p3767-0000.conf
l4t_generate_soc_bup.sh                  p3768-0000+p3767-0000-maxn.conf
l4t_sign_image.sh                        p3768-0000+p3767-0000-nvme.conf
nvautoflash.sh                           README_Autoflash.txt
nvmassfusegen.sh                         rootfs
nvsdkmanager_flash.sh                    source
nv_tegra                                 source_sync.sh
nv_tools                                 temp_initrdflash
odmfuse.func                             tools
Thank you.
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/SD/FlashingSupport.html#flashing-to-multiple-jetson-devices
Thank you.
Glad you fround the answer. most info can be found from the developer guide. Thanks
