How to pass new Streammux config-file-path in nvmultiurisrcbin properties - Deepstream 6.2
• DeepStream Version
• TensorRT Version
I am trying to use new streammux along with nvmultiurisrcbin. However I got an error:
TypeError: object of type GstDsNvMultiUriBin' does not have property config-file-path’
So I tried to understand property setting in deepstream/sources/gst-plugins/gst-nvmultiurisrcbin/gstdsnvmultiurisrcbin.cpp. Here I don’t see config-file-path property related to streammux. So new streammux is not being supported in nvmultiurisrcbin, but docs mention it’s supported.
Am I missing something? Is it really supported?
This property is not implemented. It has been defined in “GstDsNvStreammuxConfig” structure(refer to /opt/nvidia/deepstream/deepstream/sources/includes/gst-nvcommonconfig.h). The nvmultiurisrcbin is open source. You can add this new property and implement the function with the source code.
while compiling gst-nvmultiurisrcbin plugin facing gstdsnvmultiurisrcbin.h:30:10: fatal error: gstdsnvurisrcbin.h: No such file or directory
I couldn’t find gstdsnvurisrcbin.h anywhere in the source code. Any idea where to obtain it?
This is a bug. Please use the attached header file.
gstdsnvurisrcbin.h (3.3 KB)
